Old 22nd June 2011, 04:54   #1  |  Link
MaiTiano
MaiTiano's Avatar
Is there a video player which can display the bitrates?
Just like the title of this thread.
I am trying to find such a video player which can display the video bitrates and passing frame no during video playing-back.
Can anyone tell me is there such a video player?
Many thanks.
MaiTiano is offline   Reply With Quote
Old 22nd June 2011, 06:24   #2  |  Link
jasonme
I suppose you are referring to bit-rate of each frame right? In this case, I doubt there are video players doing it. Although you can try Corel WinDVD to show video information which have real-time bit-rate information, but it doesn't show frame number. If you just need to know the bit-rate of the whole video, then most player should do.
On the other hand, I think a stream analyzer might fit better to your requirement, namely Elecard Stream Eye, it will have a frame number and bit-rate for each frame showing (well, along with all other bit-stream related information...)
jasonme is offline   Reply With Quote
Old 22nd June 2011, 07:43   #3  |  Link
Ghitulescu
Ghitulescu's Avatar
The bitrate is not correlated with the frame other than both refer to a reference time/duration. In other words, one can find out how many bits are needed to encode a particular frame and divide it by the duration of that frame (40ms in PAL/25p). On the other hand, the bitrate most if not all players show is usually correlated with the incoming/displayed video or total data per unit of time (second). I can't speak for all standards, but no standard I know uses or imposes a bitrate per frame.
Born in the USB (not USA)
Old 22nd June 2011, 09:57   #4  |  Link
J_Darnley
J_Darnley's Avatar
Try Media Player Classic and Haali's Renderer. Press Alt Gr + O
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 23rd June 2011, 11:04   #5  |  Link
2Bdecided
Also VLC will update the stream properties window in real time as it plays. I think the results may be cumulative though, rather than instantaneous.
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 23rd June 2011, 16:02   #6  |  Link
hello_hello
If you use ffdshow to decode the video (I generally use MPC-HC to display it) and enable ffdshow's On Screen Display filter, you can choose to display input bitrate, frame number, frame duration... and a whole bunch of other stuff.
bitrates, video player
