Old 12th January 2026, 11:00   #25441  |  Link
nevcairiel
LAV Filters 0.81
LAV Splitter
- NEW: Support for APV (Advanced Professional Video) video streams
- Fixed: VVC in MP4 without CTTS did not play properly
- Fixed: AV1 streams with invalid metadata did not get handled correctly
LAV Video
- NEW: Support for decoding APV (Advanced Professional Video)
- Changed: Re-designed pixel format mapping to be based on a heuristic rather then hard-coded, improving support for rarely-used formats
- Fixed: Deinterlacing of 4:2:2 videos was broken in 0.80
LAV Audio
- Fixed: Bitstreaming TrueHD from Blu-rays with seamless branching could result in out-of-sync audio, or a noticeable gap
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Finally getting another long-standing TrueHD bitstreaming issue resolved. Otherwise the usual, FFmpeg updates and tackling anything that was immediately actionable and reported.
As always, please report issues, especially regressions, in as much detail as possible, and with a sample file.
Old 12th January 2026, 13:05   #25442  |  Link
Thankyou kind sir.
Old 12th January 2026, 23:55   #25443  |  Link
clsid
Some crash fixes:
https://github.com/clsid2/LAVFilters...519a249104d25f
https://github.com/clsid2/LAVFilters...d38b0c42f82818
https://github.com/clsid2/LAVFilters...95069d86e9e9ca
These can happen when accessing tray icon during loading.
And in libavutil\tx.c
https://drdump.com/Problem.aspx?ProblemID=1016430
Disabling those blocks under CONFIG_SMALL‎ fixes it. Seems like unnecessary debug/trace code for release builds.
MPC-HC 2.6.1
Old 13th January 2026, 13:45   #25444  |  Link
manolito
manolito's Avatar
Hi clsid,
interesting bug report, but frankly as a non-dev I do not really know what to do with it...
I am unable to compile my own version of LAV Filters, so I probably need to wait for nevcairiel to publish a fixed version. But anyways, thanks a lot for your findings...
Cheers
manolito
Old 19th January 2026, 15:36   #25445  |  Link
manolito
manolito's Avatar
@clsid
Sorry for my ignorance about Github...
On the first page of this thread I found a link to "nightly test version", and the last commit is this one:
LAVFilters-0.81.0-3.exe
Am I correct that this is your commit? Anyways, I installed it, and all my taskbar problems (disappearing icons) were gone. I would never have guessed that, because I thought that as long as LAV Filters is not used by some software that it would not affect the Taskbar. Now I know better, and this commit made my life a lot easier.
A big Thank You
Cheers
manolito
Old 19th January 2026, 18:08   #25446  |  Link
clsid
No whatever problem you had is unrelated to LAV Filters.
MPC-HC 2.6.1
Old 19th January 2026, 18:13   #25447  |  Link
clsid
@nevcairiel
DVD hardware decoding is broken.
https://drdump.com/Problem.aspx?ProblemID=1011044
Time to finally remove this option? It isn't enabled by default. Any hardware from the past 15 years can decode DVD resolution video without breaking a sweat.
Maybe also ditch quicksync as well.
MPC-HC 2.6.1
Old 20th January 2026, 17:24   #25448  |  Link
Sunspark
Quicksync has adaptive hardware decoding of interlaced video.
If the code paths aren't broken why remove it? People say it is old, but it seems to work fine.
Old 20th January 2026, 18:03   #25449  |  Link
Klaus1189
What is "adaptive hardware decoding". Do you mean deinterlacer or indeed decoding?
Old 21st January 2026, 17:12   #25450  |  Link
Sunspark
Both.. it would be used with stuff like television broadcast mostly I imagine, perhaps DVD as well. But, it's not an inverse telecine so for DVD I haven't been using it. I did test the functionality though with a TV clip, and it does deinterlace using hardware (which is awesome when one considers AMD for example pretty much has completely broken deinterlacing functionality).
I use quicksync to this day because I always felt there was something "different" about how colour or motion looked with dxva2-cb. I also use overlay output since I have it. I was told that it's not very likely there's a difference but I am unable to capture it in a screenshot. I just remember a long time ago there was a pipeline graph that shows quicksync processes colour at a different stage of the pipeline than dxva2-cb, so it's not impossible that there is a subtle difference.
I looked it up, quicksync talks directly to the intel video firmware while dxva2 goes through the windows driver stack. I also observe that Intel has a new SDK (OneVPL) which continues to use quicksync and ffmpeg is supporting both the old and new.. so..
I get simplicity, but the decoder isn't something like an old forked version of ffmpeg 2.0. It's just the interaction with the firmware as I understand it.
Old 21st January 2026, 23:20   #25451  |  Link
clsid
The Intel driver applies some processing filters when using DXVA2. You can disable that in driver settings.
MPC-HC 2.6.1
Old 24th January 2026, 18:04   #25452  |  Link
clsid
Got a bug report where a Matroska file contained more than 64 tracks.
So I tried increasing MAX_TRACKS to 80. But things got unstable and freezes. Even got a process stuck and unable to kill. Are more changes required?
I also noticed that in FFmpeg Matroska encoder, MAX_TRACKS is set to 126.
MPC-HC 2.6.1
Old 24th January 2026, 23:37   #25453  |  Link
nevcairiel
Matroska files in LAV Splitter are limited to 64 tracks. Changing that would require quite some work.
Old 26th January 2026, 11:40   #25454  |  Link
arapaz
3d Full SBS to madvr framepack
I have a 3d video in a .mkv with a full side-by-side image (3840 x 1980)
The mkv has flags for multi view count and layout.
When played with MPC-BE/LAV/MadVR (3d set to auto), the output is not framepacked sent to the TV, it is the original image.
Is it possible that LAV split the image in 2 views and send that to MadVR as 3d ?
Thnaks
arapaz is offline   Reply With Quote
Old 7th February 2026, 11:47   #25455  |  Link
josey_wells
Bitstreaming startup hang
First, let me say that LAV Filters is a fantastic product, and I have been utilizing it for more than a decade.
With my current configuration of Pot Player, MadVR, LAV Filters, and HDMI receiver, any version of LAV filters above V0.80.0-7 Beta with audio bitstreaming enabled hangs on startup. If bitstreaming is disabled then no hang occurs.
To rule out all other causes, I have used other players such as MPC-BE & MPC-HC, other renderers such as EVR, and other HDMI receivers.
It would be appreciated if this could be looked at.
josey_wells is offline   Reply With Quote
