Old 26th August 2020, 08:13   #18641  |  Link
blacksapprow
@LigH this one is from fraunhoffer and not related with network. Follow the link above, (I have mistyped as x266, but of course this is H.266....)
Meanwhile not only H.266 codec, latest Magix Vegas Pro 18 bring Colorization to films. I don't know is that possible for Ripbot to include. It needs fixing with bar adjustments, but at mobile phones, this is done automatically & immediately with chromatix application. Maybe that way, can be a future add on for ripbot, I hope!
Last edited by blacksapprow; 26th August 2020 at 08:18. Reason: forgotten letter & Pro
blacksapprow is offline   Reply With Quote
Old 26th August 2020, 10:10   #18642  |  Link
LigH
LigH's Avatar
Well, hold your horses then ... Fraunhofer created the VVC codec, yes. But it is only a reference encoder so far. Made to create correct output. Not made to be usably performant. Before using this codec for serious work, you will have to wait for optimized implementations. It doesn't make sense to wait weeks for a conversion of a movie.
New German Gleitz board
Old 26th August 2020, 18:22   #18643  |  Link
colinhunt
Hey Atak_Snajpera, I finally took the time to give RipBot264 a shot, and I'm loving it. I actually got goosebumps seeing 1080p video being encoded in hevc at 160 fps Thanks for creating this awesome software.
One question (or feature request): does/can RipBot support image sequences, as in thousands of PNG/TIF files? Googling didn't give me an answer.
edit: did a bit more googling and stumbled on ImageSource() in an .avs script. Let's see what happens...
colinhunt is offline   Reply With Quote
Old 27th August 2020, 08:50   #18644  |  Link
yuryna
@Atak_Snajpera
Any news about 3 pass support?
Now a question,
how do you choose the breaking point of chunks to distribute among all the client?
It's randomly chosen (i don't think so),
it just mathematically chosen (Total frames / some formula)
fixed number (the chunk is always N frames)?
I think it would be nice to make the chunks lenght basing on "scene change detection".
In this way the distributed chunks would be much more compression/optimized by the x264 which will not find itself in a "scene change" situation with only 5 frames to encode (because the remaining frames of the same scene have been distributed to other client).
The final compression would be more safe and optimized thanks to distribution of key frames (and all that follow) inside the same scene.
What do you think about it?
yuryna is offline   Reply With Quote
Old 27th August 2020, 14:32   #18645  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
That would only create HUGE bottleneck because you would have to analyze whole movie before starting encoding. My workaround is to start chunk at key-frame detected in source file (hence chunks have irregular number of frames). Not perfect but still better than starting chunk at some "random" frame.
Old 27th August 2020, 14:54   #18646  |  Link
yuryna
Wise solution.
For the bottlenek you could make it just a selectable option,
in order to satisfy the deep-quality-researcher too (who don't mind encoding time (like myself? eheh )).
I think it would be a good compromise (the "choice" is always a good added-value).
Old 28th August 2020, 10:20   #18647  |  Link
blacksapprow
@LigH
Don't worry, H.266 can't come so quick, and we are upgrading our systems generally within 5 years. But, if a film size shortens %50, I may love it. Because hard drives are really expensive. 2 piece of 10GB hard drive, equals to a good graphics card. This one will provide only 1 piece of 10GB in a way. Encoding took 6,5 times but playing only needs 1,5 times processing power. For me, this is not bad....
Old 28th August 2020, 11:46   #18648  |  Link
LigH
LigH's Avatar
Did you mean 10 TB?
Old 30th August 2020, 12:34   #18649  |  Link
slalom
slalom's Avatar
@Atak
there is a problem when downloading a poster
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 2nd September 2020, 19:30   #18650  |  Link
userx
userx's Avatar
OpenCL
Hello!
Not sure what happens here:
In DE mode chunks always restart after 100%.
I recently got an update to W10 2004 but i temporary disabled DE mode. Latest nvidia driver is installed.
439|CLIENT <- SERVER| ENCODING_PROGRESS=192.168.1.2:1000 -> [98.3%] 1462/1488 frames, 126.43 fps, 2888.16 kbps, eta 0:00:00;CHUNK=1;CPU=92;RAM=58;DECODER=23;ENCODER=43;OTHER=26;ENCODING_PRIORITY=low;
440|CLIENT -> SERVER| OK
441|CLIENT -> SERVER| GET_ENCODING_PROGRESS;SET_ENCODING_PRIORITY=belownormal;
442|CLIENT <- SERVER| OK
443|CLIENT <- SERVER| ENCODING_FINISHED
444|CLIENT -> SERVER| OK
445|CLIENT -> SERVER| GET_ENCODING_SUMMARY
446|CLIENT <- SERVER| OK
447|CLIENT <- SERVER| ENCODING_SUMMARY=192.168.1.2:1000 -> ERROR;CHUNK=1;CPU=92;RAM=55;DECODER=0;ENCODER=0;OTHER=92;ENCODING_PRIORITY=low;
448|CLIENT -> SERVER| OK
449|CLIENT -> SERVER| STANDBY
450|CLIENT <- SERVER| OK
451|CLIENT <- SERVER| SERVER_IDLE
452|CLIENT -> SERVER| OK
453|CLIENT -> SERVER| ENCODE_CHUNK_1=\\PC\RipBot264temp\job1\Chunks\1.cmd
I noticed I have to switch the OPENCL device to NONE to use the DE mode.
0.0 Device name      : GeForce GTX 970
    Hardware version : OpenCL 1.2 CUDA
    Software version : 452.06
    OpenCL C version : OpenCL C 1.2
    Compute units    : 13
1.0 Device name      : Intel(R) HD Graphics 4600
    Software version : 20.19.15.4835
    Compute units    : 20
Some time ago, i had the same problem with my AMD Radeon 7700 but it seems Capeverde is not well supported or something else. Now i'm not able to use my Nvidia card.
Does anybody have an idea what happens?
userx is offline   Reply With Quote
Old 3rd September 2020, 15:41   #18651  |  Link
HehoChef
Quicky Question: In the Distributed Encoding Client, what does the little number below the "server picture" mean?
For some servers it's rock solid, for some others its bouncing around rapidly.
HehoChef is offline   Reply With Quote
Old 3rd September 2020, 22:02   #18652  |  Link
Atak_Snajpera
Communication delay in ms. (Number of ms elapsed from sending command to reciving confirmation [OK] from server)
Old 4th September 2020, 12:37   #18653  |  Link
Slogra
KNLMeansCL does not seem to work on my AMD VEGA 64. Am i doing something wrong? I get a very dark image when i set mono noise to 2 or higher.
When i set it to 0 or adapter there is a normal image, but i wonder if denoise works at all with these settings.
What other GPU denoise filter do you recommend for an AMD GPU? i'm willing to add it manually to the avisynth script.
I used to use fft3dgpu in the past with avisynth 32bit (?), but i don't think there is a 64bit version.
I've done some conversions with MDegrain2. I really like the result but it is too CPU intensive.
EDIT: however KNLMeansCL does work if i change the resolution of the video from 1920x1080 to 1916x1080 or any other resulotion! So something strange is going on. I would really like to keep the original 1920x1080 resolution.
And to be honest i don't like the result of the KNLMeansCL filter. Especially with animated stuff there seems to be some "color bleeding". So i'm still looking for another GPU denoise filter.
Slogra is offline   Reply With Quote
Old 4th September 2020, 13:03   #18654  |  Link
LigH
LigH's Avatar
But that's certainly not the fault of RipBot264, being just a user interface to control distributed encoding via AviSynth scripts. The reason will rather be between the ATI graphic driver and the KNLMeansCL AviSynth plugin.
Old 4th September 2020, 13:15   #18655  |  Link
Slogra
Agreed. Maybe i should've posted my question in a different topic.
But maybe other ripbot264 users have seen this issue before and have a solution.
Old 4th September 2020, 15:16   #18656  |  Link
LigH
LigH's Avatar
I'd recommend the KNLMeansCL development thread instead. This plugin will not be used in RipBot264 only, but possibly in other tools as well, or even manually.
Indeed, the keyword "vega" appears a few times in there.
Old 5th September 2020, 00:44   #18657  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
I don't quite understand why you're complaining about your graphics card not working with KNLMeansCL, when you don't like the result anyway..
If you like the result when using MDGrain2, maybe you need to upgrade your CPU...are you using distributed encoding ??
Maybe a custom filter, that uses both !!
Sometimes you've just gotta do, what ya gotta do...
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 7th September 2020, 12:43   #18658  |  Link
Slogra
I was able to get knlmeanscl working using a workaround by adding a border before denoising and removing the border after denoising (see knlmeanscl thread).
I'm planning to encode many videos, so I tested the 2 denoise filters and settings with one video first.
Resolution: 1920x1080
Encoder: x.265
Audio: 320kbps 5.1 aac
File size:
Original 2900MB
unfiltered 720MB
mdgrain2 457MB
knlmeanscl mono noise 1 537MB
knlmeanscl mono noise 2 524MB
Encoding speed:
Knlmeanscl 24fps
Mdegrain2 12fps
So Knlmeanscl is much faster.
But mdgrain2 looks a bit nicer imho.
Unfortunately I don't have numbers of the power consumption. I read about power consumption of my cpu and gpu. The 8700K cpu should draw about 90watts with full load.
I don't know the load of the Vega during denoising. I guess it is close to full load, which should be around 300watts.
So if these numbers are correct then mdegrain2 is more power efficient in my setup.
I probably will go for Mdegrain2, although it will take twice as long.
The image is better, the file size smaller and total power consumption is probably lower.
Sorry, if all this belongs in another thread .
Old 10th September 2020, 10:50   #18659  |  Link
Pauly Dunne
Grumpy Old Man.
Well, I can't believe it, a long awaited Auto Update has appeared...
Welcome to RipBot264 v1.26.0, everybody
Some interesting additions, and updates
Thanks, Atak
edit:- having said that, I think there is a problem with MPC.zip...
[ERROR] D:\RipBot264v1.25.1\updates\mpc.zip is corrupted. CRC32 mismatch. Expected value was 79A3D553 but got 1638972A
There weren't any significant files in the MPC.zip...
Old 10th September 2020, 11:50   #18660  |  Link
jlpsvk
changelog????
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
