17th February 2014, 00:25 | #23 | Link |
I'm talking about the Intel graphics driver. If you have an iGPU in your processor and you run Nvidia as your primary, you can still access QuickSync, but you have to enable the Intel GPU in the bios and then install the Intel driver as secondary. Then you will have both QuickSync and CUVID. I am still investigating what the situation is for Intel Media SDK in SW mode on a processor without an iGPU.
17th February 2014, 00:40 | #24 | Link | |
http://software.intel.com/en-us/vcso...ools/media-sdk Also, can you try opening an AVC file with dgmvcsource() using SW mode (hw=1)? Last edited by Guest; 17th February 2014 at 00:55. |
17th February 2014, 01:00 | #25 | Link | |
Tried the latest version with hw=1 and it works. Used the sample that was included in the earlier betas. |
17th February 2014, 01:13 | #26 | Link | ||
Nevertheless, you're right, it seems a bit much to require end users to install an SDK. Quote:
Thank you for the important test results! Last edited by Guest; 17th February 2014 at 16:05. |
17th February 2014, 16:08 | #28 | Link |
The documentation explains that "hw" is an integer offering various choices and not a boolean. "hw" is renamed as "engine" for DGDecIM, and if you understand it that way I'm sure the confusion will dissolve away.
17th February 2014, 18:06 | #29 | Link |
Here is beta 2 with expanded engine options. You can force SW for Intel, for example.
http://neuron2.net/misc/dgdecodeim_b2.zip @Reel.Deel This should fix your issue. I expect it to work either with Intel auto or Intel SW in your system. Please advise your results. EDIT: Please use beta 3 and make sure you have libmfxsw32.dll co-located with dgdecodeim.dll. Last edited by Guest; 17th February 2014 at 19:58. |
17th February 2014, 18:24 | #31 | Link | |
This will be moot soon as I am working on the stand-alone indexer. |
17th February 2014, 19:19 | #32 | Link | |
17th February 2014, 19:27 | #34 | Link |
engine=2 works fine for me. Do you have the libmfxsw32.dll in the same place as dgdecodeim.dll?
I have added the libmfxsw32.dll to the ZIP and revised the Notes to mention it. If this turns out to be the reason for your crash I will fix up the error checking to be a little more helpful. Last edited by Guest; 17th February 2014 at 19:34. |
17th February 2014, 19:41 | #36 | Link | |
Here's the crashinfo from VD. |
17th February 2014, 19:48 | #38 | Link |
Here is beta 3 with the correct dll loading code. Now the libmfxsw32.dll can be put with dgdecodeim.dll and you don't need to put it in the system directory.
http://neuron2.net/misc/dgdecodeim_b3.zip Thanks again for your test results. |
17th February 2014, 19:50 | #39 | Link |
For whatever it's worth, the Intel SW engine has all the same problems (lockup stepping backward and returning at least part of the the video offset by 1 frame) as the HW engine that I detailed in this post.
17th February 2014, 19:52 | #40 | Link | |
