13th April 2008, 23:10 | #101 | Link |
The Canon HF100 camcorder creates a BD structure live on the flash card. I put it on a DVD-5 with no changes and it played as "AVCHD" on the PS3 - no menus, just one title, every scene (file) on the flash a different chapter in the title.
There's one problem: at the end, the PS3 loops back to the beginning and starts playing the whole disk (title) again. What do I need to change to prevent it from doing that? |
18th April 2008, 09:33 | #102 | Link |
Matroska find' ich toll
Hi Pelican9
Is it possible to implement the the output-format of chapters in form of "ogg" like in ChapterXtractor? i can't use your chapter.txt in mkvmerge. hubble for example: CHAPTER01=00:00:00.000 CHAPTER01NAME=Chapter 1 CHAPTER02=00:03:59.720 CHAPTER02NAME=Chapter 2 CHAPTER03=00:06:01.400 CHAPTER03NAME=Chapter 3 CHAPTER04=00:07:13.160 CHAPTER04NAME=Chapter 4 CHAPTER05=00:14:09.160 CHAPTER05NAME=Chapter 5 CHAPTER06=00:16:23.320 CHAPTER06NAME=Chapter 6 CHAPTER07=00:17:23.120 CHAPTER07NAME=Chapter 7 CHAPTER08=00:20:46.960 CHAPTER08NAME=Chapter 8 CHAPTER09=00:23:24.520 CHAPTER09NAME=Chapter 9 CHAPTER10=00:28:14.160 CHAPTER10NAME=Chapter 10 CHAPTER11=00:29:10.320 CHAPTER11NAME=Chapter 11 CHAPTER12=00:31:49.440 CHAPTER12NAME=Chapter 12 CHAPTER13=00:35:54.360 CHAPTER13NAME=Chapter 13 CHAPTER14=00:40:37.240 CHAPTER14NAME=Chapter 14 CHAPTER15=00:41:43.800 CHAPTER15NAME=Chapter 15 |
18th April 2008, 18:30 | #104 | Link |
Pelican9, is it possible that the decoding of Set:SetSystem:SetStream is incomplete/wrong?
51000001 8FEC8FED 00000000 is decoded as: SetStream PSR109, GPR0 GPR4076 and GPR4077 are used. So I assume that the correct decoding is SetStream GPR4076, GPR4077, <notset>, <notset> SetStream should have 4 parameters. And 8000h defines if it's used. Parameters being Audio, Subtitle, IG, Angle. |
19th April 2008, 00:10 | #105 | Link |
Hello,
I made some experiments with Nero 8. 1. 1 title, no Menu -> result : it loops 2. 1 title 1 Menu -> you can select end action in Nero as follows a) loop title b) next title c) go to menu Based on that, I assume/conclude as follows * there is no 'stop' action defined at end of title (again my guess) * if you want to not loop, you have to create a menu * reason (again, my guess): when you author a title in scenarist (which is very strict on standard compliance), you must select a top menu and at least 1 movie both pointing to the stream you want to author for blu ray. you cannot not select the menu - it means the top menu is also the title (movie). if you play in PS3 and select go to menu it actually starts the movie again, but if you had chapters, these are then not recogized. In conclusion it seems, that looping is the only sensible action when you have no menu. one idea, which I am not sure makes sense would be to create a 2nd title of extremely short length , for example black screen. you can then loop that after the defined end action from clip 1 (the movie) was 'go to next' of course I would be overly keen to see if there is another solution which stops the annoying looping hope this helps |
19th April 2008, 04:33 | #106 | Link | |
can somebody tell me how to create a bdedit screenshot to post ? |
30th April 2008, 12:54 | #114 | Link |
Hi
Is it possible to correct a defect menu with BDedit or can BDedit show where the fault is, because I've one BD-structure which can't be played with powerdvd . There is only a black screen and powerdvd stops after 10sec |
20th May 2008, 13:04 | #119 | Link |
I have created a Blu-ray movie file from two merged m2ts files using a combination of TSsplitter and TsRemux.
I used TSsplitter to join the two m2ts files and then TsRemux to create the Blu-ray movie structure. While the merged m2ts is the right filesize the time duration as reported from TsRemux is only the duration of the second input m2ts file. In terms of playback from Arcsoft TMT, the time duration of the merged m2ts file with direct playback is correct however when I attempt playback as a movie file, the duration corresponds only to the second input m2ts file. A consequence of this is that TMT will only play part of the file (for the shorter duration) before returning to the start. Is it possible to change the duration of a BD movie file with BDedit ? Last edited by drsmithdtv; 20th May 2008 at 13:12. |
20th May 2008, 20:23 | #120 | Link |
Hi Pelican, great tool.
I have recently begun to experiment with home made movies shot on HDV and authored for Blu-Ray with Adobe Encore CS3. My goal is to burn my HD movies on a regular DVD for viewing on PS3. The rationale is primarily cost of the media. I know it is realistic since the length is well below 4.7GB capacity of the DVD. The issue I have is that Encore writes out a standard Blu-Ray file structure, which, when burned to a DVD is incompatible with the PS3. However, the PS3 is capable of playing authored AVCHD discs, including those with HDV (mpeg2) content. Therefore, what I have been able to accomplish is that starting with an AVCHD index.bdmv, I can edit it using BDedit to be identical to the authored index.bdmv as output from Encore. Then, I burn the AVCHD structure and it works! But, this method is time consuming and rather awkward. When I compare the original Blu-Ray index.bdmv with the AVCHD index.bdmv, I can see that the only distinction is the presence of the "1 extended entry" in the AVCHD. My question is - is there any capability or do you have any plans to add functionality to edit the ExtensionData() records with BDedit. Naturally, I am primarily interested in adding the AVCHD "tag". This functionality would save a lot of time during the authoring process! (I have examined the binary data and I have read the Blu-Ray patents I found with Google, but I am unable to find enough detail to implement this myself.) Here is a link to a description of the workflow: http://www.adobeforums.com/webx/.59b520d1 Thank you very much for your time. |
bd menu, bdedit, blu-ray |
