#22061 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#22063 | Link |
BD Rebuilder v0.50.02
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.50.02). Changes for this release:
- Added a new hidden option. IVTC_METHOD
lets you choose between DECOMB and TIVTC
as the inverse telecining method. Usage is
defined in HIDDENOPTS.TXT.
- Added the ability to add multiple playlists
to the batch queue when ALTERNATE output is
selected. The feature can be accessed by a
right click in the queue area (if ALTERNATE
output is chosen). For sources previously
imported, the titles specified during import
will be used as output names for the MKV or
MP4 files. Meant as a time saver for those
who like to create MKV/MP4 versions of
series discs.
- Improved automatic audio bitrate ("*") for
MKV and MP4 ALTERNATE output. It now uses
a constant quality parameter for encoding
rather than a predetermined set of audio
bitrates. See ALTAUTOAUDIO in HIDDENOPTS.
- Corrected an issue in which added borders
and/or resizing that is specified in PINFO
may not be applied when reencoding from an
imported source when MULTIPROCESS is in use
with Directshowsource().
- Corrected an error in which required video
resizing mandated by PINFO for an imported
source was not being honored in X264/LAVF
mode. This could result in a distorted
encode and "stretched" view during playback.
- Added code to adjust for DVD imports that
have a horizontal resolution of 352 pixels.
That format is legal for DVD, but not for
the BD standard. It is a rare format, but
it exists on some discs.
- Corrected an issue in which deinterlacing
filters might be used on a 720p source.
- Corrected an error in which aborting during
an ALTERNATE mux, and then attempting to
resume could result in "ERROR in attempt to
mux (MKVMERGE)".
- Corrected an issue in which some movies may
have their audio length clipped when using
NeroAACEnc.
- Fixed a problem in which a 480i source might
be left intact, even when iVTC has been
selected and should be accomplished.
- Updated the included version of X265.EXE to
a newer release (12/22/2014).
- Updated the included version of X264.EXE to
the latest release (r2525).
- Updated the included version of X264-64.EXE
to the latest release (r2525).
- Other minor corrections and cosmetic fixes.
#22066 | Link | |
I found a bug with Import/Quick-Play Settings and Import... I'm testing for repeat reporting..
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
#22067 | Link | |
#22069 | Link |
again dgindex PID error message
Hi jdobbs,
I have the dgindex PID error message again on Full Disc BD25 Backup by new German AKIRA Blu-Ray on MPEG2 Bonus material. The same error I have had on Ger. SHINING Blu-Ray. I thought it was fixed at 0.50.01. I have tested it on 2 PCs (Win 7 and 8.1) with and without codec packs but nothing changed. On Akira Blu-Ray the PID error message only comes on mpeg2 VID_00101 and VID_00102 but not on VID_00103. Please see Pictures and mediainfo log files for the 3 mpeg2 files. It would be very nice if you can reactivate ffdshow (on hidden options) for mpeg2 encoding again because it works perfect without any Errors on mpeg2 material. many thanks and kind regards Last edited by andref4; 29th December 2014 at 16:49. |
#22070 | Link |
I did a lot of testing on that.
I don't believe I've gotten reports from anyone else who has reported that issue. I even ran BD-RB against the file you provided me that was supposed to have the error -- and couldn't repeat it. That leads me to believe it must be specific to your setup (or your process). I'm not sure what else I can do. The only time I could repeat it is if I forced a read error on a file.
jdobbs.softworks@gmail.com Last edited by jdobbs; 29th December 2014 at 20:10. |
#22072 | Link |
Can you give me an example in something other than "UNDERWORLD_RISE_OF_THE_LYCANS"? I ordered that one, it arrived damaged, and I sent it back.
#22074 | Link |
@Ch3vr0n - Do you blank any stuff (using the Hidden Option that enables right-click -> Blank)? I find nearly all my discs come out undersized, but I also blank lots of useless stuff. I haven't reported this only because it's been a long while since I've done an untouched re-encode to prove it isn't me.
#22075 | Link | |
no my hdds are all ok. the files are correct backuped and have no read errors and so on. But I dont know why this error only comes if mpeg2 files indexed by dgindex. If I did encode the movies which have mpeg2 with dvdfab it works and the mpeg2 files are encoded to mpeg4 format without any errors and the BD25 backup works perfect. with at least bd-reb 0.47.07 it has worked too but the 0.47 I cant use anymore because it's expired. If you cant find the error I must use, if the error message comes on, dvdfab for bds with mpeg2 material. ![]() Tomorrow I can try it on my brothers Laptop... But I dont think it works because I tested mpeg2 stuff on 2 other PCs with same error. Can it be that an AV/Firewall will block dgindex? On all PCs I tested it has Norton Internet Security installed. Last edited by andref4; 30th December 2014 at 15:00. |
#22076 | Link | |
I'll add a hidden option for the next release that will bypass DGIndex/DGDecode for MPEG-2. But, honestly, it is a lot better to not use Directshow -- especially when doing iVTC (which is very, very common in NTSC MPEG-2)
jdobbs.softworks@gmail.com Last edited by jdobbs; 30th December 2014 at 16:01. |
#22077 | Link |
Links to audio and subtitles
Thanks Mr Dobbs for the latest updates!
One thing still bothers me, its a minor thing, more esthetic, If I rebuild a BD from series, with multiple episodes, If I remove the subtitles and audio I dont want, the links still show up when playing, If I do a movie only backup they are really gone. Is there a way to get rid of the empty links when rebuilding full series BD's? Thank you, Greetings from Hans Last edited by Hassie; 31st December 2014 at 00:24. |
#22078 | Link | |
#22080 | Link |
I'd pretty much have to build a Java interpreter for BD-J, and the equivalent for command sequences -- and then the software to analyze their actions and automatically modify the code. That's way beyond the scope of BD Rebuilder.
| Display Modes | |
