Old 27th November 2014, 18:39   #21881  |  Link
RobertM
I've gone through the code and I can't figure how this is happening, so I've ordered TRANCE. I'll let you know what I find when it gets here in a couple days.
Just let me know, once the disc arrives, if you want me to test some other settings, or if I can help in any other way. I really appreciate the effort you put in to helping us out, and you'll be more than compensated for the cost of this disc with my usual XMas donation. I plan to keep up that yearly tradition until I stop using BD-RB. I've donated to many shareware apps, but none moreso than BD-RB. It's money well spent for me, and well earned by you. Thanks, JD.
RobertM is offline   Reply With Quote
Old 27th November 2014, 19:01   #21882  |  Link
jdobbs
Originally Posted by HWK View Post
Did you notice x265 is outputting 10 bit video instead of 8 bit.
With the version included with BD-RB? If that happened it was entirely by accident.
jdobbs.softworks@gmail.com
Old 27th November 2014, 21:07   #21883  |  Link
andref4
Hi jdobbs,
did you downloaded the Shining vid_00003 from the link I gave you?
If so please let me know so that I can delete the file.
regards
andref4 is offline   Reply With Quote
Old 27th November 2014, 22:55   #21884  |  Link
HWK
HWK's Avatar
You wouldn't happen to get them from http://builds.x265.eu/ if so, problem is there not in BD-RB. I downloaded 32 bit with 8 bit support and I got 10 bit instead.
However when I downloaded 64 bit, then it was right one. I also noticed 64 bit uses less memory and is faster as well.
If you fail to plan; you plan to fail, would you not agree? Think about it.
HWK is offline   Reply With Quote
Old 28th November 2014, 00:07   #21885  |  Link
jdobbs
Originally Posted by andref4 View Post
Hi jdobbs,
regards
Go ahead and delete it.
Old 28th November 2014, 00:09   #21886  |  Link
jdobbs
I typically download from that same link. The 32 bit version is included in BD-RB's TOOLS folder.
Old 28th November 2014, 00:58   #21887  |  Link
HWK
HWK's Avatar
Oh, I see. Anyways 10 bit color space has no playback problem at least on media Player classic-home cinema
Old 28th November 2014, 03:20   #21888  |  Link
jdobbs
Good catch. BD-RB wasn't properly taking the original audio size into account when two-pass-target mode was selected along with INTACT audio while processing an ALTERNATE selection.
Old 28th November 2014, 04:12   #21889  |  Link
HWK
HWK's Avatar
Ah, Nice. Jdobbs, when encoding in two pass with HEVC and if you abort in second pass and start again, it wants to start with pass one and then do second pass.
Would it be possible to avoid doing pass one, if already done. Like it does with X264.
Old 28th November 2014, 22:47   #21890  |  Link
kanerulz69
Banned
@jdobbs, do you think speed will be greater if I upgrade my current i7 3690x w/ 64gb ddr3 to the latest i7 5960 that is 8 core, where mine now is 6 core, it takes me about 4hrs to encode a movie full backup 25gb bdr on very slow 2 pass, want to know if I'll see that much of a difference in encode speed by upgrading...
kanerulz69 is offline   Reply With Quote
Old 29th November 2014, 00:14   #21891  |  Link
jdobbs
I can't say, as I'm not an i7 guy -- but hopefully someone else can chime in.
Old 29th November 2014, 00:53   #21892  |  Link
omegaman7
omegaman7's Avatar
I'd be willing to bet, that the second pass will benefit from 2 more cores. You may not see much if any gain in the first pass. Theoretically, I would think that you would. More worker bees after all lol. Anandtech has benchmark comparisons
http://www.anandtech.com/bench/product/1317?vs=443
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 29th November 2014, 01:14   #21893  |  Link
Groucho2004
Unfortunately, their x264 benchmarks are ridiculously outdated which means that, especially with newer CPUs, the score will not reflect the true potential. Not to mentioin that the techarp benchmarks are created by morons (sorry, I can't be kind about this).
This website uses up-to-date versions of x264 and uses the "FHD Benchmark" which I believe provides realistic results. You'll find x264 results in the "Application Tests" section of each test.
Old 29th November 2014, 05:22   #21894  |  Link
Lathe
Lathe's Avatar
Just to confirm, I was just trying to back up 'TOMB RAIDER' which WILL fit on a single layer Blu-ray (the destination size being a BD-25) so that I could eliminate a couple of the unnecessary audio and sub tracks. BDRB processed the main movie file just fine and of course indicated that no re-encode would necessary. But, when it started on one of the extra files (MPEG-2) it immediately gave me the exact same error message 'Could not create an AVS file'. So, it sounds like it definitely is doing what you said when trying to process MPEG-2 files while using the internal LAVF frame server.
Funny, until recently, I had never noticed it doing that before.
Lathe is offline   Reply With Quote
Old 29th November 2014, 05:44   #21895  |  Link
jdobbs
It would have started on v0.49.02, the error is associated with the code I added to support DGINDEX/DGDECODE.
Old 29th November 2014, 05:51   #21896  |  Link
omegaman7
omegaman7's Avatar
Apologies. Didn't mean to mislead. It was merely a quick google, right before work lol.
Old 29th November 2014, 22:10   #21897  |  Link
Lathe
Lathe's Avatar
Thanks, good to know. You sure found that fast!
Old 2nd December 2014, 00:44   #21898  |  Link
DoctorM
Today I re-encoded some bonus features to a BD5 using Quick Play. The option for Strict AVCHD is turned on.
My Sony BD player says the disc is unplayable, and VLC only plays a video/audio loop from the original menu with no text or selectable elements.
Is Quick Play even compatible with AVCHD discs?
[12/01/14] BD Rebuilder v0.49.05 (beta)
[17:01:19] Source:  TANGLED.2010.2D
  - Input BD size: 8.10 GB
  - Approximate total content: [00:52:07.499]
  - Target BD size: 4.36 GB
  - Windows Version: 6.1 [7601]
  - Quick-Play Reauthoring mode enabled
  - Quality: Highest (Very Slow), Two Pass
  - Output folder: C:\Users\Dr. M\Desktop\
  - Decoding/Frame serving: DGDecNV
[17:01:26] PHASE ONE, Encoding
 - [17:01:26] Processing: VID_00006 (1 of 19)
 - [17:01:26] Extracting A/V streams [VID_00006]
 - [17:01:36] Reencoding video [VID_00006]
   - Rate/Length: 23.976fps, 5,687 frames
   - Bitrate: 9,210 Kbs
 - [17:01:36] Reencoding: VID_00006, Pass 1 of 2
 - [17:02:33] Reencoding: VID_00006, Pass 2 of 2
 - [17:06:35] Video Encode complete
 - [17:06:35] Processing audio tracks
 - [17:06:35] Multiplexing M2TS
 - [17:06:41] Processing: VID_00103 (2 of 19)
 - [17:06:41] Extracting A/V streams [VID_00103]
 - [17:06:53] Reencoding video [VID_00103]
   - Rate/Length: 23.976fps, 5,806 frames
   - Bitrate: 9,205 Kbs
 - [17:06:53] Reencoding: VID_00103, Pass 1 of 2
 - [17:07:54] Reencoding: VID_00103, Pass 2 of 2
 - [17:11:53] Video Encode complete
 - [17:11:53] Processing audio tracks
 - [17:11:53] Multiplexing M2TS
 - [17:11:59] Processing: VID_00104 (3 of 19)
 - [17:11:59] Extracting A/V streams [VID_00104]
 - [17:12:15] Reencoding video [VID_00104]
   - Rate/Length: 23.976fps, 2,969 frames
   - Bitrate: 12,411 Kbs
 - [17:12:15] Reencoding: VID_00104, Pass 1 of 2
 - [17:12:46] Reencoding: VID_00104, Pass 2 of 2
 - [17:14:42] Video Encode complete
 - [17:14:42] Processing audio tracks
 - [17:14:42] Multiplexing M2TS
 - [17:14:48] Processing: VID_00105 (4 of 19)
 - [17:14:48] Extracting A/V streams [VID_00105]
 - [17:15:25] Reencoding video [VID_00105]
   - Rate/Length: 23.976fps, 9,877 frames
   - Bitrate: 9,193 Kbs
 - [17:15:25] Reencoding: VID_00105, Pass 1 of 2
 - [17:16:47] Reencoding: VID_00105, Pass 2 of 2
 - [17:22:22] Video Encode complete
 - [17:22:22] Processing audio tracks
 - [17:22:22] Multiplexing M2TS
 - [17:22:30] Processing: VID_00106 (5 of 19)
 - [17:22:30] Extracting A/V streams [VID_00106]
 - [17:22:42] Reencoding video [VID_00106]
   - Rate/Length: 23.976fps, 2,510 frames
   - Bitrate: 9,201 Kbs
 - [17:22:42] Reencoding: VID_00106, Pass 1 of 2
 - [17:23:05] Reencoding: VID_00106, Pass 2 of 2
 - [17:24:40] Video Encode complete
 - [17:24:40] Processing audio tracks
 - [17:24:40] Multiplexing M2TS
 - [17:24:45] Processing: VID_00107 (6 of 19)
 - [17:24:45] Extracting A/V streams [VID_00107]
 - [17:25:03] Reencoding video [VID_00107]
   - Rate/Length: 23.976fps, 5,365 frames
   - Bitrate: 9,191 Kbs
 - [17:25:03] Reencoding: VID_00107, Pass 1 of 2
 - [17:25:52] Reencoding: VID_00107, Pass 2 of 2
 - [17:29:09] Video Encode complete
 - [17:29:09] Processing audio tracks
 - [17:29:09] Multiplexing M2TS
 - [17:29:16] Processing: VID_00108 (7 of 19)
 - [17:29:16] Extracting A/V streams [VID_00108]
 - [17:29:33] Reencoding video [VID_00108]
   - Rate/Length: 23.976fps, 5,167 frames
   - Bitrate: 9,221 Kbs
 - [17:29:33] Reencoding: VID_00108, Pass 1 of 2
 - [17:30:24] Reencoding: VID_00108, Pass 2 of 2
 - [17:34:03] Video Encode complete
 - [17:34:03] Processing audio tracks
 - [17:34:03] Multiplexing M2TS
 - [17:34:09] Processing: VID_00109 (8 of 19)
 - [17:34:09] Extracting A/V streams [VID_00109]
 - [17:34:29] Reencoding video [VID_00109]
   - Rate/Length: 23.976fps, 6,170 frames
   - Bitrate: 9,208 Kbs
 - [17:34:29] Reencoding: VID_00109, Pass 1 of 2
 - [17:35:33] Reencoding: VID_00109, Pass 2 of 2
 - [17:39:53] Video Encode complete
 - [17:39:53] Processing audio tracks
 - [17:39:53] Multiplexing M2TS
 - [17:39:59] Processing: VID_00110 (9 of 19)
 - [17:39:59] Extracting A/V streams [VID_00110]
 - [17:41:03] Reencoding video [VID_00110]
   - Rate/Length: 23.976fps, 17,810 frames
   - Bitrate: 12,312 Kbs
 - [17:41:03] Reencoding: VID_00110, Pass 1 of 2
 - [17:44:19] Reencoding: VID_00110, Pass 2 of 2
 - [17:59:36] Video Encode complete
 - [17:59:36] Processing audio tracks
 - [17:59:36] Multiplexing M2TS
 - [18:00:01] Processing: VID_00113 (10 of 19)
 - [18:00:01] Extracting A/V streams [VID_00113]
 - [18:00:11] Reencoding video [VID_00113]
   - Rate/Length: 23.976fps, 1,393 frames
   - Bitrate: 12,354 Kbs
 - [18:00:11] Reencoding: VID_00113, Pass 1 of 2
 - [18:00:28] Reencoding: VID_00113, Pass 2 of 2
 - [18:01:40] Video Encode complete
 - [18:01:40] Processing audio tracks
 - [18:01:40] Multiplexing M2TS
 - [18:01:44] Processing: VID_00114 (11 of 19)
 - [18:01:44] Extracting A/V streams [VID_00114]
 - [18:01:54] Reencoding video [VID_00114]
   - Rate/Length: 23.976fps, 1,368 frames
   - Bitrate: 12,330 Kbs
 - [18:01:54] Reencoding: VID_00114, Pass 1 of 2
 - [18:02:10] Reencoding: VID_00114, Pass 2 of 2
 - [18:03:17] Video Encode complete
 - [18:03:17] Processing audio tracks
 - [18:03:17] Multiplexing M2TS
 - [18:03:22] Processing: VID_00115 (12 of 19)
 - [18:03:22] Extracting A/V streams [VID_00115]
 - [18:03:35] Reencoding video [VID_00115]
   - Rate/Length: 23.976fps, 1,890 frames
   - Bitrate: 12,240 Kbs
 - [18:03:35] Reencoding: VID_00115, Pass 1 of 2
 - [18:03:57] Reencoding: VID_00115, Pass 2 of 2
 - [18:05:40] Video Encode complete
 - [18:05:40] Processing audio tracks
 - [18:05:40] Multiplexing M2TS
 - [18:05:45] Processing: VID_00116 (13 of 19)
 - [18:05:45] Extracting A/V streams [VID_00116]
 - [18:05:56] Reencoding video [VID_00116]
   - Rate/Length: 23.976fps, 1,968 frames
   - Bitrate: 12,320 Kbs
 - [18:05:56] Reencoding: VID_00116, Pass 1 of 2
 - [18:06:23] Reencoding: VID_00116, Pass 2 of 2
 - [18:08:04] Video Encode complete
 - [18:08:04] Processing audio tracks
 - [18:08:04] Multiplexing M2TS
 - [18:08:09] Processing: VID_00117 (14 of 19)
 - [18:08:09] Extracting A/V streams [VID_00117]
 - [18:08:19] Reencoding video [VID_00117]
   - Rate/Length: 23.976fps, 990 frames
   - Bitrate: 12,383 Kbs
 - [18:08:19] Reencoding: VID_00117, Pass 1 of 2
 - [18:08:31] Reencoding: VID_00117, Pass 2 of 2
 - [18:09:17] Video Encode complete
 - [18:09:17] Processing audio tracks
 - [18:09:17] Multiplexing M2TS
 - [18:09:21] Processing: VID_00118 (15 of 19)
 - [18:09:21] Extracting A/V streams [VID_00118]
 - [18:09:31] Reencoding video [VID_00118]
   - Rate/Length: 23.976fps, 1,188 frames
   - Bitrate: 12,299 Kbs
 - [18:09:31] Reencoding: VID_00118, Pass 1 of 2
 - [18:09:45] Reencoding: VID_00118, Pass 2 of 2
 - [18:10:44] Video Encode complete
 - [18:10:44] Processing audio tracks
 - [18:10:44] Multiplexing M2TS
 - [18:10:49] Processing: VID_00119 (16 of 19)
 - [18:10:49] Extracting A/V streams [VID_00119]
 - [18:11:00] Reencoding video [VID_00119]
   - Rate/Length: 23.976fps, 1,479 frames
   - Bitrate: 12,338 Kbs
 - [18:11:00] Reencoding: VID_00119, Pass 1 of 2
 - [18:11:16] Reencoding: VID_00119, Pass 2 of 2
 - [18:12:26] Video Encode complete
 - [18:12:26] Processing audio tracks
 - [18:12:26] Multiplexing M2TS
 - [18:12:31] Processing: VID_00120 (17 of 19)
 - [18:12:31] Extracting A/V streams [VID_00120]
 - [18:12:41] Reencoding video [VID_00120]
   - Rate/Length: 23.976fps, 1,488 frames
   - Bitrate: 12,342 Kbs
 - [18:12:41] Reencoding: VID_00120, Pass 1 of 2
 - [18:12:57] Reencoding: VID_00120, Pass 2 of 2
 - [18:14:04] Video Encode complete
 - [18:14:04] Processing audio tracks
 - [18:14:04] Multiplexing M2TS
 - [18:14:09] Processing: VID_00121 (18 of 19)
 - [18:14:09] Extracting A/V streams [VID_00121]
 - [18:14:19] Reencoding video [VID_00121]
   - Rate/Length: 23.976fps, 1,485 frames
   - Bitrate: 12,340 Kbs
 - [18:14:19] Reencoding: VID_00121, Pass 1 of 2
 - [18:14:35] Reencoding: VID_00121, Pass 2 of 2
 - [18:15:42] Video Encode complete
 - [18:15:42] Processing audio tracks
 - [18:15:42] Multiplexing M2TS
 - [18:15:47] Processing: VID_00122 (19 of 19)
 - [18:15:47] Extracting A/V streams [VID_00122]
 - [18:15:54] Reencoding video [VID_00122]
   - Rate/Length: 23.976fps, 375 frames
   - Bitrate: 9,124 Kbs
 - [18:15:54] Reencoding: VID_00122, Pass 1 of 2
 - [18:15:59] Reencoding: VID_00122, Pass 2 of 2
 - [18:16:17] Video Encode complete
 - [18:16:17] Processing audio tracks
 - [18:16:18] Multiplexing M2TS
[18:16:21]PHASE ONE complete
[18:16:21]PHASE TWO - Rebuild Started
 - [18:16:21] Rebuilding BD file Structure
 - [18:17:05] Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[18:17:45] - Encode and Rebuild complete
[18:17:45] JOB: TANGLED.2010.2D finished.
DoctorM is offline   Reply With Quote
Old 2nd December 2014, 01:23   #21899  |  Link
gonca
AVCHD is strictly movie only. Some players do play menu structure within an AVCHD disc while some don't. Has your player successfully played back BD5 or 9 with menus before?
gonca is offline   Reply With Quote
Old 2nd December 2014, 01:44   #21900  |  Link
DoctorM
Yup, menus generated with MultiAVCHD work fine. It disables any menu features that are incompatible with AVCHD discs when set to that format (as opposed to full BD) and it works just fine.
I assumed the same would be true for BD Rebuilder.
Edit: Burned a rewritable BD50 and the menus played fine (and looked great).
I read somewhere on wikipedia that what is compatible for a DVD menu is compatible for AVCHD menus. That would suggest the video and audio should be compatible. I'm not sure why it doesn't work.
