#21 | Link |
FLV Extract doesn't generate headers or any other data for MP3 files, it simply copies chunks of data from the FLV audio 'tags' into the MP3 file. The frame headers are already present inside the FLV file and not modified by FLV Extract, so if something is wrong with the output then it is likely the fault of whatever created the FLV file.
moitah.net |
#22 | Link |
brontosaurusrex
is there a working muxer for flv (vp6) + mp3?
my problem: http://forum.doom9.org/showthread.php?t=129871 |
#23 | Link |
FLV Extract 1.3.0 released. Surprisingly FLV Extract is now the most popular download from my site with ~50,000 downloads a month. Now I need to finish the VirtualDub FLV input plugin
.Code:
* Added dialog that lists the status of all files to replace the message box
that was shown for each file.
* Doesn't leave files open upon error.
* Better handling of incomplete files.
* Changed VP6 FourCC from FLV4 to VP6F.
* A few fixes for rare files.
moitah.net |
#25 | Link |
BeHappy/MeGUI developer
any chance to get proper oneclick flv->mkv remuxer? or even better command line tool?
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
#26 | Link |
@dimzon: No, but maybe a command line version. That would allow you to use it in a batch file along with mkvmerge.
moitah.net |
#27 | Link |
When I play the avi produced by FLV extract with MediaPlayerClassic it has sound. Three audio tracks according to MPC file properties - two MP2 and one MP3. Where is MPC getting the audio from - is it in the avi? FLV extract only extracted the MP3.
If I change the name of the avi and play it, then there's no audio. Last edited by cobo; 22nd March 2008 at 01:14. |
#28 | Link |
AVIs written by FLV Extract do not contain audio. MPC automatically loads an audio file that has the same filename as the video. If you want to add the audio inside the AVI, you can use VirtualDub 1.8.0 or newer.
moitah.net |
#30 | Link |
Can you post a link to the video (the page on YouTube is fine)?
moitah.net |
#33 | Link |
just wanted to add my voice to the choir - thank you, a very useful tool! Now that the BBC seems to be changing its radio streams from Real Media to mp3 through FLV, this will be very useful to be able to continue to listen to BBC radio shows on my morning commute!
#34 | Link |
FLV Extract 1.4.0 released:
* Supports H.264/AVC, written as a raw elementary stream. * Supports AAC, written as .aac with ADTS headers. * Extracts VP6 alpha channel to a separate file. * Prompts before overwriting files.
moitah.net |
#36 | Link | |
![]() Thank you Moitah, really appreciated
#37 | Link |
Member
wow! and thanks.
using this to demux flv tutorial files so that I can play them on iphone. THANKS
Thanks to all for the great programs out there and thanks to all for the support given on these forums |
#39 | Link |
Sorry if this is against rule 11, but thanks very much for the AVC support! I couldn't find a way to open one of those odd AVC flv's, then I found this program was updated. You help me to keep with the times.
f=33 |
#40 | Link |
FLV Extract 1.6.0 released. Recent features (from 1.5.0 and 1.5.1 as well):
moitah.net |
| Display Modes | |
