#61 | Link |
![]() M4A muxing works, but shows a dialog with no text before muxing each file for some reason. MKA has no problems. |
#63 | Link |
Hello,
I don't know if I'm doing something wrong because I haven't seen my problem anywhere. Everytime I extract an FLV that contains an AVI file inside, it disappears after it's done (only when I have the setting: remux to mkv). Everything else works great. |
#64 | Link | |
Nani miten da yo? Baka!!
have you set disable for the option "Remove temp files" yet? Or can you please send me link of the file you're trying to extract (mediafire like please) so i can check it detailedly. |
#66 | Link |
Mkvmerge can mux those streams without a problem, so probably the command-line generated by the GUI for remuxing is wrong. (expecting ".264" instead of ".avi"?)
But FLV1 video in mkv will not offer great compatibility anyways... |
#67 | Link | |
it might be true, if i remember right, i didn't use switch case for .264/.avi in here (i don't like avi muxing into mkv as well). I will fix the code a bit. --- I did add the case for avi input file, but i wonder the command-line is still wrong format? --- I found the problem in here, the command-line for avi input file got repeated. And there are still a problem in setting ratio for mp4 file :/ it needs both of input/output file ratio, and i still dont know how to set values of command-line right. Last edited by jofori89; 5th September 2012 at 02:29. |
#68 | Link |
FLV Extract
Latest version: 2.0.3 (September 5 2012) http://code.google.com/p/flv-extraxct/ Front-end FLV extract and mp4/mkv remuxing GUI software. Change logs: version: 2.0.3 - Fix avi (FLV/VP6,...) muxing to mkv gives no output file). Require: - .Net 2.0 (if using XP). - Mkvmerge.exe for mkv remuxing. - mp4box.exe for mp4 remuxing. Download: http://code.google.com/p/flv-extraxct/downloads/list Last edited by jofori89; 5th September 2012 at 02:50. |
#73 | Link | |
Yeah, i got that bug too when i tried remux some 29.970 FLV files from youtube to MP4. If i did not specify the output framerate but just leave it be original, it become 25fps. There are not that bug with mkv
#74 | Link |
FLV Extract version 2.1.0
FLV Extract
Latest version: 2.1.0 (Jan 12 2013) http://code.google.com/p/flv-extraxct/ Front-end FLV extract and mp4/mkv remuxing GUI software. Change logs: -Fix incorrect framerate for mp4 output file at auto option. -Add right click menu, now user can add files via it or "Open with..." in Windows Explorer. Require: - .Net 2.0 (if using XP). - Mkvmerge.exe for mkv remuxing. - mp4box.exe for mp4 remuxing. Download: http://code.google.com/p/flv-extraxct/downloads/list Current issues: - Changing ratio for mp4 output is currently not working. - Some files contain non-Unicode characters in its name may not be remuxable to mp4 (remove those characters will fix this). Last edited by jofori89; 12th January 2013 at 06:30. |
#75 | Link | |
Member
#76 | Link | |
ratio = " ar=1.78:1.33";
#78 | Link | ||
Currently there is no code to auto get ratio of flv video in project, should i let user manually input resolute of video? ![]() Quote:
#79 | Link |
Life's clearer in 4K UHD
How about offering the ability for users to input their own settings within the 'FPS' and 'Aspect Ratio' boxes?
| Display Modes | |
