Old 26th October 2025, 20:00   #2181  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally Posted by jpsdr View Post
That's due to an installation issue on my buildbot server which clashes with the recent change to how the 64-bit installer is built. It'll be fixed soon-ish.
Latest MKVToolNix is v97.0
Mosu is offline   Reply With Quote
Old 26th October 2025, 21:32   #2182  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Problem's fixed, and the missing build has been built.
Old 26th October 2025, 23:23   #2183  |  Link
jpsdr
Nice, thanks.
My github.
Old 8th November 2025, 12:24   #2184  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v96.0 released
Heyooo.
Here's the latest, the greatest (maybe?) release of MKVtoolNix, v96.0. Business as usual: couple of enhancements, couple of bug fixes.
Here are the usual links: the MKVToolNix home page, the downloads section and the source code.
The Windows packages and Linux AppImage are available already. The other Linux packages & the macOS disk image are still being built and will be available over the course of the next couple of hours.
Here are the NEWS since the previous release:
Version 96.0 "It's My Life" 2025-11-08
New features and enhancements
  • all programs: added a command-line parameter "--no-bom" that disables writing byte order marks to text files encoded with one of the UTF variants. Implements #6166.
  • MKVToolNix GUI: multiplexer: added variable "<MTX_CHAPTERS_FILE_NAME>" to the "run program after job completion" mechanism containing the absolute path to the chapters file name. Implements #6172.
Bug fixes
  • mkvmerge: OBU reader: fixed probing files in which the first frame ends after the 1MB mark, which is how big the memory buffer used for probing content is. Fixes #6165.
  • mkvmerge: VobSub reader: VobSub ".idx" files that start with a byte-order mark (BOM) are now read again correctly. Fixes #6162.
  • mkvextract: AV1/IVF: fixed inserting a temporal delimiter OBU at the start of each frame if there is none. Mostly fixes #6120.
  • mkvextract: AV1/IVF: fixed a potential calculation error when deriving frame rate numerator & denominator from Matroska's default duration. Part of the fix of #6120.
  • mkvextract: AV1/IVF: fixed calculation of IVF frame number calculation from Matroska's frame timestamps by rounding instead of truncating. Part of the fix of #6120.
Have fun 😁
Old 8th November 2025, 13:22   #2185  |  Link
Klaus1189
Thanks for new release, but while installation of x64 on Win11 I do not get asked for admin rights to install and therefore install fails. If I rightclick the installer and run it with admin rights, it works. Is that just me or can you confirm that?
Old 8th November 2025, 13:31   #2186  |  Link
LeMoi
No problem here win WIN11 too to install without specifiying admin rights
LeMoi is offline   Reply With Quote
Old 8th November 2025, 13:43   #2187  |  Link
Klaus1189
I retested 95.0.0 which works without manual admin rights and 96.0.0 which does not.
Old 8th November 2025, 17:36   #2188  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
I have another user reporting the same kind of issue over on the forum. Note that I'm using a different/new NSIS build so that I can actually build 64-bit installer executables instead of 32-bit ones. You'll get used to it. Other programs do it that way, too.
What I find interesting, though, is that I personally get asked for admin privs immediately upon launching the installer without having to tell Windows so explicitly, like LeMoi, too. I do not know why, nor do I care to investigate, to be quite honest.
Old 8th November 2025, 20:15   #2189  |  Link
Klaus1189
If it helps, Win 11 25H2, fresh new install about 2 weeks ago. If you reconsider, just let me know. I will provide as much info as I can. I am also here for tests.
Old 8th November 2025, 20:29   #2190  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
When trying to instal 'mkvtoolnix-64-bit-96.0-setup.exe' I receive the following message even after deleting mkvtoolnix first: -
SeeMoreDigital is online now   Reply With Quote
Old 8th November 2025, 21:34   #2191  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Run the installer with admin privileges.
Old 8th November 2025, 21:41   #2192  |  Link
Klaus1189
Yes, exact same issue
Old 8th November 2025, 21:42   #2193  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
You can give https://mkvtoolnix.download/windows/...est build here a try. I've changed
RequestExecutionLevel none
to
RequestExecutionLevel admin
. Funnily enough I had used "admin" in the past, but changed it to "none" in 2010 — unfortunately without any explanation in the commit message. I vaguely remember users requesting I do this, but I do not remember their reasoning.
Old 8th November 2025, 21:43   #2194  |  Link
SeeMoreDigital
Yes, I actually ended up doing this. Sorry I neglected to mention it in my previous post.
Old 9th November 2025, 11:52   #2195  |  Link
Klaus1189
to
https://mkvtoolnix.download/windows/...1908-setup.exe
This build askes me for admin rights
Old 18th November 2025, 18:03   #2196  |  Link
lansing
I was muxing vob files into a mkv but the length doesn't match with the dgindex I created with the same vobs. It looks like mkvtoolnix added 7 frames to each vob except for the first one? I'm using version 96.0
Old 18th November 2025, 18:50   #2197  |  Link
SeeMoreDigital
As a test... Have you tried joining the vob files together using TSmuxer GUI?
Old 2nd January 2026, 14:36   #2198  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v97.0 released
Hi fine folks!
Happy new year everyone. Here's v97.0 of MKVToolNix, probably the smallest release I've ever done with just two NEWS.md entries. But I like to keep up with my ususal schedule, so here we are. Feel free to skip this release if the feature mentioned below is irrelevant for you.
An important note for macOS users: I will stop providing macOS binaries and any kind of support for macOS in the second half of 2026 due to Apple discontinuing support for the Rosetta x86-to-ARM translation system. As my current build process only works on x86 (Intel) macs this will be the end of the line for any kind of mac support for me.
Version 97.0 "You Don't Have A Clue" 2026-01-02
  • mkvmerge: MP4 reader: added support for TrueHD in MP4 with FourCC "mlpa". Implements #6178.
  • installer: the Windows installer will request admin permissions again, as it did before release 96.0.
Have fun 😁
matroska
