Old 9th October 2007, 13:11   #41  |  Link
Shakey_Jake33
The Vista problem might be because of UAC. Try disabling that. And of course register the filter with admin privileges.
You are right! Disabling UAC lets me install it! I've never had to do that with a codec before though.
Shakey_Jake33 is offline   Reply With Quote
Old 9th October 2007, 15:01   #42  |  Link
TheSof
I keep getting a "Cannot render file" when using madflac and mpc. Works fine in graphedit.
TheSof is offline   Reply With Quote
Old 9th October 2007, 15:30   #43  |  Link
madshi
Hmmm... Do you have some "strange" filter in the "external filters" section? Don't know what else could stop madFlac from working...
What happens if you just drop a FLAC file into GraphEdit without manually choosing madFlac. Does GraphEdit automatically choose madFlac and does playback work that way?
Maybe you still have another filter installed (e.g. CoreFlac)?
Old 9th October 2007, 15:49   #44  |  Link
TheSof
When I drop an flac into graphedit I get an error:
"The format is not supported."
I do not have coreflac installed, nor any other flac source filter nor decoder, but clearly somethings wrong on my end, as seems to be more and more often the case
Old 9th October 2007, 17:40   #45  |  Link
madshi
That's a bit strange. Maybe there's another filter which tries to read the FLAC file but fails. Does MPC show you which filter it used for the "cannot render file"?
Old 10th October 2007, 19:13   #46  |  Link
madshi
madFlac v1.4 released
http://madshi.net/madFlac.rar
* bugfix: "madFlac" is shown in MPC/ZoomPlayer now instead of file name
* bugfix: maybe installation in Vista64 works now without having to deactivate UAC (not tested)
* bugfix: using different libFlac.dll build to avoid crashes on older CPUs
* in addition to the "madFlac Source" there's now a "madFlac Decoder" filter for decoding FLAC inside of MKV (or other containers)
The new "madFlac Decoder" filter for MKV FLAC decoding is not very well tested yet. So I'd be happy about some feedback. Especially I'd like to know if there are audio dropouts or audio sync problems or anything like that. If everything works great, I'd like to know that, too, of course. Thanks.
Old 12th October 2007, 00:19   #47  |  Link
TheSof
Have not had much time to test, but for me it is great. It does not drop out when ffdshow does (for me ffdshow will always drop out now and then in the first 20 seconds but then more or less behaves) nor pop, which core does sometimes.
I also like the information panel.
Great work in all. Thanks so much.
Old 12th October 2007, 08:27   #48  |  Link
madshi
I'm glad to hear that - thanks for the feedback...
Old 13th October 2007, 08:34   #49  |  Link
Fasola_Jan
Can you add tag support for Windows Media Player 11, pretty please (with cherry on top)?
Fasola_Jan is offline   Reply With Quote
Old 13th October 2007, 08:42   #50  |  Link
madshi
I don't even know (exactly) what that is. If you give me a few details I might be able to add it.
Old 13th October 2007, 11:22   #51  |  Link
Fasola_Jan
Sure You do
Title, Artist, Album info etc. embedded inside flac file (tags).
Windows Media Player Tag Support Extender (WMPTSE) project link:
http://wmptagext.sourceforge.net/
It sometimes works with flac files (almost)
Maybe You can port some of this to madFlac?
Old 13th October 2007, 11:57   #52  |  Link
madshi
Can you please send me a short sample of a file with all the tag infos in it that you want to have supported? I only need a few seconds of audio with the tags in. So e.g. 1MB should be plenty enough.
Old 13th October 2007, 13:22   #53  |  Link
Fasola_Jan
Done.
(to email at madshi.net account)
Old 13th October 2007, 13:29   #54  |  Link
ACrowley
FLAC muxed in mkv works nice so far now !
ACrowley is offline   Reply With Quote
Old 13th October 2007, 22:38   #55  |  Link
madshi
Done.
Received it. Thanks. Will look at this when I find some time.
Old 13th October 2007, 22:39   #56  |  Link
madshi
Good to hear!
Old 14th October 2007, 14:38   #57  |  Link
ACrowley
Good to hear!
and connects properly to AC3Filter..so i can output FLAC as AC3 640 through SPDIF...not lossless ofcourse, but it sounds still great...imho AC3Filter AC3 on the fly encoder sund better as ffdshow
But AC3Filter supports on 5.1 and wont connect to 6.1/7.1 Flac..i think when i set madflac to 5.1 restricted Output ,it should connect in 5.1 to AC3 Filter again , right ?
I know there a ffdhshow Build which can handle 6.1
But this ffdshow Build wont output (on the fly encode) AC3 640 via SPDIF for any Audio like FLAC or WMA pro. It was working fine with older ffdshow Builds
However, AC3 Filter works fine with madflac
Old 14th October 2007, 14:57   #58  |  Link
madshi
Yes, it will connect that way. That's what the madFlac option is meant for...
Old 14th October 2007, 14:58   #59  |  Link
madshi
Btw, if there is interest I might include realtime Aften reencoding to madFlac. However, I don't know how fast Aften is. It might cost too much CPU to be useful.
Any opinions?
Old 14th October 2007, 14:59   #60  |  Link
ACrowley
Ah, i made a few Test on 6.1 (7.1) FLAC Files.
madflac output from "24 Bit" 6.1 connects to AC3Filter without 5.1 restriction Option!
AC3 Filter decodes only 5.1 from 6.1......i think the BC is skipped
But strange....AC3Filter decodes this Output from madflac (24Bit 7.2) as dts with the "dts decoder" ?!
The same FLAC in 16 bit cant conect to AC3 Filter because its more than 5.1 ,the old Problem.
But now i can set madflac to 5.1 restricted and it works again with AC3 Filter
AC3 Filter decoding is PCM as it should be.
So :
24bit FLAC 6.1 = AC3 Filter decodes it with "dts decoder" as 5.1
16bit FLAC 6.1 = AC3 Filter wont connect without madflac 5.1 restriction. Decoding via PCM as usual
Strange ,isnt it ?
@ Madshi.. it would be a great Coup when you can add AC3 640 Output (SPDIF capable) in madflac ! Maybe you find a Way
