Old 19th August 2015, 21:11   #441  |  Link
videoh
Useful n00b
Sweet, thank you! Downloading...
Old 19th August 2015, 21:44   #442  |  Link
videoh
Useful n00b
If you demux the AVC ES from the TS and then convert that to MKV with mmg.exe everything is fine and acts exactly the same as if you index the TS.
If you feed the TS directly into mmg.exe then everything gets hosed, and frames are lost at the start.
Conclusion: Your guess was correct. mmg.exe is not properly reading the TS. It is not unusual for applications to fail miserably at parsing interlaced transport streams. Apparently mmg.exe is yet another example. You should demux the audio and video, apply a delay correction to the audio as needed (or do it when muxing MKV), and then mux them into an MKV.
Old 19th August 2015, 22:03   #443  |  Link
dejong12
Thank you for investigating the issue and providing a solution! I'll raise the issue at the creator of MKVToolnix.
dejong12 is offline   Reply With Quote
Old 19th August 2015, 22:08   #444  |  Link
videoh
Useful n00b
My pleasure. Good luck with your projects and thank you for bringing to light the bad version I had online.
Old 19th August 2015, 22:27   #445  |  Link
stax76
stax76's Avatar
I think mkvmerge uses time codes so it works fine for playback but is unusable for encoding. dsmux muxes it better allowing for encoding afterwards, unfortunately it fails on certain sources and it's discontinued.
Old 19th August 2015, 22:39   #446  |  Link
dejong12
I've just tried to remux the .ts into .mkv with dsmux and I can confirm that the resulting .mkv works correctly in DGDecNV, so there's a problem with mkvmerge. And my apologies for hijacking the thread.
Old 19th August 2015, 23:26   #447  |  Link
sneaker_ger
I'm not seeing what you are seeing.
Downloaded episode.ts, used "mkvmerge -o episode.mkv episode.ts" (mkvmerge 8.3.0).
Opened using lwlibavvideosource(), both files show exactly 34500 frames. Mkv timecodes are 100% regular.
Old 19th August 2015, 23:30   #448  |  Link
dejong12
It only happens when using DGSource as a source filter.
Old 19th August 2015, 23:35   #449  |  Link
sneaker_ger
Maybe videoh can add his knowledge about what exactly is wrong with the mkvmerge output to your bug report:
https://github.com/mbunkus/mkvtoolnix/issues/1409
What does DGSource do when a stream does not start on a recovery point?
Old 19th August 2015, 23:45   #450  |  Link
stax76
stax76's Avatar
It's not really a bug or something as far as I can see, it's more a limitation and a better implementation is rather unlikely because it should be very hard to do even for a master programmer like Mosu, you can create a ticket but don't expect much.
Old 20th August 2015, 00:06   #451  |  Link
dejong12
Stax, another "problem". I've imported yadif x64 into the latest StaxRip version, but it's not deinterlacing correctly. I can see some color (de)blending happening. Neither deinterlacer works 100% correctly. When using the last x86 version of StaxRip (1.2.2.2) and using the same encoding settings with yadif, the deinterlacing works as it should, deinterlacing the source file 100% correctly.
Old 20th August 2015, 03:28   #452  |  Link
videoh
Useful n00b
I used 7.9.0.
Old 20th August 2015, 03:29   #453  |  Link
videoh
Useful n00b
Nah. I simply used mmg on your TS. DGSource didn't enter at all. And you said you have no issue when using dsmux to create the mkv.
Old 20th August 2015, 03:30   #454  |  Link
videoh
Useful n00b
Any frames before the first decodable one are replaced with copies of the first decodable frame.
Old 20th August 2015, 08:56   #455  |  Link
dejong12
I'm just saying that when you convert the uploaded TS to MKV (not with DSMux) and import that MKV into StaxRip the problem only shows when using DGSource. The other source filters handle the MKV fine.
Old 20th August 2015, 09:32   #456  |  Link
stax76
stax76's Avatar
muxing ts to mkv using mkvmerge is probably not a good idea if you want to encode afterwards, it should get async with other source filters too, not necessarily always but probably often, I experimented a while with it with little success, in this time I found out about dsmux.
Old 20th August 2015, 09:36   #457  |  Link
Groucho2004
I was wondering about that - why re-mux the .ts to mkv?
Old 20th August 2015, 09:47   #458  |  Link
stax76
stax76's Avatar
because most tools fail on ts producing async output, dsmux at least sometimes helps to get around this, people without DGDecNV license or other payware like TS-Doctor or VideoRedo don't have great choice. At one point I wanted to code a TS demuxer myself, I would probably done it already, the problem is I practically never have TS sources personally so my motivation working on it is rather limited.
Old 20th August 2015, 16:07   #459  |  Link
Ajvar
stax76, can you please tell me, does this 64 bit version provides video comparison feature (aka Codec comparison) and if you ever make a separate app for this? Last version I used was 1.2.2.2 beta and you wrote that you updated that coparison afterwards however I never could successfully download your Alphas of x86.
Thank you.
EDIT: It is working fine after installing Avisynth+.
Ajvar is offline   Reply With Quote
Old 20th August 2015, 19:48   #460  |  Link
dejong12
Videoh, could you take a look at what the creator of mkvmerge had to say about the issue?
