Old 30th April 2006, 15:03   #1  |  Link
mpucoder
7 color subpicture
We've know all along that the spu command for doing fades and wipes could also allow more than 4 color subs, but it took this long for me to finally make one with the upcoming MuxMan 0.18
@jeanl - this should give you something to play with
mpucoder is offline   Reply With Quote
Old 30th April 2006, 20:47   #2  |  Link
mpucoder
Here's what it looks like:
Old 30th April 2006, 21:34   #3  |  Link
dirio49
JuSt a PoWer uSEr
how come in dvdsubedit I only see red, white and blue?
I can read the text, but the colors just repeat.
Birthdays are good. Statistics show that the people who have the most live the longest.
dirio49 is offline   Reply With Quote
Old 30th April 2006, 21:58   #4  |  Link
gabest
gabest's Avatar
mpucoder:
The size of the packet is set to 0x0A49 while it is only 0x0A48, this might make decoders which check the size reject it as invalid. My decoder cannot handle CHG_COLCON, but that was only the third obstacle. The first one was this length mismatch, and also the dvd navigator will only send that one video frame once and never again when the subpic would be shown, so it doesn't have a chance to paint it over the picture.
gabest.org
gabest is offline   Reply With Quote
Old 1st May 2006, 01:46   #5  |  Link
mpucoder
I'll fix the size and try it again (and replace the download). Yes, it can be a torture test, but changing subpictures over stills is allowed.
@dirio49 - DVDSubEdit does not process the command which makes this possible (CHG_COLCON). It's a tricky command to process. The way I do it is to map the entire subpicture into one byte per pixel, then for each rectangle in the CHG_COLCON I add the four new color/contr values to a table of 256 color/contr pairs, and add the base index (the one for the BG color) to every pixel in the area. This allows 64 rectangles maximum.
Old 1st May 2006, 01:57   #6  |  Link
mpucoder
Thanks to Gabest for spotting the error. btw, the size should always be a multiple of 2. Now it does work in PowerDVD and Nero Showtime.
I've uploaded corrected files.
Old 1st May 2006, 04:19   #7  |  Link
jeanl
jeanl's Avatar
Yes, DVDSubEdit does not process the command. It does parse it, but it does nothing with it, it won't show it the way it should and you won't be able to edit it ...
It would be a significant rewrite to add that, and I'm reluctant to undertake such a task!
Jeanl
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 1st May 2006, 20:30   #8  |  Link
kumi
Straight to video
kumi's Avatar
Very cool! Intervideo decoder doesn't play this either. I think it has a problem with CHG_COLCON + stills, because my fade/wipe tests always worked on video, but never with stills.
mpucoder: Do most standalone players correctly process CHG_COLCON commands?
kumi is offline   Reply With Quote
Old 1st May 2006, 22:49   #9  |  Link
mpucoder
AFAIK they all process the command correctly.
Old 2nd May 2006, 00:04   #10  |  Link
jeanl
jeanl's Avatar
Kumi, you can do wipes and fades without the CHG_COLCON command, wipes and fades require timed DCSQTs with commands to change the transparencies, or the subpic position. The CHG_COLCON isn't necessarily required for that, although it gives you a lot more freedom.
jeanl
Old 2nd May 2006, 00:09   #11  |  Link
mpucoder
Someday I will do the ultimate test of CHG_COLCON - all 256 combinations of color and contrast. (Although one can only see 240, as it doesn't matter which of the 16 colors is used when the pixels are transparent)
Old 2nd May 2006, 01:09   #12  |  Link
jeanl
jeanl's Avatar
The ultimate test of CHG_COLCON by the ultimate geek!
(mpucoder I'm just kidding, I hope you know that! we're all aspiring to your degree of geekness! )
jeanl
Old 2nd May 2006, 01:12   #13  |  Link
jeanl
jeanl's Avatar
mpucoder, out of curiosity, what's the app that you showed us a screenshot of? Is it the latest muxman? You're gonig to add subpic feature to it?
Did you construct your example by hand, or did muxman come up with it automatically, figuring out how to tile the screen to distribute all 6 colors appropriately? That would be fairly smart!
jeanl
Old 2nd May 2006, 02:05   #14  |  Link
mpucoder
yes, MuxMan 0.18's viewer/editor can display subs, and when finished will be able to make menus (subs and highlight) - lots of new Windowy things like rubberband rectangles, alphablending, and it is even multi-threaded.
yes, this one was created with a hex editor from a 4 color spu to test the decoder.
jeanl
Yes it would - and maybe later when 1.0 is finished I will try something like that. But for now the most sophisticated part of creating a CHG_COLCON command will be using the mouse to draw the rectangles.
Old 14th March 2007, 23:00   #15  |  Link
Paddington
Author of SubtitleCreator
Paddington's Avatar
@mpucoder
I've been playing with your example and after demuxing it with PgcDemux, can already read it properly in the current version of SC. However, I was having a problem when using muxman (v0.15Q) to recreate the DVD again - using PgcDemux's output, muxman only gives me a very small 'movie', with no subtitles and which immediately stops. My question therefore is: does muxman 0.15Q support sups with a CHG_COLCON? I can already generate them too, but have no way to test if I do it correctly (except my own routine, which works, of course :-)
Thanks in advance!
Paddington is offline   Reply With Quote
Old 15th March 2007, 04:49   #16  |  Link
mpucoder
MuxMan does not interpret sup files other than to determine the duration. The problem you're having is the example uses a slideshow, so after demuxing all you have is a single frame m2v. Set the video duration to a longer value, 2 minutes was used in the example. Here is the script used to create the example:
Section=Settings
	Destination Folder=D:\VIDEO_TS
	Item=Palette
		Name=DefaultPalette
		Color 0=0, 0, 255
		Color 1=255, 0, 0
		Color 2=0, 0, 0
		Color 3=255, 255, 255
		Color 4=0, 255, 0
		Color 5=255, 0, 255
		Color 6=255, 255, 0
		Color 7=0, 125, 125
		Color 8=125, 125, 125
		Color 9=225, 225, 225
		Color 10=125, 0, 0
		Color 11=0, 125, 0
		Color 12=0, 0, 125
		Color 13=222, 0, 255
		Color 14=222, 125, 0
		Color 15=125, 0, 125
Section=Content
	Item=Segment
		Name=Segment_1
		Display Mode=Only Letterbox
		Resolution=none
		Force=No
		Item=Video Stream
			Coding Mode=Mpeg-2
			Standard=NTSC
			CC Field 1=No
			CC Field 2=No
			Item=Video Play
				File=D:\MuxSources\[1]_vts_01_1.m2v
				Start=00:00:10:01
				Duration=00:02:00:00
		Item=Sub-Picture Stream
			Stream Number=1
			Language=en
			Language Extension=1
			Display Mode=Wide/Letter
			Item=Sub-Picture Play
				File=D:\MuxSrc2\6colors.sup
				Time Code=NTSC non-drop
				Start=00:00:00:00
				Display=00:00:00:00
				Duration=00:00:00:00
		Item=Scene List
			Item=Scene
				Name=Segment_1_scn1
				Scene Time=00:00:00:00
				Uop=00000000
Section=Navigation
	Item=First PGC
		Name=FP
		Menu ID=No Menu
		Uop=00000000
		PG Playback Mode=Sequential Playback
		Repeat Times=0
		PGC Still Time=0
		Palette=DefaultPalette
		Item=Pre Commands
				JumpTT VTS01_TTL01
		Item=Post Commands
		Item=Cell Commands
		Item=Program List
	Item=VMG
		Item=Language
			Name=Unspecified_0
			Language=unspecified
			Item=PGC
				Name=Unspecified_title
				Menu ID=Title Menu
				Uop=00000000
				Next PGC=
				GoUp PGC=
				Repeat Times=0
				PGC Still Time=0
				Item=Pre Commands
						JumpTT VTS01_TTL01
				Item=Post Commands
				Item=Cell Commands
				Item=Program List
	Item=VTS01
		Item=Language
			Name=Unspecified_1
			Item=PGC
				Name=Unspecified_root
				Menu ID=Root Menu
				Uop=00000000
				Next PGC=
				GoUp PGC=
				Repeat Times=0
				PGC Still Time=0
				Item=Pre Commands
						JumpVTS_TT VTS01_TTL01
				Item=Post Commands
				Item=Cell Commands
				Item=Program List
		Item=Title
			Name=VTS01_TTL01
			Uop=0
			Item=PGC
				Name=VTS01_TTL01_PGC1
				Menu ID=Title Entry
				Uop=00000000
				Next PGC=
				Prev PGC=
				GoUp PGC=
				Repeat Times=0
				PGC Still Time=0
				Item=Pre Commands
						SetSTN subpicture=1:ON
				Item=Post Commands
				Item=Cell Commands
				Item=Program List
					Item=Program
						Name=VTS01_TTL01_pg1
						Item=Cell
							Name=VTS01_TTL01_cell1
							Linked Scene=Segment_1_scn1
							Command=
							Cell Still Time=0
							VOBU Still Flag=False
							Access Restriction Flag=Permitted
							Cell Type=0
							Seamless Flag=default
			Item=Part of Title List
				Item=VTS01_TTL01_pg1
Old 15th March 2007, 22:38   #17  |  Link
Paddington
Paddington's Avatar
@mpucoder
Thanks for that, but it still doesn't quite work - although IfoEdit shows the subtitle is there, it doesn't display it. In addition, after demuxing and muxing back, the final result has become smaller.
Here is a list of my PgcDemux 1.2.0.5 demuxed files:
15/03/2007 22:32 0 Celltimes.txt
15/03/2007 22:32 1,169 LogFile.txt
15/03/2007 22:20 3,541 MyMuxManProject.mxp
15/03/2007 22:32 2,642 Subpictures_20.sup
15/03/2007 22:32 47,803 VideoFile.m2v
And the muxed files:
15/03/2007 22:20 8,192 VIDEO_TS.BUP
15/03/2007 22:20 8,192 VIDEO_TS.IFO
15/03/2007 22:20 14,336 VTS_01_0.BUP
15/03/2007 22:20 14,336 VTS_01_0.IFO
15/03/2007 22:20 542,720 VTS_01_1.VOB
Which is a bit smaller than your original (was 544.768). I've attached the final result, as well as the sup file. Do you have any idea what I am doing wrong?
Old 15th March 2007, 22:44   #18  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
IfoEdit has several problems when displaying the subpics. Don't trust it! Use a better software player, or burn a RW and test on a good standalone.
r0lZ
Old 16th March 2007, 04:12   #19  |  Link
mpucoder
Well, that mux is not right, don't know where the subs came from. I tested 15Q using video demuxed from your vob and the sup file in your zip. Worked correctly, so maybe you have a bad download. Here's all I did:
1) open video file, set duration to 2 minutes
2) open .sup file as first subpicture file
3) mux
no chapter points are needed. All the navigation you see in the project file is default generated by MuxMan.
Old 18th March 2007, 19:17   #20  |  Link
Paddington
Paddington's Avatar
@mpucoder
I've created some sup files with region (CHG_COLCON) encoding, but muxman 0.15Q does not process them well, and it crashes or hangs. This might well be due to my incorrectly formatted sups, but ReJig did handle them well, and created a DVD that played correctly in IfoEdit. The main difference with yours is that it contains a stop time. Would you please have a look at them and tell me what's wrong. Thanks a lot!!!
PS regionTest1 and regionTest5 contain 1 and 5 subpictures, respectively, with 1 and 3 regions (all in separate subpictures).
