Go Back   Doom9's Forum > Capturing and Editing Video > HDTV / DVB / TiVo
Old 21st February 2014, 11:25   #21  |  Link
pandy
Originally Posted by sebus View Post
Cannot detect file format
Audio must be recorded without any modification - bit exact copy mode
http://www.hydrogenaudio.org/forums/index.php?showtopic=91655
pandy is offline   Reply With Quote
Old 21st February 2014, 16:48   #22  |  Link
Ghitulescu
Ghitulescu's Avatar
Some American told me long time ago that all HD receivers have to have the firewire-interface enabled. I would suggest trying to copy them 1:1 via firewire (there is a software used for D-VHS once in the internet).
The best solution would be to copy them natively directly from the HDD.
The third best option (and the first for me) would be to buy the set on BD (it's cheaper now). It think the price is lower than any other solution involving hardware you don't have or that doesn't work (and requiring to buy additional gear).
In Germany the PayTV providers try to force people into getting their own boxes, which generally are not only nuttered in terms of functionality but also have of a very bad quality, both constructional and reliability. I own my own STB and I could always recover the recordings from the HDD. Movies I don't record, as usually they have various issues (senders' logo, less channels, lower A/V quality, lack of subtitles, lack of the original audio). This is what I recommend to you, too. It will be a good future investment, a movie can be remuxed and authored (chapters, subtitles etc) within one hour, if needed, in original broadcasting quality.
Coming back to your question, S/P-DIF should be in theory possible with all soundcards having digital in. The software has to bypass windows (ie it has to be ASIO based) for best results (or any results at all ). Many freeware and payware can do this. You can even create a graph to save the digital stream to a file.
Born in the USB (not USA)
Old 28th March 2014, 18:22   #23  |  Link
Music Fan
I recorded ac3 5.1 a few years ago with the optical input of an Audigy 2 ZS and its original drivers on Windows XP.
I had to ;
-tick "enable bit accurate recording" in Device Controls
-put REC on SPDIF in Creative's volume window
-put REC's volume on 0db (50 %)
-record in stereo 48/16 with Cool Edit Pro (became Adobe Audition) ; of course, it's better to begin recording before to play the stream to record and finish after recording to avoid missing parts
-save in Windows PCM (Wav extension)
-use BeSplit to clean the stream and create an .ac3 file with this command ;
C:\BeSplit.exe -core( -input "F:\ac3 file 448k.wav" -prefix P:\track -type ddwav -fix )
P:\track will become P:\track01.ac3
It also removes the potential blank parts at the beginning and end (if done how I suggested with Cool Edit Pro).
eac3to can maybe also clean the stream.
Anyway eac3to can be used after BeSplit to remove the possible dialog norm (IIRC BeSplit didn't do this) with this simple command ;
"C:\Program Files\eac3to\eac3to.exe" "P:\input file.ac3" "F:\output file.ac3"
This also works to remove dialog norm of dts files (replace .ac3 by .dts).
Music Fan is offline   Reply With Quote
Old 11th March 2020, 10:47   #24  |  Link
astraub
Using besplit destroys lip sync
I found that recording an AC-3 track using SPDIF and post-processing it with besplit destroys the audio/video sync. The AC-3 file is shorter than the video. Could this be a problem when recording in 16 instead of 24Bit mode?
I also tried AC3REC and this showed a lot of CRC errors and frame drops, which could explain the missing audio time?
I will get another SPDIF interface, capable of 24 bit mode. Hopefully this improves the situation.
Any additional comments / ideas?.
Greetings
Andreas
astraub is offline   Reply With Quote
Old 23rd March 2020, 06:15   #25  |  Link
goemon
what spdif interface are you using?
goemon is offline   Reply With Quote
Old 25th March 2020, 20:20   #26  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
What version of Windows are you using? I used a SoundBlaster SPDIF box ages ago - it worked fine under Windows XP, but on Windows 7 the Windows Mixer got in the way and added noise/resampling to the recording. You have to make sure whatever's recording is exclusively and directly access the SPDIF interface, I think.
wonkey_monkey is offline   Reply With Quote
Old 25th February 2025, 09:51   #27  |  Link
Bruno202
What software to use?
Bruno202 is offline   Reply With Quote
