1st October 2021, 20:57 | #742 | Link |
For anyone that builds this for themself on macOS, it appears that Qt 5.10+ will have a weird issue on a multi-monitor setup where it will only LAUNCH from the primary monitor (it can still be dragged to any monitor, but the shortcut used to open it can only be located on the monitor designated as the primary monitor). The only version of Qt I have confirmed works fine is 5.6.
1st October 2021, 21:43 | #743 | Link | |
1st October 2021, 21:48 | #744 | Link |
Does not matter, if it's launched on any screen other than the primary it won't launch. You can change the primary and it will work on that monitor, or you can launch on the primary and drag it over, but if the OS is trying to launch it from not the primary monitor it does not.
1st October 2021, 23:57 | #745 | Link |
I suppose other Qt programs don't have the same problem, such as Texmaker (https://www.xm1math.net/texmaker/download.html with Qt 5.15.2)
So it should be possible to modify something in VSEditor to suppress this issue. Anyway, I cannot contribute anything before having a Hackintosh. |
2nd October 2021, 02:56 | #746 | Link |
It's hard to say what causes it, on the setup I was using there were three different kinds of monitors so that could have played into it as well. I actually still need to report the bugs compiling mod 2 & 3 as well... Hopefully I find some time next week to troubleshoot.
20th January 2022, 01:00 | #747 | Link | |
I tried to compile for Debian
https://www.l33tmeatwad.com/vapoursy...p_We8vNVDLfSaf Quote:
../../common-src/helpers.h:4:10: fatal error: vapoursynth/VapourSynth.h: No such file or directory 4 | #include <vapoursynth/VapourSynth.h> |
20th January 2022, 01:13 | #748 | Link | |
21st January 2022, 19:02 | #751 | Link |
Damn, I forgot that SMPlayer from http://deb-multimedia.org/ is built with VS R54 dependency, thanks
27th January 2022, 21:39 | #752 | Link |
The cult of personality
vsedit doesn't show output video when pressing f5.
it shows the output window with correct number of frames but no video inside. i am on windows 10, vapoursynth 57 and python 3.9.7. vs editor 2 immediately crashes when pressing f5 EDIT (SOLUTION): i downloaded the beta version of vs editor 1 and it worked fine, just that vs editor 2 is not working Last edited by ~ VEGETA ~; 27th January 2022 at 21:48. |
18th February 2022, 02:18 | #753 | Link |
Derek Prestegard IRL
I too am having the issue where I try to open vsrepogui on Windows and nothing happens.
I have Python 3.9.10 with VapourSynth R57. I also have Python 3.10.0 installed if that matters.
These are all my personal statements, not those of my employer :) |
18th February 2022, 10:39 | #754 | Link |
Check if you're also affected by this https://github.com/vapoursynth/vsrepo/issues/173
22nd February 2022, 12:15 | #757 | Link |
I keep getting:
VapourSynth Editor r19-mod-5 (R57) 2022-02-22 01:57:19.288 Failed to initialize VapourSynth environment! Failed to initialize VapourSynth environment!
Gorgeous, delicious, deculture! |
22nd February 2022, 16:02 | #758 | Link | |
23rd November 2022, 06:24 | #759 | Link |
'VapourSynth.Editor-r19-mod-5.3-x64-Qt6' can't be opened.
I am on windows 8.1 Enterprise, python 3.10.4 and . vapoursynth 58. This is the prompt I return: This application failed to start because no Ot platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: windows |
23rd November 2022, 16:17 | #760 | Link |
Qt 6 by default only support Windows 10 and newer.
see: https://doc.qt.io/qt-6/supported-platforms.html |
