Old 25th December 2016, 04:49   #121  |  Link
shaolin95
Originally Posted by toniash View Post
A guy (igv) ported and improved this shader for the mpv hook system:
https://gist.github.com/igv/8a77e4eb...bb94c1c50c317e
I don't really know what he improved but it looks amazingly on my sister's laptop with a weak intel hd3000 iGPU. The two-passes version is too intensive!
(From Madvr thread)
Where do you place this file to work with mpv (SMPlayer)? I have been using it with MPC-HC but wanted to try mpv as it seems to be better for SVP.
Thanks
shaolin95 is offline   Reply With Quote
Old 25th December 2016, 08:56   #122  |  Link
toniash
Thanks
vo=opengl-hq:backend=angle:scale=ewa_lanczossharp:cscale=ewa_lanczossoft:interpolation:tscale=mitchell:tscale-clamp:temporal-dither:user-shaders="~~/shaders/adaptive-sharpen.glsl"
toniash is offline   Reply With Quote
Old 25th December 2016, 17:20   #123  |  Link
shaolin95
Sorry for the dumb question but is my first time using mpv.
Will I add in the same section I add this line for SVP "--input-ipc-server=mpvpipe" as shown on this guide?
https://www.svp-team.com/wiki/SVP:SMPlayer
Old 27th December 2016, 18:21   #124  |  Link
toniash
yes
Old 27th December 2016, 18:32   #125  |  Link
shaolin95
yes
I must be doing something wrong cause I just get an error. I was dropping the script file in the root directory of the mpv64 folder (inside of the SVP folder).
Is that what I am doing wrong?
Old 27th December 2016, 20:00   #126  |  Link
toniash
Then I think you need "user-shaders="~~/adaptive-sharpen.glsl"
Good luck!
Old 30th December 2016, 09:08   #127  |  Link
toniash
Good luck!
Did it work?
Old 30th December 2016, 14:47   #128  |  Link
shaolin95
Did it work?
I didn't get an error but I do not see any effect on the screen so is not working
Thanks though, I just didn't want to keep bugging you.
Old 30th December 2016, 15:51   #129  |  Link
toniash
#define curve_height .96
// Main sharpening strength, POSITIVE VALUE ONLY! // 0.3 <-> 1.5 is a reasonable range of values
what value do you use?
Old 30th December 2016, 16:29   #130  |  Link
shaolin95
I didn't change it at all just let the script untouched. I'm just not sure I'm putting the file in the right folder maybe.
I will take some screenshots of my config and post.
Thanks!
adaptive sharpen, shader, sharpening
