25th October 2007, 04:55 | #61 | Link | |
I might also be missing a step, so if anyone can really give a fool-proof method of doing this on Vista that'd be awesome. 1. Grabbed all the software (DRM Helper, drmdbg latest, autoUnDRM for the drm2wmv) 2. Told DRM Helper where my media is. 3. clicked Search for Media, which it found. 4. Clicked start. 5. Pointed drmdbg to my media folder and to the drm2wmv folder. 6. Clicked MultiScan WMP opens up, plays the last song, and nothing else happens. |
25th October 2007, 05:29 | #62 | Link |
I dont care so should you
Dose DRMdbg load a list of crazy looking code in the lower boxes?
If so then you have the keys located in a *.key file to unDRM those files... Using decryptIT, drm2wmv, or freeme2... use of DecryptIt is the simplest way (i found) to get all files un-drmed... (ie batch mode) The only problem is if half the files are Drmed and half are not in the media folder then drmdbg will play the first file with out the need of Grabbing the key, causing it not to grab all of the keys... keep only the files that need UnDRMed in the folder you wish to un-drm... |
25th October 2007, 05:43 | #63 | Link | |
25th October 2007, 05:47 | #64 | Link | |
25th October 2007, 11:18 | #65 | Link |
A lot of problems were corrected.
drmdbg 2007/10/25 18:30 http://up.uppple.com/upload.cgi?mode=dl&file=7384 DLKey:12345 zip-pass:8o5ZPzd21aE36n4980Ts875088611c |
25th October 2007, 15:31 | #66 | Link | |
Thanks for the reply. I just tried the 10/25 version and am still getting the VirtualAllocEx error...I'm on Vista Business, no Bitlocker. I'll try it on another Vista box tonight. Thanks, LC |
26th October 2007, 05:55 | #68 | Link |
where did you purchase them your DRMd music... it might use a different type of DRM all together Not Play-for-sure WMP
I dont know It works on mine just fine... Tryed on vista H-Basic<->Ultimate |
26th October 2007, 23:22 | #69 | Link |
I have tried everything mentioned in this thread and have had mixed results as well as mixed experiences with the various versions of stripping software. I have also downloaded the code that sectroyer posted and am working on some things to make a GUI version similar to the one we all love, but for now I've created a vbScript to help automate the process we have been discussing here in this thread.
Long story short, I've tried all the suggested methods in this post and still came across buggy results - mostly because of the way the drmdbg application processes the files - and I've come to the conclusion that it's easiest to manually run drmdbg and then run a batch script to process the audio files. P.S. the script only works for wma files...not tested on Vista hope this helps
"ignorance is bliss..." INTEL CORE 2 Extreme (~2.93GHz), EVGA N680i-SLI 4096 MB RAM 800Mhz C4, XFX 9800 GX2 1024MB X-Fi Fatality, BFG PhysX 128MB, Apple Cinema 23 @ 60 hertz Last edited by mybsides; 28th October 2007 at 19:31. Reason: ajax_undone is an ass |
27th October 2007, 17:07 | #70 | Link |
mybsides, your work is wonderful.
Subdirectory scanning became possible. drmdbg 2007/10/27 22:30 http://up.uppple.com/upload.cgi?mode=dl&file=7419 DLKey:12345 zip-pass:nkNr669hu5Q25LMFQG5899abC1m8M5 |
27th October 2007, 19:42 | #71 | Link |
Oh wow~! Thanks so much for including subdirectory recursion.
"ignorance is bliss..." INTEL CORE 2 Extreme (~2.93GHz), EVGA N680i-SLI 4096 MB RAM 800Mhz C4, XFX 9800 GX2 1024MB X-Fi Fatality, BFG PhysX 128MB, Apple Cinema 23 @ 60 hertz Last edited by mybsides; 28th October 2007 at 19:31. Reason: Ajax_undone is an ass |
28th October 2007, 18:39 | #72 | Link | |
Why Password Protect the files? its not like M$ isn't going to find the passwords right below the links anyway... it just make it annoying.... By the way use a different Upload site rather then rapidshare.com seriously they ultra suck |
28th October 2007, 19:25 | #73 | Link | |
"ignorance is bliss..." INTEL CORE 2 Extreme (~2.93GHz), EVGA N680i-SLI 4096 MB RAM 800Mhz C4, XFX 9800 GX2 1024MB X-Fi Fatality, BFG PhysX 128MB, Apple Cinema 23 @ 60 hertz Last edited by mybsides; 28th October 2007 at 19:28. |
29th October 2007, 17:16 | #74 | Link |
I have some wmv files which I want to unDRM.
I used drmdbg (2007/10/27 22:30) and out of the 10 files I have,only 2 keys were obtained. I successfully manage to unDRM the 2 files using DecryptIt which came with Automate UnDRM v2.0. However, how can I unDRM the remaining 8 files ? |
4th November 2007, 00:03 | #76 | Link |
Can anybody give me clear instructions on how this is supposed to work? I can appreciate that drmdbg gets updated every other day, but it's a bit confusing to keep up with it.
I try to run the program, by double-clicking or through the command prompt. It launches WMP and I select a protected file. Then, it just sits there. Nothing in that large box on the bottom, no text file, no nothing. Can somebody help? (Vista Business, IBX 11.0.6000.7000, also XP Home 11.0.6000.6324, the latter of which currently works with FU4WM). Thanks |
4th November 2007, 00:23 | #77 | Link | |
"ignorance is bliss..." INTEL CORE 2 Extreme (~2.93GHz), EVGA N680i-SLI 4096 MB RAM 800Mhz C4, XFX 9800 GX2 1024MB X-Fi Fatality, BFG PhysX 128MB, Apple Cinema 23 @ 60 hertz |
4th November 2007, 03:41 | #79 | Link |
FYI:
Installing the Zune software will upgrade you to IBX 11.0.6000.7000. The installer requires internet access to install. I tried it on an XP Pro virtual machine, and it upgraded to .7000 even with the original WMP9 installed. If you use a computer with the Zune software previously installed, it will retain the old version. My Vista Ultimate desktop is running .6324 with the Zune software installed. |
4th November 2007, 07:45 | #80 | Link | |
drm, ibx |
