#1 | Link |
[bug?] x264 --seek xx --frames yy
x264 core:104 r1713 c276662
ffms input === x264.exe --preset slow --crf 18 --seek 200 --frames 300 --output film.h264 film.mpg result film does not start from 200th frame, as in: x264.exe --preset slow --crf 18 --output film.h264 film.avs AVS: LoadPlugin("ffms2.dll") FFVideoSource("film.mpg") Trim(200,499) its start from ~216 frame... why? its a bug or any coeffecient exist which i must to apply to command line, if dont use avisynth? Also, i think "--frames" dont work fine - but its may be because "--seek" dont work as i want Last edited by PopovN; 16th September 2010 at 10:38. |
#2 | Link |
Try adding --demuxer lavf to the first command line.
http://www.7-zip.org/ |
#3 | Link | |
lavf - frame-accurate, but with it i cant use "--vf crop:0,66,0,66" it say "crop [error]: top crop value `66' is not a multiple of 4"....
with mode4 crop it works, bat also it say: Quote:
Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=1, N=25 Bit rate mode : Variable Bit rate : 4 829 Kbps Width : 704 pixels Height : 576 pixels Display aspect ratio : 4:3 Pixel aspect ratio : 1.091 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.476 Last edited by PopovN; 16th September 2010 at 11:03. |
#4 | Link |
Add or subtract an extra 2 lines to the crop, 64 or 68. You might have a problem with this, but honestly, it's only 2 lines.
Not sure on the max_analyze_duration. It might go away if you use --no-interlaced. The source is obviously flagged as interlaced, which is screwing this around. Try adding --no-interlaced with the first command line you posted above and see if that works. If not, also add the --demuxer lavf again and see if that works. Personally, I wouldn't worry about errors such as max_analyze_duration, unless you see problems with the output of x264.
#5 | Link | |
but i worry about "[mp2float @ 014d4010] incorrect frame size" it red-colored and it exist with or without "--vf crop" in result file visually cant see any artifacts |
#6 | Link |
mp2 is audio.
If you can't see any artifacts and the --seek and --frames parameters work as expected, then problem solved imo. Although, it can't hurt to post the file you're having problems with, or a short sample that still produces the problems you're experiencing so that someone can have a look at it properly and maybe resolve the issue x264 is having with this file. It sounds like there is something wrong with the way that file was created.
#7 | Link |
O.. thank you )) ... i sow "mp2" as "mpeg-2" .. as video..
problem is solved as problem with seek but not as problem with ffms i think.. Thank you for your ansvers ... but... i come back to avisynth - i need crop .. Last edited by PopovN; 16th September 2010 at 11:55. |
#8 | Link | |
Compiling Encoder
in this case lavf seems to be returning that the video is interlaced so combined with the fact the video is YV12, you need to crop height in increments of 4. |
#9 | Link | |
but i want to frame-accurate seek and non-mode4 crop - so i need to come back to more-"slow" avisynth-way ![]() In ffms-input mode2 crop is very well ... but without frame-accurate (( Last edited by PopovN; 16th September 2010 at 14:09. |
#10 | Link | |
Compiling Encoder
if your source is not interlaced then add the --no-interlaced option and this should allow you to crop by mod2 values in x264's crop filter. if your source is interlaced, then cropping by mod2 values will distort the picture. |
#11 | Link | |
Is that with the --no-interlaced option, or as per your initial post?
bug, ffms, seek, x264 |
