Old 14th January 2006, 22:19   #261  |  Link
Isochroma
Yes, the XviD directshow filter has a very good output colorspace selector; this would be great to have in CoreAVC!
Isochroma is offline   Reply With Quote
Old 14th January 2006, 23:18   #262  |  Link
Scoty
please People help me. i can not use the CoreAVC in MPC and WPM 10. which settings in MPC and WPM 10 i need ?
Scoty is offline   Reply With Quote
Old 15th January 2006, 00:01   #263  |  Link
calinb
calinb's Avatar
Originally Posted by breez
Well actually the conversion is done just right, but there is a difference with video and PC levels. In video levels reference black is at 16 and reference white at 235 (0 and 255 in PC levels).
It is problematic for mixed use PCs. One either calibrates display for video or PC levels, but not for both. One can also expand the 16-235 range to 0-255 to use with a display calibrated to PC levels. This of course isn't a lossless operation (banding may occur when done at low precision).
The other problem with expanding levels from the video to pc range is levels outside the "permitted" video level range sometimes occur--the so called "blacker than black levels." They will be clipped in the expansion. When using the video range, it's still possible to properly adjust your display to render them (supported by some monitor/TV calibration DVDs), whereas they are simply lost when expanded to the PC range.
calinb is offline   Reply With Quote
Old 15th January 2006, 00:03   #264  |  Link
dk75
dk75's Avatar
regsvr32 /s CoreAVCDecoder.ax
And you shouldn't uninstall ffdshow.
You should change decoding option in codec settings: "H.264" to "disabled" and "RAW" to "supported all".
With this, you could do color space conversion with ffdshow for CoreAVC decoded stream.
I'm going down...
dk75 is offline   Reply With Quote
Old 15th January 2006, 01:01   #265  |  Link
Zero1
Zero1's Avatar
The speed is remarkable, excellent job. This will help bring H.264 to many more people now
Such a shame it won't become a part of FFDShow(/libavcodec). Let's just hope they are able to speed up also. We already have the best ASP decoder
Zero1 is offline   Reply With Quote
Old 15th January 2006, 15:56   #266  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Originally Posted by SeeMoreDigital
I wonder, would it be possible to place some "user settings" that can be accessed and adjusted via the filters "Properties" widow: -
Cheers
at least some kind of infos... would it be possible to show the profile that was used for the encode?? like ffdshow does via osd (bframes, gmc, etc.)
that would be very nice
btw, enjoy the nice sunday
sillKotscha is offline   Reply With Quote
Old 15th January 2006, 17:13   #267  |  Link
bond
ok before this non-avc related discussion evolves too much, note that this thread is about coreavc, the _AVC_ decoder
if you want to discuss different things, like mpeg-2, .ts, streaming or whatever start new threads where they belong plz
Ogg Theora | Ogg Vorbis
Old 15th January 2006, 17:16   #268  |  Link
lexor
it is? I thought it was about TCMPM which reached mature stage and just got coreAVC, I thought decoder discussion was just a bonus based on BetaBoy's first post.
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 15th January 2006, 21:10   #269  |  Link
bond
guys, betaboy started an own thread for tcpmp in the software player forum (where it belongs):
http://forum.doom9.org/showthread.php?t=103199
post there your non-coreavc issues
Old 16th January 2006, 12:13   #270  |  Link
PicardGK
I'am checking rgb32/24 mmx transformation. It will cost speed for sure (like ffdshow). Alone the bytes written to memory is almost 3 times as many. Benchmark performance with Null output will suffer more because of lower memory latency which doesn't really hide the mmx transformation.
Why people use rgb32 for video playback? I heard some Nvidia card has crappy yuv colorspace transformation, but I'am not sure why.
Does all VMR9 driver support YUY2 input? I also have the brightness problem in this scenario, but it can be adjusted by the decoder (like ColorYUV(levels="TV->PC")), although I'am not sure how much quality loss there is because of the 8bit channel resolution.
PicardGK is offline   Reply With Quote
Old 16th January 2006, 12:53   #271  |  Link
bond
well i used to notice jerky playback in rare cases with my old nvidia tnt2 pro with yv12, that happened with gabest's realvideo dshow stuff iirc
especially i noticed jerkyness with yv12 anamorphic resize (with asp)
this would speak for that the old tnt2 has problems with yv12
than there is the thing that anamorphic resize works in mplayer, tough i am not sure it really uses yv12 (altough it says so)
tcpmp also works fine it seems (does it output yv12?)
so this might indicate that there are simply some issues with the dshow filters i used (ffdshow for asp) and yv12 works fine on the tnt2
than there is that mf once told me that these cards have problems with yv12 overlay but i wasnt able to find any info about this anywhere in the web, so i am not sure about this
also after i upgraded to win2000 i dont seem to get these issues that clearly anymore (eg yv12 anamorphic resize with coreavc seems to work fine)
the thing is the jerks are hardly spotable, so its hard to say whether there are problems or not, especially if you are testing with avc on a pentium3 866mhz pc you never know if lack of cpu kicks in
so all in all my tnt2 is an old card and i still cant say for sure if it has problems or not
on my tnt2 vmr9 only wants to directly connect to coreavc if it outputs yuy2. when coreavc outputted yuy2 only it force a colorspace converter in between
if you add something that means quality loss make sure to add an option for the user to en- or disable it plz
Old 16th January 2006, 13:08   #272  |  Link
PicardGK
YV12 is the deafult if the DirectDraw overlay supports it. But I will add some options in settings dialog to be able to override.
I guess the second part was about YV12. My Radeon 9600 doesn't support YV12 either with VMR9. I guess because it's planar.
Of course. Btw the only problem with TV->PC yuv level transformation that scaling [16..235] to [0..255] means the result will have some gaps, but I guess it's not visible. But it may cost little performance, so everything is optional.
Old 16th January 2006, 13:46   #273  |  Link
videomixer9
ffdshow fan
I think many ppl want to convert the ranges as you can clearly see any encoding glitch in VMR9 with YV12 video. I have lots of encodes that look fine in overlay but you'll see how crappy they really are in VMR9. Besides it's kinda awkward seeing a grey tone instead of black even though this is the correct way of displaying it. Where this doesn't matter should be HTPCs or if you use VMR9 on your TV screen otherwise, of course.
Imo the problem clearly is that there's no hardware accelerated colorspace conversion available as part of VMR9 and imo MS should fix this.
Besides the bonus of being able to have lots of accelerated videos running at the same, I don't see much bonus in using VMR9 (excl. all uses for videos in games). If you got an graphics adapter with bad hardware resizer you'll prolly lack the power to correct this via software anyways, seeing that high quality lanczos resizing or even hq bicubic resizing takes lots of power in realtime.
Whatever, VMR9 sounds cool and is new, thus many ppl will keep using it and some might actually gain quality with it, but sure not those with old pcs and graphics cards that have broken support for things like YV12, and those sure aren't the new top modells of nvidia and ati ...
videomixer9 is offline   Reply With Quote
Old 16th January 2006, 13:55   #274  |  Link
3ngel
Because doing YUY2->RGB32 conversion in software avoid possibile bad conversion, and any visualization problem you can imagine cause of the grafic card hardware routine.
Doing in software a good conversion (with a good routine) you are sure to send to the GPU the raw video stream (already converted in the color space used by the GPU that is RGB) and so the GPU has only to send to video without any other operation. And so there are no problems at all (and a maximum quality visualization).
3ngel is offline   Reply With Quote
Old 16th January 2006, 14:01   #275  |  Link
PicardGK
Originally Posted by cjei
I hope CoreAVC can have these color conversion options :
ColorMatrix("Rec.709->Rec.601")
ColorMatrix("Rec.601->Rec.709")
Because vmr7&9 seems to need PC scale YUV
and overlay needs Rec.709 for HD.
I checked and AVC does have a way to signal input yuv levels and whether it's BT601 or BT709. So by default the decoder will use this info (example all Apple 1080p trailers us BT709, but 720p and lower are BT601). Not sure if there is a need to be able to override it. On the other hand the output properties should be optional, because I don't know any way to detect them.
At the moment BT601 vs BT709 transformation will only work with RGB output. (btw maybe it's just me, I see almost no different on my LCD monitor between this modes...)
Sure. It will be supported (optional). This an output property.
Btw I don't understand why would VMR9 look good on TV? This would mean the gray on monitor looks black on TV, which means an old overlay black would be more black or something.
You mean whem CoreAVC outputs YUY2 to VMR9, it's transformed by the video driver software and not pixelshader or something? This would mean there is not much perfomance loss if CoreAVC would do the transformtion (with correct yuv level and colormatrix usage).
Old 16th January 2006, 14:52   #276  |  Link
Inventive Software
Turkey Machine
Guys, I'm impressed! For the first time I can play 720x576@25 AVC content on my Celeron 800. You should have an award! This stuff is revolutionary, no joke.
As yet, I haven't tried ASP content with all the bells and whistles, but that time will come soon!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 16th January 2006, 14:56   #277  |  Link
CruNcher
CruNcher's Avatar
It isn't really, it shows that good clean low level coding can be very powerfull but sadly alot of developers today go more in the direction of .Net and stuff loseing all this knowledge
It is about Time
Old 16th January 2006, 14:58   #278  |  Link
breez
Old overlay with a TV would look bad as supposedly gray colors would be black (and white when dealing with light gray).
breez is offline   Reply With Quote
Old 16th January 2006, 18:03   #279  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
mmx color transformation code has been added to SVN for TCPMP and also to the CoreAVC filter.. it's up to Toff to listen to the proposals from you 'SMD' to add the about dialog controls so the user has more options.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 16th January 2006, 18:24   #280  |  Link
videomixer9
ffdshow fan
Actually I thought that MS could implement VMR9 to accept almost anything and give video drivers the chance to pass over colorspace conversion to the graphics hardware, all I know is that MS currently delivers this odd colorspace conversion filter that's not really brilliant. Or can VMR9 do conversions via PixelShaders or sth. similar already without the player, or are there any shaderscripts you can e.g. use with MPC to do conversions e.g. to RGB?
Oh well seeing how skillful CoreAVC is done I guess you'd do something nice for this thing too, maybe better than fake hardware acceleration we all know
As to TV it seems funky as classic overlay and VMR9 look almost perfectly the same here. Dunno what nvidias drivers or hardware do there ...
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
