#202 | Link | |
Groucho's Avisynth Stuff Last edited by Groucho2004; 11th September 2019 at 11:21. |
#203 | Link |
Technical question: After version 2.5.3 have you changed how you output text to console? Some time ago I wrote a simple GUI for AVSMeter and it worked fine up to version 2.5.3. (the capturing code also works fine with ffmpeg.exe/x264.exe/x265.exe and so on)
![]() Now with 2.5.4 and newer version of avsmeter my code gets those weird looooooong spaces in avs info section. Correct captured text from v2.5.3 (each line finishes with proper CRLF marker) ...and now weird capture v2.5.4 and newer ![]() ![]() Looks like instead of CRLF marker for each line now we have those artificial spaces? txt files in case if you want to examine them in notepad++ -> https://www.mediafire.com/file/9cs3p...x/logs.7z/file
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 29th September 2019 at 16:27. |
#204 | Link | |
FFMpeg has different text output routines. I use the console API to be able to position the cursor where I need it on the screen which probably explains some oddities when trying to capture the output.
Groucho's Avisynth Stuff |
#205 | Link | |
#206 | Link | |
However, that function was already present in 2.5.3 so I'll check again what I changed. There might well be a workaround that won't break the capturing.
#207 | Link | |
#208 | Link |
Are you capturing stderr or stdout? Also, what are your default console dimensions (number of rows/columns)?
#209 | Link |
Atak,
Here is a slightly modified 2.5.4, let me know if that behaves differently.
#210 | Link | |
#212 | Link |
There is a "gui" for the plugin scan part: Avisynth Info Tool https://forum.doom9.org/showthread.php?p=1864714
#213 | Link | |
Useful n00b
#214 | Link |
No, neither decent nor indecent.
#216 | Link |
I noticed that sometimes the INI file gets overwritten with a default one. Not sure why this happens.
Is there a way to prevent this? If not, it would be great if you could add AllowOnlyOneInstance to the CLI options, or better yet, make it default to 1. Thanks |
#217 | Link | |
'1' is the default.
#219 | Link |
Well, I can't reproduce it. If I change the value to '0' it stays that way after running AVSMeter.
#220 | Link |
The problem is it happens randomly. It can be fine for a few days and then suddenly its back to the default.
By reading the docs this should happen if AVSmeter doesn't find the INI file. Maybe some OS issue prevents it occasionally from reading the INI. Is there a reason why the default value of AllowOnlyOneInstance is 1? |
| Display Modes | |
