#21 | Link |
i dit everyting you say Capsbackup but its the same
![]() WIN7 Preferred MPEG2 CODEC: not set correctly? Are there a codec missing? I.dont now. And everethime i start bd rebuilder i get the message windows not configred with ffdshow. So i let BD rebuilder do it for me and answer with yes. Get then message windows 7 system has been successfully configured to use ffshow with rebuilder , can uyou explain why above the message : WIN7 Preferred MPEG2 CODEC: not set correctly? When i run Inspect? it is not necessary that well to put? Are it not regards bokker Last edited by bokker; 14th January 2011 at 20:47. |
#22 | Link |
![]() Join Date: Oct 2001
It means that even though you have FFDSHOW installed, it is not the preferred codec and some other one might be used.
Since the others are set correctly, some other program had to have changed it. Probably something you've installed recently. Right click on the file FF_RESET.BAT in your BD-RB folder and say "Run as Administrator". This will set the values back to their original state. Then right click on BD_Rebuilder.exe and say "Run as Administrator". It will then see that they need to be set and will do it correctly again. Make sure you say "Yes" when it asks you if it's ok to change them.
jdobbs.softworks@gmail.com |
#24 | Link |
If it doesn't exist -- that means they were never set in the first place by BD-RB (because it saves the original values to that file before changing them).
The FFDSHOW settings aren't the issue. It's the Windows 7 preference settings. If they point elsewhere, FFDSHOW is simply ignored. If you don't mind editing your registry yourself, you can put the line below into a .BAT file and run it as administrator. Remember, though, that editing the registry can sometimes be risky, and you are doing so at your own risk: reg add HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {e06d8026-db46-11cf-b4d1-00805f6cbbea} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f
#25 | Link | |
to the lower part of the drawing black line the number starts the same such as those I of you have. But those already in to register stood> This key already there {e06d8026-db46-11cf-b4d1-00805f6cbbea} / {212690FB-83E5-4526-8FD7-74478B7939CD} i let it be I dit the same you say here i make it in the register HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {e06d8026-db46-11cf-b4d1-00805f6cbbea} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} ![]() And than i restar my computer and install all the progammas, I do Haali, FFDSHOW and Avisynth 2.57 i nothing chance this progams just install. And at last right click on BD_Rebuilder.EXE and select "Run as Administrator" . And when i take inspector i see again WIN7 Preferred MPEG2 CODEC: not set correctly? When y als o run "REG_MSCOMCTL.BAT" and select run it as administrator." nothing happend al the same message,, WIN7 Preferred MPEG2 CODEC: not set correctly? Only thing i see when i run BD rebuilder are a file BDREBUILDER configuratie.[Options] VERSION=0.37.0.1 MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 I let that so it is. Sorry but i try What do i do wrong? Last edited by bokker; 15th January 2011 at 17:16. |
#26 | Link |
Perhaps you don't have administrator privileges? Try logging in as admin and try again.
If you know how to use the registry editor, just manually change the value for {e06d8026-db46-11cf-b4d1-00805f6cbbea}" to "{04FE9017-F873-410E-871E-AB91661A4EF7}" under HKLM\SOFTWARE\Microsoft\DirectShow\Preferred.
#27 | Link | |
Ther are two Value name one the one i make: reg add HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {e06d8026-db46-11cf-b4d1-00805f6cbbea} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f And one whois already there. {e06d8026-db46-11cf-b4d1-00805f6cbbea} {212690FB-83E5-4526-8FD7-74478B7939CD} And must i change after REG_SZ ? sorry |
#28 | Link |
If it was already there the command line would have changed the existing one.
There can only be one. If you look closely you'll see that the others are slightly different: {e06d8026-db46-11cf-b4d1-00805f6cbbea} - This is the one you change {e06d802b-db46-11cf-b4d1-00805f6cbbea} {e06d8032-db46-11cf-b4d1-00805f6cbbea} You double click on the value and paste in the new one and say "Okay". Remember, though, you are editing your registry at your own risk... you have to be very careful not to change the wrong things.
jdobbs.softworks@gmail.com Last edited by jdobbs; 15th January 2011 at 18:18. |
#29 | Link |
i change this value {e06d8026-db46-11cf-b4d1-00805f6cbbea} {212690FB-83E5-4526-8FD7-74478B7939CD}
in to this value {e06d8026-db46-11cf-b4d1-00805f6cbbea} {04FE9017-F873-410E-871E-AB91661A4EF7} I install al again but stil i can see FF_RESET.BAT and stil the message to see with inspector WIN7 preferred MPEG2 CODEC: Not Set correctly Shut i give up jdobbs ???I thank you verry mutch till now
#30 | Link |
You will never see FF_RESET now. That only get's created when BD-RB sets all those values the first time it is run. You're doing it by hand.
Now that you've changed it, run INSPECT.EXE and you should see "Ok" for preferred MPEG-2 codec.
#32 | Link |
Need Help on correcting setting
I'm sure this question has been addressed many,many times. And if I was not having to be the sole caretaker of my 2yr grandson 24/7, I'd have the time to read all the threads and posts. But I'm lucky just to have a few minutes alone. If anyone can help with this one issue, I would owe big-time: running win 7 ultimate 32 bit, all bd software up to date Only getting one error when I run "inspect", as follows " WIN7 preferred VC-1 CODEC: Not Set correctly" Where, and how do I set correctly? Driving me nuts, As I said, time is not on my side to research Thanks in advance Steve |
#33 | Link |
1. Click on the Windows START button.
2. Click on "All Programs" 3. Scroll down to FFDSHOW and click 4. Select "Video Decoder Configuration" 5. Under "Codecs" (on the left), find VC-1 and select "wmv9" 6. Click on OK.
#35 | Link |
Uninstall ffdshow, reboot. Delete BDREBUILDER configuration settings file in BD-RB folder.
Reinstall ffdshow, the one recommended from 1st page of this thread. Then: There is a .BAT file called "REG_MSCOMCTL.BAT" -- simply right click on it and select "Run as Administrator". Then right click on BD_Rebuilder.exe and select Run as Administrator. |
#36 | Link |
Did as asked
Followed directions of last post, now I get the following messages
As attachments, don't know how to insert into post Wrong order, Inspect dshow After I click "yes", I then get this message, bd rebuild all gif Last edited by sbtuttle; 2nd March 2011 at 15:32. Reason: to add: Thanks in advance |
#37 | Link |
Uninstall any codec packs you installed. Any recent programs you installed? that may have installed video playback codecs?
Uninstall haali, avisynth and ffdshow. Delete the program folder for haali. Reboot. Reinstall those three programs from page one and try again, following the instructions from page one.
#38 | Link |
Have done all twice, still no joy
uninstalled all of the supporting programs, uninstalled re-builder,
rebooted reinstalled in order listed, and only set the defaults, with exception to those mentioned in install post. have not installed codec packs or playback software It has to be a simple setting in ffdshow - just don't know which one messages I know get will be attached Thanks to all, I am very grateful for all the help Steve |
#39 | Link |
Some other program has to be changing that setting. When BD-RB tells you everything has been set correctly it is reading the exact same registry entry as INSPECT.
Make sure you right click and run as administrator the first time you run BD Rebuilder -- but I don't think that's it, since everything else seems to be set correctly.
#40 | Link |
Hello, list of loaded vid programs
Ran both the config and bd-rebuilder everytime as admin Following is a list of all video related programs (can't remember if Auto GK is listed, but it's loaded, also have Anyhd, but it's not on if I use DVDfab |
| Display Modes | |
