Old 17th December 2025, 09:20   #32281  |  Link
FreaQ
Starfish
FreaQ's Avatar
I am using BD-Rebuilder with x264 CRF encoding, which works great for me.
But I would like to change the default settings of no-fast-pskip, aq-mode, aq-strength, subme, me & deblock
Is there a way to do this? I did not see anything in the HIDDENOPTS.txt
FreaQ is offline   Reply With Quote
Old 17th December 2025, 09:53   #32282  |  Link
Lathe
Lathe's Avatar
I don't know about those particular commands, but you can add x264 'Tweaks' to the configuration file like I have for some encodes:
TWEAK_PASS_TWO=--ref 4 --deblock -2:-2 --psy-rd 1.00:0.25 --me hex --subme 6
I hope that helps...
Lathe is offline   Reply With Quote
Old 17th December 2025, 10:14   #32283  |  Link
FreaQ
Starfish
FreaQ's Avatar
Thanks. But it looks like the command is for two pass encodes only. I do one pass crf.
In the hiddenopts are following tweaks
TWEAK_PASS_ONE
TWEAK_PASS_TWO
TWEAK_ALTERNATE
TWEAK_ALTERNATE_NV
TWEAK_X265
But none for one pass encoding or x264 only
Old 17th December 2025, 14:47   #32284  |  Link
jdobbs
TWEAK_PASS_ONE
TWEAK_PASS_TWO
TWEAK_ALTERNATE
TWEAK_ALTERNATE_NV
TWEAK_X265
I admit it sounds a little counterintuitive... but if you do a single pass encode, the values in TWEAK_PASS_TWO are used. I probably should have called it "TWEAK_FINAL_PASS" or something similar -- but it is what it is. You should also know that there are some parameters that BD-RB will filter out (such as settings that would cause the encode to be non-compliant).
jdobbs.softworks@gmail.com
Old 17th December 2025, 16:24   #32285  |  Link
FreaQ
Starfish
FreaQ's Avatar
Yes, that's not intuitive at all, but I appreciate the clarification.
Thanks
Also I happened to stumble over the blanking extras feature which is not explained in the hiddenopts.txt. Nevertheless I found the options in this thread. But you should add those to the txt
Old 17th December 2025, 19:00   #32286  |  Link
FreaQ
Starfish
FreaQ's Avatar
CRF with custom options works. Thanks.
But when I add a job to the queue BDRB uses default two pass encoding instead of the selected CRF encoding which is unfortunate because I want to run the jobs overnight.
Old 17th December 2025, 19:57   #32287  |  Link
jdobbs
It uses the settings that are current at the point you add the job to the queue.
Old 17th December 2025, 20:03   #32288  |  Link
FreaQ
Starfish
FreaQ's Avatar
I assumed that and CRF was set. But it started the two pass anyways. I will try again.
Old 17th December 2025, 20:50   #32289  |  Link
FreaQ
Starfish
FreaQ's Avatar
Nope doesn't work.
Even so I explicitly set it to CRF in the GUI, BDRB startet a two pass encode
[Options]
VERSION=0.62.0.16
ENCODER=0
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=1
AUTO_QUALITY=0
TARGET_SIZE=47366
NVENC_CAPABLE=1
AUDIO_TO_KEEP=deu;eng;ger;
SUBS_TO_KEEP=deu;eng;ger;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=2
AVCHD=1
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
FORCE_ENCODE=1
FIXED_CRF=19
ENABLE_BLANKING=1
ENABLE_TEST=1
TWEAK_PASS_TWO=--no-fast-pskip --aq-mode 3 --aq-strength 0.7 --subme 9 --me umh --deblock -3:-3
MIN_M2TS_SIZE=1
[Paths]
SOURCE_PATH=c:\path\to\iso
WORKING_PATH=c:\path\to\workdir
[Batch]
MAIN_MPLS=00102.MPLS
MAIN_MPLS_ANGLE=0
FORCED_SUB=0
FORCED_AUD=0
AUDIO=1001001100100111111111111111111111
SUBS=110010000000000001100100000000000011001001100100110010011001001100100110010011001001100100110010011001001100100110010011001001100100
BLANKED=0000111111111111111111
[20:42:44] BD Rebuilder v0.62.16
[20:42:44] BEGIN - BATCH SEQUENCE
[20:42:44] PROCESSING BATCH FILE [1]
[12.17.25] BD Rebuilder v0.62.16
[20:42:44] Source:  DISC
  - Input BD size: 37,16 GB
  - Approximate total content: [02:43:10.004]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: High Quality (Default), Two Pass
  - X264 Tweak(s) enabled
  - Decoding/Frame serving: X264/LAVF
[20:42:44] PHASE ONE, Encoding
 - [20:42:44] Processing: VID_00002 (1 of 22)
 - [20:42:44] Extracting A/V streams [VID_00002]
 - [20:43:09] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 75.216 frames
   - Bitrate: 31.174 Kbs
 - [20:43:09] Reencoding: VID_00002, Pass 1 of 2
[20:43:18]PHASE ONE aborted by user request
[20:43:18] BATCH ABORTED...
[20:43:18] END - BATCH SEQUENCE
Old 18th December 2025, 16:03   #32290  |  Link
jdobbs
I just tested it. I set the output to X264 and CRF, and then added two jobs to the queue. They both encoded in a single pass using CRF.
I'm not sure what you may be doing differently.
[Edit] Ok. I just noticed that you are using LAVF as the decoder. If I set the decoder to LAVF I am also getting two passes. It's doing that because you can't enable CRF with LAVF (DECODER=2) in BD-RB (it's been a while and I can't remember why), and it defaults back to two pass. I have comments in my code that say "you can't enable CRF with LAVF". You can set it to single pass with a VBR bitrate and it works in the queue (because it isn't disabled like CRF). If you want to do CRF, just set DECODER=0 in your INI file and CRF will become available again on the ENCODE SETTINGS menu (it becomes disabled when you set DECODER=2 or 4).
[Edit 2] Just remembered why... when using CRF in making a BD you have to perform predictions using samples to make sure that the CRF used will result in a file that will fit on the disc. You can't do that when using X264's internal LAVF to feed the frames for encoding.
Old 18th December 2025, 19:28   #32291  |  Link
FreaQ
Starfish
FreaQ's Avatar
Thanks for the explanation.
Changed the decoder to DGDecNV and it works with CRF in Batch.
Old 23rd December 2025, 12:58   #32292  |  Link
FreaQ
Starfish
FreaQ's Avatar
Another problem when I try to encode a BD with a secondary audio track.
Happens with DECODER=3 and DECODER=0
[12.23.25] BD Rebuilder v0.62.16
[11:41:49] Source:
  - Input BD size: 41,00 GB
  - Approximate total content: [04:34:03.844]
  - Quality: High Quality (Default), CRF
[11:41:51] PHASE ONE, Encoding
 - [11:41:51] Processing: VID_00001 (1 of 14)
 - [11:41:51] Extracting A/V streams [VID_00001]
 - [11:42:49] Reencoding video [VID_00001]
 - [11:42:49] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 116.731 frames
 - [11:47:50] Encoding using constant rate factor.
 - [12:46:19] Video Encode complete
 - [12:46:19] Processing audio tracks
   - Track 4353 (deu): Keeping original audio
   - Track 4356 (eng): Keeping original audio
   - Track 4357 (eng): Keeping original audio
   - Track 6656 (eng): Keeping original audio
 - [12:46:19] Multiplexing M2TS
 - [12:46:36] Processing: VID_00002 (2 of 14)
 - [12:46:36] Extracting A/V streams [VID_00002]
  - TSMUXER ERR: 0xFFFFFFFE
   - Extracting video streams [VID_00002]
   - Extracting secondary video [VID_00002]
   - Extracting audio/subtitle streams [VID_00002]
 - [12:46:53] Reencoding video [VID_00002]
 - [12:46:53] Reencoding secondary video [TRK_02]
   - Rate/Length: 23,976fps, 3.531 frames
 - [12:46:53] Encoding using constant rate factor.
 - [12:48:37] Video Encode complete
 - [12:48:37] Processing audio tracks
 - [12:48:37] Multiplexing M2TS
 - [12:48:42] Processing: VID_00003 (3 of 14)
 - [12:48:42] Extracting A/V streams [VID_00003]
   - Extracting video streams [VID_00003]
   - Extracting secondary video [VID_00003]
   - Extracting audio/subtitle streams [VID_00003]
 - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\VIDEO\BDMV\STREAM\00003.m2ts
   - Extracting audio streams [VID_00003]
 - Error in attempt to extract audio.
 - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\VIDEO\RIPS\BDMV\STREAM\00003.m2ts
[12:49:30] - Failed to retrieve audio, aborted
Old 23rd December 2025, 15:47   #32293  |  Link
jdobbs
That kinda' looks like a source that has issues or is corrupt... but just to see if it makes a difference, add the following to the "[Options]" area of your INI:
ENABLE_NEW_TSMUXER=0
That way it will try the older TSMUXER. You never know...
Old 23rd December 2025, 19:07   #32294  |  Link
FreaQ
Starfish
FreaQ's Avatar
Didn't help. I will try to rerip.
Old 27th December 2025, 17:46   #32295  |  Link
Ch3vr0n
Just had my 1st BD in a long time that would fail to process with Elby's CloneBD, luckily i still remembered this tool and it worked. Found an old backup of a config file. Are any of these no longer in use? Been a long time since i had to use this so there have been lots of things i need to update my knowledge on.
[Options]
VERSION=0.62.0.16
ENCODER=1
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
TARGET_SIZE=23500
AUTO_BURN=2
AUDIO_TO_KEEP=dut;eng;nld;und;
SUBS_TO_KEEP=dut;eng;nld;und;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=0
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
COMPLETION_BEEP=1
OUTPUT_SBS=1
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=4100
#FRIM_SW_DECODE=0
FRIM_SW_ENCODE=1
#SPECIAL_3D_MUX=1
#General Settings
ENABLE_TEST=1
ENABLE_BLANKING=1
BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav
OUTPUT_FOLDER=H:\Blu-ray\Encodes\BDRB\
MINIMIZE_TO_TRAY=1
MOVIEONLY_TYPE=37
ALTCRF=23
ALT_TARGET=8600
ALT_CRF_TARGET=2048
ALTMETHOD=2
ALTAUTOCROP=0
FRIMSOURCE=0
NVENC_CAPABLE=1
[Paths]
SOURCE_PATH=J:\<snip>\
DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\x32 Binaries\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\x32 Binaries\DGDecodeNV.dll
WORKING_PATH=J:\Blu-ray\Encodes\BDRB\
I first grabbed the latest DGDecNV but it doesn't supply 32bit binaries. Is there any way to get BDRB to use the latest or are we "stuck" with 2.51 which is the last one that has 32 bit binaries? Should DGDecNV even be used at all anymore? Is there anything new i need to be made aware of in terms of experimental/improved settings? I wasn't shy of experimental options last time i used it.
Ch3vr0n is offline   Reply With Quote
Old 27th December 2025, 19:49   #32296  |  Link
Columbo
Donor
Doesn't BD Rebuilder support 64-bit operations? I'd be surprised if not. Otherwise, why do you need 32-bit DGDecNV? Will help if we can.
Columbo is offline   Reply With Quote
Old 27th December 2025, 21:17   #32297  |  Link
Ch3vr0n
That's not the point. BDRB does yes, however when using DGDecNV it always has prompted for the 32bit DGDecNV executable. Don't confuse this with the 64bit brdb.exe
Old 28th December 2025, 13:11   #32298  |  Link
Columbo
Donor
Well then, BDRB needs to be updated.
Old 28th December 2025, 14:39   #32299  |  Link
Ch3vr0n
Which is what i'd like to know, if that's going to happen. Last i know for the years bdrb has supported dgdecnv there was some kind of issue with 64bit dgdecnv. No clue if thats still the case @jdobss
Old 28th December 2025, 16:23   #32300  |  Link
Columbo
Donor
Happy to help with any issues incorporating DGDecNV 64-bit.
