Old 3rd February 2017, 19:18   #1  |  Link
itsnotme
Looking for a GPU rendering image viewer upscaling
Hey, not sure if it's appropriate to be asked in this sub-category, but is there an image viewer that uses gpu rendering similar to Madvr? I searched online but I could could only find image resizers. If there aren't any, what is a very good image resizer then (doesn't have to be free)?
Thanks
itsnotme is offline   Reply With Quote
Old 3rd February 2017, 19:48   #2  |  Link
Asmodian
MPC-HC can open images and send them to madVR. LAV can open pngs, jpgs, etc.
madVR options explained
Old 4th February 2017, 00:19   #3  |  Link
itsnotme
Thank you and it works, but I can't zoom in or scroll through the pictures. Anything else I can try?
Old 4th February 2017, 03:57   #4  |  Link
JohnLai
http://www.fastpictureviewer.com/
But it is freemium product.....and has limited format support for non-professional......
Then we got hardware accelerated image viewer --> Not sure what kind of algorithm being used for upscale/downscale by programs below:
http://www.pictomio.com/Default.aspx
http://www.softpedia.com/get/Multime...dernView.shtml
https://www.digikam.org/
Back in the day, I even use https://sourceforge.net/projects/bubblesreader/ or https://sourceforge.net/projects/glmangareader/ for reading comics/manga.
JohnLai is offline   Reply With Quote
Old 10th February 2017, 13:28   #5  |  Link
amayra
Quality Checker
amayra's Avatar
i dont think there app out there like that all devs i prefer performance more than quality
ps: i looking for app like that for 2 year lol i even ask Zachs for make MediaPlayer.NET image viewer mod
I love Doom9
amayra is offline   Reply With Quote
Old 11th February 2017, 06:28   #6  |  Link
romulous
Zoom Player can show images using DirectShow - madVR if you have it set as the video renderer. You just need to disable Adv Options > Playback > Use internal JPEG / BMP / PNG image decoder (supports higher resolution images) first. It also supports zooming in and out, and moving through lists of files.
romulous is offline   Reply With Quote
Old 18th February 2017, 09:11   #7  |  Link
Zachs
Suptitle, MediaPlayer.NET
It's actually not that much to make mpdn into an image viewer. All the code is there just need to have a different user interface. Just haven't got a lot of time these days.
Zachs is offline   Reply With Quote
Old 18th February 2017, 10:31   #8  |  Link
Przemek_Sperling
PencilSheep https://www.pencilsheep.com/ uses GPU rather than CPU for almost every operation.
Przemek_Sperling is offline   Reply With Quote
Old 20th February 2017, 10:38   #9  |  Link
amayra
Quality Checker
amayra's Avatar
i think is more about use SuperRes , NNEDI3 and Pixel Shader ..... ect
that is why MPDN is better for this job
I love Doom9
Old 6th March 2017, 17:02   #10  |  Link
amayra
Quality Checker
amayra's Avatar
well you make to your to-do-list ?
I love Doom9
Old 7th March 2017, 11:41   #11  |  Link
Zachs
Lol. As much as i know it is exciting from user's perspective, it's not really that exciting for the devs. Just grunt work mainly to create a new user interface for picture viewing.
Old 8th March 2017, 01:27   #12  |  Link
amayra
Quality Checker
amayra's Avatar
so there no hope for us ?
i would like to have decent manga viewer
I love Doom9
Old 8th March 2017, 14:21   #13  |  Link
Shiandow
I wouldn't call it hopeless, all the pieces are there, there's just been nobody who wanted to put them all together.
image resizer, image viewer
