Old 5th August 2021, 11:21   #161  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
contrasharpening function was fixed to either use spatial or temporal limiting.
Which are the best case scenario to choose from spatial or temporal?
Besides that BM3D prefiltering has been added.
Great, I will try it ASAP.
@turment on Telegram
Old 5th August 2021, 12:32   #162  |  Link
Dogway
Julek: I had a look into Otsu's method a month ago but wondered whether it would be useful at all. Well it uses histogram bins so that's not something I can do in Expr but I just implemented a cheap dynamic thresholding to ex_binarize() will upload soon. If Adaptive Thresholding doesn't use histogram bins it can be possible, I will have a look.
tormento: Currently in SMDegrain contrasharpening is stuck to spatial limiting. Spatial limiting is like the defacto method, I like it over temporal for anime to keep faithful lineart. Temporal could be useful for situations like poor interframe correlation like noisy sources, shaky or very action oriented films. One option would be to switch from one to another automatically depending on sequence content (via motion vectors).
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 5th August 2021, 12:56   #163  |  Link
tormento
Acid fr0g
tormento's Avatar
tormento
I tried the prefilter=5 and it gives me the error:
Script error: There is no function named 'MatchColorFormat'.
(D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.2.3d~Dogway.avsi, line 657)
(D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.2.3d~Dogway.avsi, line 159)
Would you please explain me better what the trymany option does? I have tried to understand thru MVTools manual but it keeps being of obscure meaning to me.
Old 5th August 2021, 13:08   #164  |  Link
Dogway
You need Utils-r41 for MatchColorFormat(). I haven't worked on format conversions lately because Transforms Pack is on halt so for the time being I use internal or other scripts.
trymany I don't know it's a remnant from real.finder's mod. There are still a few things I have to look up.
Old 5th August 2021, 13:22   #165  |  Link
zorr
Trymany is obscure to me as well but my tests indicate that trymany=false gives better results. At least on one test case.
zorr is offline   Reply With Quote
Old 5th August 2021, 14:09   #166  |  Link
Julek
Julek's Avatar
I think Adaptive is more useful than Otsu's, actually I already use Adaptive in Vapoursynth via numpy, but I believe that a direct implementation via Exp (or std.Convolution in VS) would help the speed.
Julek is offline   Reply With Quote
Old 5th August 2021, 14:54   #167  |  Link
tormento
Acid fr0g
tormento's Avatar
I guess for floating point format used by BM3D or what else?
Edit: tried and can't run both in StaxRip and in VirtualDub2. StaxRip plainly hangs, Virtualdub2 spits the following:
My script:
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE", 2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\1_33 Grosso guaio a Chinatown\grosso.dgi",ct=132,cb=132,cl=0,cr=0)
ConvertBits(16)
SMDegrain (tr=4, thSAD=400, trymany=false, refinemotion=true, contrasharp=false, PreFilter=5, truemotion=true, plane=4, chroma=true)
Prefetch(6)
AVSMeter64 output:
AVSMeter 3.0.8.0 (x64), (c) Groucho2004, 2012-2021
AviSynth+ 3.7.1 (r3431, master, x86_64) (3.7.1.0)
Exception 0xC000001D [STATUS_ILLEGAL_INSTRUCTION]
Module: C:\WINDOWS\System32\KERNELBASE.dll
Address: 0x00007FFB8450467C
No problems whatsoever with prefilter=4.
Old 5th August 2021, 19:39   #168  |  Link
DJATOM
DJATOM's Avatar
Illegal instruction mostly means that your CPU lacks certain instruction (AVX2 on sandy/ivy bridge?) support.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 5th August 2021, 20:25   #169  |  Link
tormento
Acid fr0g
tormento's Avatar
Yep, I confirm it's a BM3D test2 issue. With test1 I have no problems at all with a simple test script.
Old 5th August 2021, 21:03   #170  |  Link
Dogway
Sorry I took the day off. Did you include both dll in the plugin folder, both are needed I think?
About MatchColorFormat() it just converts the clip back to input format since BM3D needs YUV444 (for chroma processing). Ideally I would use a personal function from Transforms Pack, but currently it's in WIP state.
Old 5th August 2021, 21:31   #171  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
wonkey_monkey: Is the variable reference output option included in the tool? It's not showing in any of my browsers, it could come very handy for these long sorting networks.
Now updated. It only inserts pixel references for 3x3 or 5x5 networks, with or without the central pixel, so any network with 8, 9, 24, or 25 inputs.
wonkey_monkey is offline   Reply With Quote
Old 5th August 2021, 21:59   #172  |  Link
Dogway
Thanks a lot, super time saver, I was wasting more than half an hour each time. I needed it to update "medianST" so a 3x3x3, that means 27 inputs, but you can also clip to closest neighbour (26 inputs) and save in this case about 9 lines of min/max.
Something was a bit wrong though (picking output 12 and 13 for 26 inputs 13 layers):
K M                   dup1 dup1 min K^ max M^
swap1  M P                      min M^
K N                                    max N^
M N                   dup1 dup1 min M^ max N^
M N
There's nothing to swap, I replaced with:
M P                             min M^
K N                                    max N^
M N                   dup1 dup1 max swap2 min
x swap2 clip
Old 5th August 2021, 23:32   #173  |  Link
kedautinh12
Cause BM3D_VAggregate() move from BM3DCUDA to BM3DCPU in test2
https://github.com/Dogway/Avisynth-S...2.3d.avsi#L653
Old 6th August 2021, 00:18   #174  |  Link
wonkey_monkey
I think I've fixed it.
Old 6th August 2021, 10:24   #175  |  Link
tormento
Acid fr0g
tormento's Avatar
Yep, it was an AVX2 issue.
Please notice that utils-r41 and ZS_shared have duplicate functions in common. I hope it won't give secondary issues.
Old 6th August 2021, 10:57   #176  |  Link
kedautinh12
Just delete function duplicate from utils-r41 or ZS_shared
Old 6th August 2021, 13:36   #177  |  Link
tormento
Acid fr0g
tormento's Avatar
Tested and working with test3 of BM3D.
Now I just have to understand which is better at prefiltering between BM3D and KNLMeansCL, as speeds are comparable when encoding.
Would it be difficult to introduce a function in SMDegrain to show only the differences (as pixels) between the original clip and the resulting one?
Old 6th August 2021, 14:38   #178  |  Link
Dogway
As I could observe BM3D is better at motion estimation and probably also at denoising.
There's a function in ExTools that can be used for comparisons:
ex_makediff(a, aug=true, UV=128)
Old 6th August 2021, 15:24   #179  |  Link
kedautinh12
Yes, BM3D in my opinion is best denoiser
Old 7th August 2021, 04:39   #180  |  Link
poisondeathray
Thanks for the toys Dogway,
Can you check GrainFactory3mod - it appears to do nothing for me, even when using high values for g1str, g2str, g3str and tried different pixel formats. GrainFactory3 ok
colorbars(pixel_type="YV12")
GrainFactory3mod
#GrainFactory3
avisynth, dogway, filters, hbd, packs
