Old 19th June 2021, 17:12   #1121  |  Link
LigH
LigH's Avatar
Not generally possible. They may handle fundamentally different actions (e.g. VirtualDub has no substitute to every possible AviSynth filter and NLE feature, whereas AviSynth is not able to select a codec for the compression).
New German Gleitz board
Old 19th June 2021, 18:47   #1122  |  Link
How do you convert AVISynth scripts to Virtualdub processing scripts?
As LigH said, but you can load avisynth scripts into VDub2, and additionally process in some way, and/or add to queued jobs list.
Old 20th June 2021, 03:46   #1123  |  Link
GAP
Okay thanks.
GAP is offline   Reply With Quote
Old 19th December 2021, 21:22   #1124  |  Link
Yo shekh,
If you do get back to this, can I ask if cursor in AVS script editor be sizeable, specifically adjust width wider,
on 4K monitor and Windows 10 scaling to 150%, cursor is almost invisible in the editor [W10 scaling or Ease of Access cursor width seems to make no difference].
I quite often find myself having to click with the mouse so I can tell where the cursor is.
Thanks muchly
Old 3rd February 2022, 18:19   #1125  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
It seems VirtualDub2 doesn't understand Y-only clips with >8 bits. Not sure if this has been noted before so just putting it on record.
wonkey_monkey is offline   Reply With Quote
Old 10th February 2022, 20:45   #1126  |  Link
Wilbert
I made this one sticky, and collected all the depreciated stuff into one sticky. Let me know if anyone has other suggestions.
Old 10th February 2022, 22:26   #1127  |  Link
wonkey_monkey
You could un-sticky my "Compiling VirtualDub with VC++ Express - how I did it" thread because it's hopelessly out of date.
Old 6th September 2022, 08:27   #1128  |  Link
LigH
LigH's Avatar
Are you barking at the wrong tree?
Old 7th September 2022, 14:59   #1129  |  Link
tormento
Acid fr0g
tormento's Avatar
Don't feed the troll™.
@turment on Telegram
Old 11th September 2022, 03:54   #1130  |  Link
GAP
Due to circumstances involving my laptop's GPU being busted, I am foced to use my Woindws XP comuter. I wanted to convert my videos to .mp4 but while converting my video, I encountered an error called "Requested frame not found". I am not sure what has caused this error but I want to convert my videos using Virtualdub2. Can anyone help me?
Old 11th September 2022, 16:51   #1131  |  Link
nji
Suspended for forum rule violations
With my limited knowledge I would say that
the video stream is defect in some way.
Try different decoder (at VD2's open dialog),
or try avidemux.
If successfull check the audio (sync and quality).
nji is offline   Reply With Quote
Old 12th September 2022, 15:43   #1132  |  Link
From another of your threads, [EDIT: GAP threads]
If you can't play back uncompressed in realtime, I'd worry that you might not be able to record uncompressed in realtime, and thus would get dropped frames. So double-check that before trying uncompressed.
Recording uncompressed video is a great use case for RAID, if that's an option for you.
From this [GAP] thread,
https://forum.doom9.org/showthread.php?t=183052
Maybe suggest trying the batch script with that error producing clip,
BAT(same thread) = https://forum.doom9.org/showthread.p...05#post1948505
See if ffmpeg gives any further info in error message for the missing frame,
perhaps it can even auto conceal the error. (producing legal output clip)
EDIT:
OR smaller bat script. Output UT_Video, AVI.
SomethingOrOther.bat
setlocal
REM Where to Find ffmpeg
set FFMPEG="C:\BIN\ffmpeg.exe"
REM Where to get input file, No terminating Backslash, "." = current directory
set INDIR="."
REM Where to place output file, No terminating Backslash.
set OUTDIR="D:"
FOR %%A IN (*.wmv *.mpg *.avi *.flv *.mov *.mp4 *.m4v *.RAM *.RM *.mkv *.TS *.ogv *264 *.webm *.m2v *.VOB) DO (
  %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI"
Pause
Output AVI to to D: drive. Input types in BLUE (can try adding more at end of list, eg " *.abc", SPACE separatedf from other extensions).
Create CONVERT Folder. Copy bat and source clips into that folder.
Ensure FFMPEG line points to your ffmpeg binary.
Run the bat.
(The Bat dont like SPACES nor weird foreign chars in filenames)
Old 14th September 2022, 08:51   #1133  |  Link
GAP
I will that a try and see what I get. I am not sure Virtualdub2 works for XP as I want to export to .mp4.
or try avidemux.
What version of AVIDemux works with XP?
Old 19th September 2022, 21:53   #1134  |  Link
filler56789
SuperVirus
filler56789's Avatar
<OT>
Not sure whether the members from France, Italy, Spain, Poland or Hungary (for example) would like to see their native languages labeled as "weird" or "foreign".
Next time please try to write just "non-ASCII characters".
It's true that the Amerikans have the bad habit of assuming that they are the center of the universe;
however it's easy to forget that they inherited this bad habit from the Brits.
</OT>
filler56789 is offline   Reply With Quote
Old 19th September 2022, 23:02   #1135  |  Link
I consider my bottom well smacked ! (but will likely repeat said faux pas )
One day we will take back that colony and re-establish the center of the Universe
Old 22nd September 2022, 04:16   #1136  |  Link
GAP
What is the the input caching driver? I heard once that it might be somehting wrong with the driver.
Old 5th November 2022, 12:35   #1137  |  Link
isidroco
Last working version: https://sourceforge.net/projects/avi...idemux/2.6.20/
Until today (v44282) all virtualDub2 versions work with XP, some third party plugins (as Filtres_JPSDR) may fail.
isidroco is offline   Reply With Quote
Old 5th November 2022, 13:28   #1138  |  Link
isidroco
In VDUB2, File, Open, at the bottom you can use original VDub Input driver: "Audio/video interleave..." which will only open AVIs (and will fail to accurately seek frames on h264/h265). Or "Caching Input Driver" (FFMPEG based) which will open almost anything although you will loose DirectStreamCopy (unless video is compressed using a compressor with AllKeyFrames as MJPG).
You may try to fix corrupted video: http://www.risingresearch.com/en/dvr/
Old 6th November 2022, 15:16   #1139  |  Link
jpsdr
Even the XP build version ?
My github.
Old 12th November 2022, 18:45   #1140  |  Link
nji
HEVC; set display aspect ratio
?How?
