Old 20th June 2020, 16:06   #21  |  Link
Groucho2004
Wonkey_Donkey
Typo or on purpose? I admit that Wonkey Donkey also has a nice ring to it.
Groucho's Avisynth Stuff
Old 20th June 2020, 16:41   #22  |  Link
Obviously a typo (as is Wonkey_Willy when I accidentally use that one too).
Old 20th June 2020, 20:49   #23  |  Link
Groucho2004
I'll do it unless wonkey's WaveForm() supersedes and replaces that plugin.
Well, I did it anyway, find it in my Avisynth Stuff thread. Read the included documentation, there are some parameters that must be supplied.
Example:
audio = WavSource("test.wav")
return AudioGraph(AudioDub(BlankClip(10000), audio), 20, 0, $8a9dff, $fcb5db)
Old 20th June 2020, 22:50   #24  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
https://www.youtube.com/watch?v=TUzkWF7AVZI
wonkey_monkey is offline   Reply With Quote
Old 20th June 2020, 23:42   #25  |  Link
I'm guessin' that Wonkey_Monkey
is a kinda corruption of "One Key Monkey", and the time it would take for him to accidentaly write the complete works of William Shakespeare.
Infinite monkey theorem:- https://en.wikipedia.org/wiki/Infinite_monkey_theorem
[But of course it may have nowt whatever to do with it].
Old 20th June 2020, 23:48   #26  |  Link
Groucho2004
That reminds me of Jeremy Duncan:
https://forum.doom9.org/showthread.p...00#post1364900
It's amazing that this was 10 years ago. Time flies.
Old 20th June 2020, 23:56   #27  |  Link
Yep, he aint been online since 2011, apparently he is/was an actor, that explains eveything.
EDIT:
I'm guessin' that in the Infinite Donkey Theorem, it would take even longer to produce eg Hamlet [A mild cigar from Benson & Hedges].
Old 26th June 2020, 19:23   #28  |  Link
Reel.Deel
Thank you Groucho. I test it the plugin but there is some odd crashes going on. I will post something later on, hopefully someone else can reproduce.
Old 26th June 2020, 19:40   #29  |  Link
Groucho2004
Did you use my updated version (0.0.1)?
Old 26th June 2020, 20:01   #30  |  Link
Reel.Deel
No, I used 0.0.0, I missed the update . Will test and report back.
Old 16th May 2023, 12:04   #31  |  Link
kedautinh12
ver 0.0.2
https://github.com/Asd-g/AviSynth-AudioGraph/releases
Fixed undefined behavior - uninitialized optional parameters.
Fixed undefined behavior - uninitialized allocated memory.
Fixed undefined behavior (float input audio) (CPUs with SSE/SSE2) by reenabling the internal conversion from/to audio float.
Fixed upside down graph. (YUY2)
Added support for YV24 and planar RGB/RGBA (8-bit).
Added support for frame properties passthrough.
