Old 26th February 2011, 18:03   #161  |  Link
dansus
Im struggling to work out the parms required to force SAR 1:1 in --Video-Filter;
--video-filter crop:2,2,2,2/resize:1280,720,method=lanczos/? (source 4:3 anamorphic, want 16:9 1:1 ouput)
Edit: Coffee's kicked in, worked it out;
--video-filter crop:2,2,2,2/resize:1280,720,1:1,method=lanczos
Still struggling with correct fps output, source is 29.970 after deinterlace and its spitting out 59.940.
ffms [info]: 1440x1080i 0:1 @ 60030/1001 fps (vfr)
dansus is offline   Reply With Quote
Old 26th February 2011, 21:39   #162  |  Link
sneaker_ger
--no-interlaced --fps 30000/1001
Old 26th February 2011, 21:47   #163  |  Link
sneaker_ger
btw.:
Why isn't "--no-interlaced" documented in fullhelp?
And why is everything from "--no-i" to "--no-interlaced" accepted?
Old 26th February 2011, 21:57   #164  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
getopt
Old 26th February 2011, 22:23   #165  |  Link
sneaker_ger
I see.
Old 26th February 2011, 22:25   #166  |  Link
dansus
That seems to have worked, except playback is in slow motion now..
Old 26th February 2011, 22:40   #167  |  Link
sneaker_ger
Then your source is not 29.970.
Old 26th February 2011, 22:48   #168  |  Link
dansus
Media Info says;
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=56
Codec ID : 27
Duration : 1mn 11s
Bit rate mode : Variable
Bit rate : 8 593 Kbps
Maximum bit rate : 20.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Old 26th February 2011, 22:52   #169  |  Link
sneaker_ger
Did you perhaps use bobbing (e.g. yadif mode 1) or mistyped "30000/1001"?
Upload a sample otherwise.
Old 26th February 2011, 23:08   #170  |  Link
dansus
Seems ok, using ffms in x264.exe
x264.exe --preset slow --crf 21.5 --level 4.1 --video-filter crop:2,2,2,2/resize:1280,720,1:1,method=lanczos --no-interlaced --fps 30000/1001 --output "C:\Output.mkv" --demuxer ffms --index "C:\x264-index" "C:\testhd.ts"
Sample - http://www.mediafire.com/?5j9x0az19sx00eq
Old 26th February 2011, 23:45   #171  |  Link
dansus
Doesnt like PAL MBAFF either (BBCHD)
ffms [info]: 1440x1080i 4:3 @ 27679/1001 fps (vfr) ??
Theres some weird effect playback too.
http://www.mediafire.com/imgbnc.php/...0fb0eedf6g.jpg
Old 26th February 2011, 23:55   #172  |  Link
sneaker_ger
Yes, I also had some troubles on your sample.
This command line seems to result in acceptable output:
x264 testhd.ts -o output.mkv --vf yadif:0,bff/select_every:2,0 --fps 60000/1001
I didn't manage to bob and I don't know what I'm doing wrong.
Old 27th February 2011, 00:06   #173  |  Link
dansus
So your saying you couldnt get the right output with ffms?
Old 27th February 2011, 00:08   #174  |  Link
sneaker_ger
Test my command line, it looks fine, but I did not manage to bob.
Old 27th February 2011, 00:18   #175  |  Link
dansus
Cant seem to get that code to run, crashes after index. Im sure its just me being a noob..
Old 27th February 2011, 00:20   #176  |  Link
sneaker_ger
I'm using this build.
Old 27th February 2011, 00:31   #177  |  Link
dansus
Is that a x64 build? Yep, rename link to 1913_32 if you need x86 version.
Old 27th February 2011, 00:41   #178  |  Link
dansus
That did the trick. Thanks.
What would be the best parms for PAL i50 content, --vf yadif:0,tff --fps 25/1 ?
Wasnt aware Yadif had been built in to x264, need to look into this more, see what other goodies lie within.
http://www.mediafire.com/?kehnkpejkcmluk9
Old 27th February 2011, 02:22   #179  |  Link
sneaker_ger
Good question, theoretically "--vf yadif --fps 25" should work, but since it screws up on your sample it either means the capture is corrupted or ffms is too buggy to handle it. Search around the forum for BBC and you might find some tips as you are not the only one that has problem with it.
beta, ffmpegsource, libavformat, test, x264
