Old 10th October 2019, 09:41   #1061  |  Link
expanseFan
Originally Posted by stax76 View Post
That are many questions for one post. :-)
Yes, for PAL DVDs using MakeMKV has some advantages.
I'll try that, thanks, never heard of MKV before. I suppose it converts the entire VIDEO_TS folder into one MKV file (losslessly)?
Indeed, too many questions, I hope you can answer as many as you can, WHENEVER you have the time of course! (they are at a descending order of importance to me).
Also, I'd like to congratulate you for the great work you're doing with StaxRip, it's an exceptional tool for encoding my videos. Although, I'm a newbie, I prefer StaxRip over Handbrake due to its better performance, ability to trim video(with preview) and the fact that it has many filters available with VapourSynth and AviSynth.
P.S. I like that you frequently update StaxRip to latest x264, x265, NVENC, ffmpeg, etc. Don't want to rush you, but are you planning to release a new stable soon? Couldn't find your beta builds, are they stable enough for encoding without errors?
expanseFan is offline
Old 10th October 2019, 15:06   #1062  |  Link
TomSmith
Ryzen3000/Navi10 - Enc
I used StaxRip for some time with my Intel/Nvidia Setup.
As I changed my hardware to AMD Ryzen3000/Navi10 I noticed that VCEEnc seems to be outdated. Is it that Rigaya stopped development by the end of 2018? I do hope that this is not the case...
If it really is, is there another Enc that should be used with AMD CPU/GPU?
Thank you very much,
Tom
TomSmith is offline
Old 10th October 2019, 16:49   #1063  |  Link
NikosD
Rigaya is like Frank (stax76)
He never stops development.
Unfortunately AMD stopped development of its SDK called AMF.
Take a look at GitHub of AMD AMF and I think you will conclude the same think.
I don't think you will find a better encoder, try ffmpeg with built-in AMD encoder to see if there is something more to add to VCEEnc.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 11th October 2019, 17:18   #1064  |  Link
TomSmith
TomSmith is offline
Old 12th October 2019, 00:52   #1065  |  Link
Atlantis
If we have 2 instances of Staxrip, is it possible to have 2 Job Lists?
At the moment we have only one Job List. I think it is important to be able to tell which instance should get which job.
Sometimes you have long encodes that you want in one instance and other short encodes that you want in a second instance.
Atlantis is offline
Old 12th October 2019, 01:43   #1066  |  Link
stax76
stax76's Avatar
No, it's always shared.
stax76 is offline
Old 12th October 2019, 01:58   #1067  |  Link
Atlantis
Makes sense to be able to separate them if it's easy to do.
Atlantis is offline
Old 12th October 2019, 02:17   #1068  |  Link
jlw_4049
I think temporary workers similar to MeGui would work instead of two seperate UIs.
Sent from my SM-G965U1 using Tapatalk
jlw_4049 is offline
Old 12th October 2019, 02:33   #1069  |  Link
Atlantis
I finally switched to VapourSynth to do my encodes and just found out that there is no FFT3DFilter in VS menus. I can see that it exists in the plugin directory of VS.
I used it in Avisynth alot and found it very useful.
Atlantis is offline
Old 14th October 2019, 00:33   #1070  |  Link
Atlantis
I am using MCTemporalDenoise in VapourSynth and I get this message
Script exceeded memory limit. Consider raising cache size.
The encoding still continues and finishes. Do I have to do something? Is something wrong?
Atlantis is offline
Old 14th October 2019, 01:30   #1071  |  Link
stax76
stax76's Avatar
http://forum.doom9.net/showthread.ph...25#post1874625
stax76 is offline
Old 14th October 2019, 01:53   #1072  |  Link
Atlantis
core.max_cache_size =xxxx
But I have no idea what I should put in xxxx and is it necessary? I prefer not to add things and not to complicate. It already encodes, does it mean that it is encoding incorrectly?
Atlantis is offline
Old 14th October 2019, 02:18   #1073  |  Link
stax76
stax76's Avatar
It's documented here:
http://www.vapoursynth.com/doc/pytho...max_cache_size
If search don't help you can ask in the VapourSynth thread, I'm not really an expert in VS because I'm retired from encoding...
stax76 is offline
Old 14th October 2019, 04:18   #1074  |  Link
imhh11
I use core.max_cache_size = 8192 for my fmtc script and the warning is gone
imhh11 is offline
Old 14th October 2019, 04:27   #1075  |  Link
Atlantis
Thanks
I'm asking this question in here because it concerns the entire pipeline which staxrip uses. It's about MCTemporalDenoise.
I'm using MCTemporalDenoise to process some HDR 10bit video. I look at MCTemporalDenoise script and it's dated 2010, 9 years ago.
Safe to say that there was no HDR back then. I just want to be sure that if I use MCTemporalDenoise inside staxrip and feed it a 10bit clip,
it will not get converted to 8bit or a lower color space inside the pipeline, right? Is it HDR 10bit compatible?
Atlantis is offline
Old 14th October 2019, 13:31   #1076  |  Link
ZeroCool22
ZeroCool22's Avatar
Question:
In VBRHQ
If we have checked "Constant Quality Mode" we must deactivate the other options or can have AQ checked too?
ZeroCool22 is offline
Old 14th October 2019, 20:21   #1077  |  Link
Patman
Patman's Avatar
Originally Posted by ZeroCool22 View Post
Question:
In VBRHQ
Hi Zero,
default setting for --aq is off (look here) but the AQ-option can also be enabled.
Tools for StaxRip | x264 - x265
Patman is offline
Old 15th October 2019, 01:59   #1078  |  Link
Natty
Noob
Safe to say that there was no HDR back then. Is it HDR 10bit compatible?
avisynth+ or HBD weren't introduced at that time afaik. you might need to look at some another denoiser
Natty is offline
Old 15th October 2019, 18:49   #1079  |  Link
expanseFan
Hello, I have a problem about deinterlacing with VapourSynth in StaxRip. I want to use QTGMC without doubling the framerate. In order to do that, in Avisynth I simply add SelectEven() below QTGMC. In VapourSynth, how do I do that? I tried several combinations(SelectEven(), clip = havsfunc.SelectEven(), clip = havsfunc.SelectEven(clip)) but nothing works. How can I use it? Is there an alternative to QTGMC but one that's better quality from yadifmod?
Old 15th October 2019, 18:55   #1080  |  Link
stax76
stax76's Avatar
I think you want SelectEvery.
http://www.vapoursynth.com/doc/funct...lectevery.html
stax76 is offline
aac, hdr, hevc, nvenc, staxrip, x264, x265
