Old 17th November 2022, 20:51   #1741  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Originally Posted by LeXXuz View Post
It really made things much worse. What do I miss here?
GradFun2DBmod()
VoodooFX is offline   Reply With Quote
Old 17th November 2022, 22:29   #1742  |  Link
Dogway
Probably?:
ConvertBits(16)
GradFun3plus()
ConvertBits(8,dither=1)
Without HBD your only option is to add grain like with GradFun2DBmod()
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 17th November 2022, 22:40   #1743  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Originally Posted by Dogway View Post
Probably?:
ConvertBits(16)
GradFun3plus()
It's running in 16bit. (I feed the source in 16bit to x265 which dithers it down to 10bit internally.)
That's why the output confuses me. Something is off.
LeXXuz is offline   Reply With Quote
Old 17th November 2022, 22:50   #1744  |  Link
Dogway
It mimics the original GradFun3 strength so maybe you need to increase radius? Without a small sample I don't know, it works for me for skies, etc
Old 18th November 2022, 12:31   #1745  |  Link
LeXXuz
LeXXuz's Avatar
That's quite alright.
One other thing. A lot of old movies have some kind of luminance flickering which of course becomes way more noticeable after the layer of grain was removed through denoising. Is there any filter that can soothe this a little?
Old 18th November 2022, 12:33   #1746  |  Link
kedautinh12
You can add grain after denoise with GrainFactory3mod
Old 18th November 2022, 17:32   #1747  |  Link
anton_foy
Ex_reduceflicker(strength=2) #or 1?
anton_foy is offline   Reply With Quote
Old 18th November 2022, 17:51   #1748  |  Link
LeXXuz
LeXXuz's Avatar
I can't find that function. Which package does this belong to?
Old 18th November 2022, 23:38   #1749  |  Link
Dogway
It's called DCTFlicker, you can enable the option in SMDegrain (requires LFR>200) or simply use ex_LFR() from ExTools with DCTFlicker enabled. It's not perfect though. You can also try ex_reduceflicker() from QTGMC+
Old 18th November 2022, 23:45   #1750  |  Link
LeXXuz
LeXXuz's Avatar
Is it enough to set LFR=true and DCTFlicker=true for SD sources or do I have to set it to 200 manually at least?
I remember a post where you mentioned LFR~150 as the default for SD.
Also I'm not so sure anymore if flickering is the right description of what I mean. It could also be described as a pumping effect of the luma in the backgrounds.
No idea what the correct expression for that effect may be.
Old 19th November 2022, 00:37   #1751  |  Link
Dogway
Yes I know the effect, it's the grain low frequency contribution from the DCT compression. Basically you have to strongly temporal denoise low frequencies, this can lead to smearing so you have to be careful. LFR=true is a default, but if the effect is strong you have to lower it to make it stronger (recover less of the high frequencies). It really depends on the content, maybe you can get away with a a very crude mode="TemporalSoften".
Old 19th November 2022, 10:26   #1752  |  Link
LeXXuz
LeXXuz's Avatar
Thanks Dogway. So actually lowering the LFR-value from its default strengthens the effect of the filter? Is the default 150/300/600 for SD/HD/UHD and this value is used for LFR=true?
Just want to make sure I get it right this time.
Old 19th November 2022, 11:24   #1753  |  Link
Dogway
Default is 300 for all modes, rising or lowering that has a different effect since they all converge at maximum dimension resolution.
So 300 is same for all and max(width,height) is same for all, interpolated in between. It's made so for LFR=true to look similar at all resolutions.
By the way, I took the liberty to help Notepad3 devs with AVS+ lexer and handed them an updated list of Internal Functions, Plugins and User Functions definitions. They were kind to update it immediately.
I also made two syntax schemes, a "light" one and a dark one, you can have a glance here.
The problem now that I made Notepad3 my default text editor is that it feels glitchy. Opening a file takes like 300ms, and the GUI flickers while writing... Dunno if it's a Win7 thing here.
Old 19th November 2022, 15:26   #1754  |  Link
LeXXuz
LeXXuz's Avatar
Good I asked. It seems my info was a little outdated from somewhere quite early in this thread. Must've missed that they are scaled now internally according to resolution so I don't have to worry that much about.
Btw. on some sources I had the feeling LFR may increase the pumping/flickering effect. But it improved textures on clothing and stuff so I kept it. Greyish / dark suit textures are often the first things that get blurry in moving scenes.
Old 20th November 2022, 20:27   #1755  |  Link
LeXXuz
LeXXuz's Avatar
From the helpfile here:
https://raw.githack.com/Dogway/Avisy...20v3.5.5d.html
If instead you want to use your own prefilter denoiser, just define it in a variable and reference it here. Remember to:
Feed always 8 bit clips.
Input in fields for interlaced content *(read below)
Feed here planar ( by using Interleaved2Planar() ) YUY2 clips (not interleaved) when working with YUY2 sources.
Is that still valid or outdated info from the older helpfile?
Old 23rd November 2022, 16:12   #1756  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by Boulder View Post
Set refinemotion=false?
That actually did fix it. Thanks. I had problem in my x265 settings that propagated to other jobs that was causing it to keep restarting the encoding chunks and not make any progress.
Ryushin is offline   Reply With Quote
Old 28th November 2022, 11:31   #1757  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by madey83 View Post
Hello,
i'm looking reason why my dolby vision encodes have significaly higher bitrate compare to SDR encodes with all the same avisynth filters and x265 settings (DV - has few more additional tweaks).
AQ-mode 3.
Old 28th November 2022, 11:36   #1758  |  Link
madey83
AQ-mode 3.
hi,
any reson for that? if so which i should use?
madey83 is offline   Reply With Quote
Old 28th November 2022, 12:49   #1759  |  Link
madey83
AQ-mode 3.
Thank you. You were right
Old 28th November 2022, 13:06   #1760  |  Link
kedautinh12
hi,
I seen many people use aq-mode 2 for HDR and aq-mode 3 for sdr
avisynth, dogway, filters, hbd, packs
