#1 | Link |
Murali
Nvidia Cuda video decoder- Purpose of CUVIDMPEG4PICPARAMS and CUVIDH264PICPARAMS
When I am going through the NVIDIA Cuda decoder, the cuvidDecodePicture returns a pointer to CUVIDPICPARAMS. However the CUVIDPICPARAMS contains a union which holds two separate variables for CUVIDMPEG4PICPARAMS and CUVIDH264PICPARAMS.
When decoding H.264(AVC) video which structure should I use for the post processing? |
#2 | Link |
-.-...........Isn't CUVIDMPEG4PICPARAMS refer to MPEG4 ASP (Advanced Simple Profile)?
I believe that is your answer...... EDIT: MPEG4-ASP---> Ah....the previous era of XVID and Divx......before H264 becomes dominant.... EDIT2: Yeah, I saw you asking at many different forums....Just doesn't bother to reply....seeing you so persistent in getting answer.... EDIT3: What...you don't believe me? You ought to read the documentation once in a while.....
#3 | Link |
Murali
Thank you very much for your reply JohnLai. I have the same thought as well. I keep posting the same question in different forums for clarification. I didn't find any answer except yours.
I need to calculate the quantization value for each picture. In ffmpeg this value was calculated using on qscale of each pixel in a macro block. I want to know how can I implement the same using NVCUVID API. Please help me in this regard. Thanks in advance. Murali Krishna |
#4 | Link | |
https://trac.ffmpeg.org/wiki/Encode/MPEG-4 qscale only works with older generation of codec. https://trac.ffmpeg.org/ticket/3238 According to ticket here....qscale doesn't work with libx264 https://ffmpeg.zeranoe.com/forum/viewtopic.php?t=1203 Next, -qp (Constant Quantization Parameter) roughly analogous of mpeg4's -qscale for x264. These days, we mostly use CRF (Constant rate factor) instead of CQP with libx264. So.....based on your red question....are you trying to find out libx264 CRF average QP for I, P and B frame respectively so that you can map it to nvenc QP IPB? On your blue question, in conjunction with red question, are you trying to ask if one can use "Variable Bit Rate with qscale"? |
#5 | Link |
Murali
Hello John,
Sorry I am not talking about the command line option of qscale in ffmpeg. Please refer the below link about the H264Context Struct Reference. https://www.ffmpeg.org/doxygen/2.4/s...64Context.html This structure has a variable qscale and below link is about Picture Structure which has qscale_table. https://www.ffmpeg.org/doxygen/3.1/structPicture.html These variables were filled while decoding each pixel of a macro block (in fill_filter_caches method of h264.c ) |
#6 | Link |
Nope, you can't do that with CUVID, it is too abstracted.
You want something like these: Macroblock 121 (16x16) slice 0 slice structure Frame bits total 2 bits prediction 2 bits residuals 0 QP 7 skip_flag 1 Macroblock 13 (208x0) slice 0 slice structure Frame bits total 29 bits prediction 29 bits residuals 0 QP 12 skip_flag 0 Sub macroblock 3 Macroblock 249 (144x32) slice 0 slice structure Frame bits total 122 bits prediction 23 bits residuals 99 QP 6 skip_flag 0 Too bad you can't get those macroblock info using CUVID. In ffmpeg software decoding, AVParser (the qscale) is used. But in CUVID case, CUVIDPARSER is used, the problem is I don't think CUVIDPARSER doesn't have such functionality to 'extract' such info on the fly. _CUVIDPARSERPARAMS CUVIDEOFORMATEX *pExtVideoInfo; /**< [Optional] sequence header data from system layer */ * Video Signal Description */ struct { unsigned char video_format : 3; unsigned char video_full_range_flag : 1; unsigned char reserved_zero_bits : 4; unsigned char color_primaries; unsigned char transfer_characteristics; unsigned char matrix_coefficients; } video_signal_description; unsigned int seqhdr_data_length; /**< Additional bytes following (CUVIDEOFORMATEX) */ } CUVIDEOFORMAT; /*! * \struct CUVIDEOFORMATEX * Video format including raw sequence header information */ typedef struct { CUVIDEOFORMAT format; unsigned char raw_seqhdr_data[1024]; } CUVIDEOFORMATEX; Maybe you could extract all sequence header data instead and see if it contain QP data as per SDK info above? Last edited by JohnLai; 31st October 2016 at 12:57. |
| Tags |
| ffmpegsource, h264 decoder |
| Display Modes | |
