Old 28th May 2013, 10:39   #21  |  Link
Bernardd
Be aware though that FrameSelect selects all frames in the order specified ie 10,20,30,20,10 (line separated in file) would select 5 frames
whereas I think ConditionalReader only 3. When Reject=True, will select all frames NOT Specified, but in sequential order. Reject mode
was implemented purely for the Security Camera Movement Extraction thing, just to see what was being left out.
Maybe I'll add option to do as CR.
Old 28th May 2013, 13:23   #22  |  Link
Post #16 updated added Comment pass through.
Old 28th May 2013, 18:32   #23  |  Link
Bernardd
StainlessS,
Post #16 updated script with added Comment pass through is ok on my computer.
I do not see a big interest for the frame select in a unsequential order. Perhaps to make effect, like loop. Why not ?
With your last script, it is possible to use AvsPmod and his macro to have a GUI to make a human visual frame selection. It is nice.
But for me the FrameSelect plugin big interest is to associate process with one automatic frame select action. With your explanation on Reject Mode, i understand you intend to make Security Camera Movement Extraction.
Me, i see FrameSelect plugin with Reject Mode like a new Decimate tool, perhaps because i know write a script to list dupplicated frames with WriteFileIf Avisynth function.
Probably other people will see other uses.
Thus your plugin is efficient and open use. It is perfect like this.
Thanks
Bernardd is offline   Reply With Quote
Old 28th May 2013, 20:25   #24  |  Link
I'm modifying FrameSelect right now to do an optional ordered selection, yes maybe better for GUI use.
It was however a deliberate decision to select all frames and in the order given, that will remain the default mode.
As for the Security Camera Movement Extraction thing, it's included together with RT_Stats v1.17, see here:
http://forum.doom9.org/showthread.ph...75#post1628675
EDIT: And ordered FrameReplace, which maybe should always be used if intention is to replace (or select order should
be automated to be sequential with no duplicates).
Old 29th May 2013, 17:36   #25  |  Link
I've pretty much implemented the ordered mode for FrameSelect/Replace, but spent many times longer
trying to figure out what rules to apply. Have come to conclusion that is better to abandon FrameSelect/Replace
as is and leave on-line for maybe 1 month longer.
New Version will be called something like FrameSel/FrameRep, starting at version v2.0 and being the more restricted
ordered mode by default. FrameRep will I think have to use ordered mode ALWAYS and so frame selection destined
to be replaced, should always be called with default ordered=True.
In hindsight more restrictive ordered mode should have been default from the start, with non-ordered being an option,
in order not to break any scripts it is necessary to rename the plugin. All scripts that I've posted on D9 should still work by simply
renaming FrameSelect to FrameSel and FrameReplace to FrameRep.
There will be no further development of FrameSelect, unless someone flags a bug.
A new thread will be created for the new plugin.
EDIT: New thread here:
http://forum.doom9.org/showthread.php?t=167971
Old 8th June 2013, 11:46   #26  |  Link
LigH
LigH's Avatar
Oh, it is developing in the meantime...
Big thanks from the original requester, fapalo. He mentioned having taken single photos (possibly for a kind of time-lapse video) with unequal time gaps, more than 1000.
New German Gleitz board
Old 8th June 2013, 13:25   #27  |  Link
Yep, I saw the Google translation of fapalo's post.
edit, frames, join, select, trim
