4th April 2012, 22:24 | #1144 | Link | |
Also I should say, for those who are not so familiar with the SVP libraries, that there's no GPU reason to use SVP for (Q)TGMC or similar. The only GPU code in SVP is for rendering the final frames when doing frame interpolation. It's the updates to the motion analysis that interest me, the reworked version of MVTools, and whether it improves quality or speed. However, that part is all CPU code. Last edited by -Vit-; 5th April 2012 at 00:15. |
5th April 2012, 02:22 | #1145 | Link |
After reinstalling Windows 7, putting avisynth and its other components back together, as well as messing around with a dozen or so scripts, I successfully deinterlaced HD video (with both single-threading and multi-threading) and saved the results in a lossless format. With some additional work I managed to get my lossless file (using the lagarith codec) to be read by my other video editors as well as have the audio embedded AND in sync with the footage. My HD footage is also rid of that strange slowed playback.
Though I may have solved a big portion of my original problems, I am now faced with the dilemma of how I should go about setting up QTGMC. QTGMC has so many options that I can set and change, I tend to go overkill with my settings. For example, I tend to set my SD footage on “Placebo” or “Very Slow” to insure that I am not cutting corners with making the video look as good as it can (without attempting to go overboard with the settings, ironically). Like many others, I strive to get the best quality, but as others have responded, overkill or complicated setups add a large amount of extra time for little if any noteworthy improvements. So my question is: what are good scripts I could use that would yield the most noticeable and beneficial results but wouldn’t go overboard in encoding time for trivial quality improvements? Could someone provide me with a foundation for my presets for a general type of situation? For example, how should I go about deinterlacing HD video captured in a low light situation and has a good amount of noise (as well as SD footage with the same situation)? What about situations where there is little noise because it was recorded outside with plenty of light? I’m not sure how deeply probed my question will be, but I’m hoping to find scripts that will generally provide great quality outputs for general situations (low noise vs. high noise footage, high motion [sports] vs. typical motion footage [but not static]). |
5th April 2012, 03:53 | #1146 | Link | |
Programmer
Your guide is the most detailed I have found - Thanks!. After further looking into AVCHD spec, I realize I need to go to 720 60p as my target for Bluray acceptance. I assume since my target is Bluray for my material and not the web, that a few things from the guide would be modified. For example: ColorYUV(levels="PC->TV") - I assume this would be commented out since my target space is bluray to be rendered on an LCD. Then there is the resolution. Since Bluray official spec does not support AVCHD in 1080 60p (AVCHD 1.0 spec), then I would resize to 720p and use (matrix="PC.709") I assume your guide as is produces 30p and AVCHD spec calls for 59.94 progressive. So if I wanted 60p, then I would leave out FPSDivisor=2 in the deinterlace. Is that correct? Also the AVCHD spec shows progressive supported rate as 59.94, I assume when we see 60p that is just a misnomer from rounding up? One thing from your guide that was confusing was this part: "I am working with HDV 1080-60i, so I started with the HDV 1080-60i (1440x1080, 29.970 fps) template" I not sure I understand, if source is 1080-60i, then wouldn't fps be 59.94 not 29.970? And in screen shot the deinterlace method is set, shouldn't this be disabled since AVISynth script is doing the deinterlace? Then again my m2ts file from my Panny that was recorded in 1920x1080 60i shows fps as 29.970 in mediainfo, so I am confused as it is 60i not 30i MediaInfo from HD Camcorder file for 60i: Code:
Width : 1920 pixels Height : 1080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First remove QTGMC and remove AssumeTFF/BFF then do: ConvertToYV12(interlaced=false, matrix="PC.709") Since target is Bluray then I would think a better CRF value for x264 should be used. I would think 16 would be a good choice. Do you have experience in CRF values for Bluray output? |
5th April 2012, 09:18 | #1147 | Link | ||||||||
partially-informed layman
AviSource("d:\fs.avi") Spline36Resize(1280,720) Quote:
Having said all of that, it looks like your camera is actually shooting 1920x1080-29.97i (29.97 frames per second, 59.94 fields per second). That spec is supported by Blu-ray, so that's what you should put on Blu-ray without deinterlacing or resizing. If you're not color correcting or adding FX you may be able to put it directly on Blu-ray without any recompression if your authoring software is clever enough. |
5th April 2012, 09:54 | #1148 | Link | |||
Programmer
From the AVCHD page it mentions - "Although AVCHD shares many format similarities with Blu-ray Disc, it is not part of the Blu-ray Disc specification." But I think where AVCHD aligns with BD spec, as you say it should be compatible without any conversion. I'll just have to give it a try. For interlaced it should work, but for 60p that will have to be scaled down to 720 60p for Bluray disc support. I will be using Vegas program to author the BD disc. In some cases I will want to edit the video and cut out unwanted sections, thus in this case I would need to render and rencode with x264 and its probably best then that I deinterlace before reencode. Is that a correct assesment? Quote:
5th April 2012, 10:00 | #1149 | Link | |
5th April 2012, 14:10 | #1150 | Link | ||
5th April 2012, 20:15 | #1151 | Link | |
Programmer
In regards to nhope guide:
With your explanation and this guide, it clears things up for me. To simplify, when the video is expressed as progressive then the number is Frame Rate. If its interlaced video then its up in the air as to which one is being used (frame vs field). It seems as you said in the case of camcorder manufacturer. they generally refer to it as field rate (example 60i), but the frame rate of that 60i is 29.97 and thusly represented as such when looking at mediainfo for the interlaced clip. The Bluray spec supports 1920x1080 60i (29.97 fps) while AVCHD spec does not. But this is easily solved by mastering the content to Bluray rather than an AVCHD BD disc. However, 1080 60p is not supported by either Bluray spec or the AVCHD 1.0 spec. Bluray supports only 24p in 1080 and supports 60p in 720. So resizing is neccessary for Bluray compliance. What is confusing to me is why HD Camcorder manufacturers would even bother offering interlaced recording modes when all modern digital displays are natively progressive and can not display interlaced. What is the reasoning behind offering interlaced recording on HD Camcorders? Last edited by jfcarbel; 5th April 2012 at 20:17. |
5th April 2012, 20:38 | #1152 | Link | |
Programmer
Or is the only reason to deinterlace is because of the neccessity to resize? That is, if resizing interlaced material then must deinterlace first. So if keeping the original resolution then do not de-interlace. Correct? To deinterlace or not? Of course I have heard the argument from both sides. In one case someone states that the software deinterlacer of QTGMC will do much better then a TV deinterlacer. But then there is the camp that states that once you deinterlace you are altering the content and can never get it back and that TV deinterlace alogorithms will most likely improve as technology progresses so archive it the same as the source if possible. I also have some projects in which I will be encoding DV video (YV12 from my codec) into H.264 and it was also suggested that in addition to deinterlace improving SD video quality before encode that QTGMC would also clean up some of the SD noise before the encoding and provide better PQ. So maybe for HD Camcorder video I only deinterlace when neccessary but deinterlace for SD video coming from older (8-9 yrs old) MiniDV 8mm tapes. Anyone else have comments or thoughts on this? Last edited by jfcarbel; 5th April 2012 at 22:13. |
6th April 2012, 03:35 | #1156 | Link |
Thanks -Vit-! I've been meaning for some time to test drive your tool. I've heard a lot of great things about it and if it lives up to its billing I'm hoping it will improve some of my slo-mo swimming vids via high-quality bobbing.
6th April 2012, 13:15 | #1157 | Link | ||
It certainly seems to me that downsizing to 720 just so you can get a Blu-ray-compatible progressive stream is an inferior approach to letting the playback hardware do its thing with a 1080i stream. Quote:
6th April 2012, 17:23 | #1158 | Link | |
Programmer
But I changed course after you made a light bulb go off in my head and that is there is no reason I can't just author a standard Bluray and avoid AVCHD format on Bluray. So I will not be resizing the interlaced 1080 60i and leave as 1080. But I will need to resize the 1080 60p since that is not on Bluray spec, but then there is no deinterlace involved for that. |
6th April 2012, 17:43 | #1159 | Link | |
____ SubJunk has now kindly hosted all the main QTGMC files, so there are now more mirrors on the first post. It's particularly useful at the moment given the ongoing filehosting problems. |
6th April 2012, 18:26 | #1160 | Link |
Hi, long time lurker here - first time poster. I'm having problems getting some home video smoothly rendered with QTGMC. It looks very good until I do any sideways panning, which ends up being a bit .. uh, not really sure how do describe it. It isn't really stuttering, but it isn't a very smooth pan either (it scrolls, then pauses a tiny bit). I've spent countless hours rendering after minor changes, but whatever I do - I end up getting either the same result, or a worse one. Hoping somebody more wizened than me could be bothered to lend a hand!
The camera I've shot the footage with, is a Sony HDR-SR12, file properties of the MTS source files in Sony Vegas shows: Type: MPEG-2 Transport Stream Streams Video: 00:01:07,600, 25,000 fps interlaced, 1920x1080x12, AVC I render these out from Sony Vegas with Lagarith, 25fps, upper field first, from a project set to 25 fps, UFF, 32 bit floating point (full range) pixel format, best rendering quality and deinterlace method set to none I use this AVS script: AVISource("F:\DigiVidCam\20101205-20101212-Tenerife\render\ForDoom9\test.avi", audio=false).AssumeFPS(25,1) AssumeTFF() QTGMC( Preset="Very Slow" ) with this x264 configuration: Const. quality 20, default tuning, high AVC profile, unrestricted/autogess AVC level, default target playback device, with the Very Slow preset I rendered a short clip from this, which can be downloaded from here (4,3 MB): magnet:?xt=urn:btih:5B7EC313B1C27B04A5E9B14EDC9E693BBDD4FB92&dn=test.mkv&tr=udp%3a//tracker.openbittorrent.com%3a80/announce It's not too bad, but not really smooth either. The Lagarith source is here (121 MB): magnet:?xt=urn:btih:9BA4627588689B3CDE0CD7677711C963EC0F6F41&dn=test.avi&tr=udp%3a//tracker.openbittorrent.com%3a80/announce I've tried to render it to different formats, but I'm stuck with the same motion. At this point, I'm not really sure if it's the equipment, if it's shaky cam or if it's really just deinterlacing problems. Hope somebody can hint me in the right direction if it's the latter! I'm sooo tired dealing with deinterlacing, that I'm gonna get a new cam (perhaps Sony HDR-CX260V), but I've got a load of footage that I haven't rendered out yet - and some footage I have rendered but I'm not completely satisfied with it. |
