#1 | Link |
DVB Dream - Windows TV Software for Digital-TV (DVB/ISDB/ATSC) cards & devices
DVB Dream - Windows TV Application
DVB Dream is DVB player with many nice and unique features (more below), it supports standards DVB-S, DVB-C, DVB-T, ATSC, ISDB-S, ISDB-T (more below). Features: - Multi PIP (19+1, watch a few channels at the same time) - Multi recording (record more than 1 channel at the same time) - UHD(4K)/HD/HEVC/H264 support - Timeshift - LAN Streaming - VLC or MPC Integration - Auto-zap - Unique channel list system (grouping/ordering by several flexible options) - Favorite channels - Quick Favorites - Child lock - Embedded aspect ratio modes - Cropping / Zoom - Sleep timer - Record timer - EPG - OSD - Scheduler - Render-less mode - Internal graph building - Multi monitor support - Command line support - Network Scan - Raw Diseqc commands support - Plugins support - Preffered languages - Uncommitted switches support - Unicable support - Positioner support(including GotoX.X / USALS) - Snapshot feature - Keyboard shortcuts - Remote control support - Themes - 29 languages support EPG Plus Module : TV Guide ![]() Latest Version / What is new: v2.7 (06.06.2015) Added ATSC support for BDA devices (experimental, please report on forum if you still cannot get DD to work with ATSC) Added support for TBS 6205 DVB-T/T2 DVB-C, TBS 6001 DVB-S/S2, TBS 6905 New feature: Codec Downloader Some fixes for AAC (LATM/LOAS & ADTS streams are handled differently now, and HE-AAC should work well) Resolution, chroma and Progressive/Interlaced/MBAFF type info is now displayed for all MPEG2, H264(AVC), H265(HEVC) channels Video bitrate is now calculated on the fly (displayed on status bar) Some TS record related problems have been fixed Fixed some LAN streaming deadlock problems Fixed aspect ratio problems with MadVR (please make sure you install the latest version of MadVR) * New theme: Win10 by Bader * You can use Microsoft codecs or LAV filters for AAC audio * Please contact us about problems on forum, we are ready to help & work together to fix things. * This version might change your codec configuration after installing, please re-configure afterwards as you wish. Depending on the codecs you use, you might need to disable/enable "Reset DS after ch-change" option in video options to make channel changes problem-free/fast. If you are a Windows 7 user, please use we recommend Microsoft codecs instead of LAV codecs. v2.7.1 (12.06.2015) FIXED: Lost channels were not getting displayed after scan FIXED: DVB-T support was broken by ATSC changes CA System (crypto type) filter option for channel list (CTRL + L) * When you need to find the channels which you can decrypt by using your subscription card/plugins etc, you might simply open up channel list options (CTRL + L) and select the CA System your system/plugins can decode. For example, pick "All" (All satellites) on the top of channel list, then pick "PowerVU" from the CA list combobox to find / list all PowerVU channels on your scanned satellites * We provide free life-time DVB Dream full version licenses/serial keys for programmers who develop MDAPI plugin, DD Module, DD device interface for them to test their add-ons on DD freely. Please contact us on forum. We are ready to support your ideas & work. New add-on API functions can be implemented if necessary. www.dvbdream.org Older DVB Dream thread: http://forum.doom9.org/showthread.php?t=113377 Last edited by rel; 15th June 2015 at 17:16. |
#2 | Link | |
I have been using DVBDream quite a bit when it still was freeware. A few rough edges, but very usable.
When they decided to make DVBDream payware I looked for alternatives. There are some good free alternatives (ProgDVB, SmartDVB), but I finally decided to buy DVBViewer, and I never looked back. When it comes to features, stability and support, DVBViewer leaves DVBDream in the dust. The price for DVBDream is ridiculously high (49 USD) compared to DVBViewer (20 EUR after a recent increase). What bugs me most about DVBDream is their attitude toward paying customers. The following quote is from their forum rules: Quote:
Cheers manolito Last edited by manolito; 19th June 2015 at 17:50. |
#3 | Link | |
Software Developer
![]() Join Date: Jun 2005
And don't let yourself be fooled by the "special" edition of DVBViewer that's included with some TV cards. I got this too with my TV card and it was completely unusable. Not only was the interface clunky like hell, also the video simply didn't play smooth. And because there were no options available at all in the "special" edition, nothing could be done about this. The "full" version is totally different and works flawlessly for me. And they finally added MadVR support recently
#5 | Link |
DVDViewer has a impressive feature set and maturity no doubt, still it lacks IMO the single most important feature which is error free MP4 recording.
#6 | Link |
Then are you aware of any other capturing software which offers this?
Whenever you capture TV broadcasts (no matter if it is DVB-S/S2 or DVB-T) there will be some transmission glitches eventually. Nothing you can do about it. Transmitting the streams as Transport Streams (as opposed to Program Streams) makes sure the the receiver will not go out of sync after such glitches, but the glitches are still there. For MPEG2 Transport Streams the workflow to treat these TS captures has always been to convert them to Program Streams first (ProjectX, PVAStrumento, Womble and probably some other tools). For HD captures (AVC, soon to come HEVC) the only tool I am aware of which can fix the captured files to a certain degree is TSDoctor. Maybe someone can develop a HD capture software which incorporates the routines which TSDoctor uses, but so far I have not seen any effort into this direction. And there is the basic question if it is possible at all to correct broadcasting glitches in realtime on the fly. I have my doubts... Cheers manolito Last edited by manolito; 26th June 2015 at 07:12. |
#7 | Link |
it's possible I guess, apparently TS is difficult
| Display Modes | |
