#221 | Link | |
%ffmpeg_path% -drc_scale 0 -i %input_path% -map 0:%ID% -filter_complex "pan=7.1|c0=c0|c1=c1|c2=c2|c3=c3|c4=c6|c5=c7|c6=c4|c7=c5" -rf64 auto -c pcm_s24le %TEMP%temp.wav This whole story got me curious and I checked an original BD with a 7.1 EC3 track and the channels are also out of order.. seriously Dolby wtf? https://slow.pics/c/diDhad6t Last edited by Kuler087; 23rd September 2022 at 19:09. |
#222 | Link | |
I imagine this is why most Blu-rays have no EAC3. And of course EAC3 having AC3 inside. |
#225 | Link | ||
SuperVirus
1)
«Your software patents have expired.» |
#226 | Link |
First of all what is this:
L R C LFE Ls Rs Tfl Tfr Never saw it on blu-ray, nor did I ever see Bit rate: 1 512 kb/s for eac3. Duration: 4 h 2 min on Blu-ray was also a shock, but yeah, long movie... There is no EAC3 sound on Blu-ray... There is AC3 core on your sample in my DM. So that at leasy checks out (00001F47 strmtyp: 1 (0x1) - (2 bits)): Type 1: These frames comprise a dependent substream. The programme shall be decoded in conjunction with the independent substream with which it is associated. Last edited by Balling; 26th September 2022 at 04:20. |
#227 | Link |
Life's clearer in 4K UHD
Are you referring to EAC3 being present on a particular Blu-ray disc or EAC3 (without an AC3 core) being available on the Blu-ray format in general? If it's the latter then you are wrong...
#228 | Link |
![]() Join Date: Feb 2005
The same than (L R C LFE Ls Rs Vhl Vhr) a EAC3 channel map than can be obtained with Audition 2017.
And is played in my AVR like it was a Atmos 3D 5.1.2 front Of course aren't in BD's but if Atmos tracks are recoded to (L R C LFE Ls Rs Vhl Vhr) can save space and sended by SPDIF (my TV SAMSUNG player to AVR-DENON). It is my only interest in eac3 8 channels, for me 2D 5.1 and 7.1 are the same.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 26th September 2022 at 11:44. Reason: add info |
#229 | Link | |
https://www.blu-ray.com/movies/Zack-...lu-ray/288273/ |
#231 | Link |
BTW, "C:\tmp\Plex\Plex Media Server\Plex Transcoder.exe" -c:a pcm_s24le -i "C:\Users\Pepe\Core.wav" -eae_root C:\Users\Pepe core.eac3
This command uses -c:a pcm_s24le, but it is not needed here, wav encoding defaults to 24 bit to flac, eac3, truehd (with newer ffmpeg with activated 24 bit TrueHD that is). No, the only time it is needed is if you decode .thd to wav or .eac3 to wav. BTW, I still think drc_scale and normal native ffmpeg should be used to decode. Last edited by Balling; 27th September 2022 at 14:22. |
#233 | Link | |
#234 | Link | |
#235 | Link |
Some off topic posts moved to https://forum.doom9.org/showthread.php?t=184364 and https://forum.doom9.org/showthread.php?t=184175
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 29th September 2022 at 15:13. |
#236 | Link | |
#237 | Link |
BTW. Be careful with leaked Dolby media encoder. It does not produce lossless TrueHD with stereo wav (it is mostly lossless though, I tried Plex decoder of TrueHD and ffmpeg's), did not check what happens with leaked Encoding Engine.
#239 | Link |
SuperVirus
Friendly reminder that the title of this thread is
"Looking for a(n) eac3 7.1 encoder". Also, it is not safe to discuss wärexxx on this board :-|
«Your software patents have expired.» Last edited by filler56789; 2nd October 2022 at 07:20. Reason: grammar |
#240 | Link | |
eac3 |
