Old 23rd October 2022, 16:06   #1661  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
You need to download Deblock plugin.
Downloaded and installed but the error about deblock_deblock is still there.
Looking at the dll itself, it has a Deblock function but not a deblock_deblock one.
@turment on Telegram
Old 23rd October 2022, 16:14   #1662  |  Link
kedautinh12
You can change deblock_deblock to deblock in script. Error will gone
kedautinh12 is online now   Reply With Quote
Old 23rd October 2022, 16:24   #1663  |  Link
Reel.Deel
Did you rename the plug in to something else? The dll must be named "deblock.dll".
Old 23rd October 2022, 16:53   #1664  |  Link
tormento
Acid fr0g
tormento's Avatar
I have changed deblock_deblock to deblock in the script but AVSPmod crashes when I try to preview, without any error message.
In VirtualDub2 I get:
An instruction not supported by the CPU was executed in module 'VirtualDub64'.
If Deblock.dll needs something more than AVX, on my Sandy Bridge I am f*cked.
Anyway, the script is:
PHP Code:
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE"2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
#LoadPlugin("D:\Eseguibili\Media\DGHDRtoSDR\DGHDRtoSDR.dll")
DGSource("F:\In\Tatami\01.dgi")
ConvertBits(16)
CCD(15# Remove big chroma "blocks"
# Remove blocking and smooth out jagged edges (only applies where motion match fails)
mb=Deblock_QED(quant1=30quant2=40,UV=1)
mb=mb.ex_smooth(1mode="SG"limit=truesharp=true
# Prefiltering with radius 3 for more coherence. I found preset "normal" to clean edges better.
pre=ex_BM3D(sigma=10,preset="normal",radius=3,UV=1,gpuid=0,tv_range=true
# Large radius for more coherence. LFR to recover some smearing. limits=false to don't sharpen motion areas
SMDegrain(6400prefilter=premfilter=mbContraSharp=trueRefineMotion=trueplane=4LFR=300limits=falseDCTFlicker=false)
# Debanding to reduce posterization in walls/defocused backgrounds
GradFun3plus(thr=0.25radius=10mask=2smode=0,UV=1
Old 23rd October 2022, 17:00   #1665  |  Link
kedautinh12
opt in deblock plugin of 299792458m will auto-detect, if you use cpu had AVX and below, opt will choose sse4.2. Try add opt=2 in deblock() or maybe you copy wrong ver: x86 in VirtualDub64
Old 23rd October 2022, 17:30   #1666  |  Link
tormento
Acid fr0g
tormento's Avatar
Nope, I did it right.
As far as I can see, deblock doesn't have a opt switch.
Old 23rd October 2022, 17:33   #1667  |  Link
DTL
May be try to add manual limiting of CPU in AVS in the script with SetMaxCPU ?
Like SetMaxCPU("mmx+, sse+, sse2+, sse3+, ssse3+, sse4+, sse4.1+, sse4.2+, avx+") . May be even start from SetMaxCPU("none") to check if it help any.
But it will not help if executable was compiled for AVX2 or later execution environment and compiler may add some AVX2 or newer instructions not guarded by AVS environment or internal detector of MaxCPU features avaialble.
The project build settings lists
<EnableEnhancedInstructionSet>AdvancedVectorExtensions2</EnableEnhancedInstructionSet>
https://github.com/299792458m/Avisyn...ck.vcxproj#L98
So it most probably compiled with instructions used up to AVX2. So someone need to download source and compile for SSE2 as lower option in typical visual studio or any other compatible compiler.
Old 23rd October 2022, 17:39   #1668  |  Link
Reel.Deel
299792458m Deblock does have an opt parameter. But you might be onto something. When I use deblock() it works but when I use deblock_deblock() or deblock(opt=x) I get the "An instruction not supported by the CPU was executed in module 'VirtualDub64'." error.
Should it be "Not Set" ?
Edit: compiled with "Not Set" and now the opt parameter works without crashing ...
Old 23rd October 2022, 17:46   #1669  |  Link
kedautinh12
Are you sure??
https://github.com/299792458m/Avisyn...-by-299792458m
Old 23rd October 2022, 18:01   #1670  |  Link
kedautinh12
Can you share "not set" compiled file, Reel.Deel??
Old 23rd October 2022, 18:53   #1671  |  Link
tormento
Acid fr0g
tormento's Avatar
Are you sure??
Nope. Another pair of glasses is needed.
Anyway I have to edit the avsi to use it. I will try.
Old 23rd October 2022, 19:24   #1672  |  Link
Boulder
Pig on the wing
Boulder's Avatar
https://drive.google.com/file/d/1AO1...ew?usp=sharing
Straight from the Avs+ wiki.
Old 23rd October 2022, 19:38   #1673  |  Link
Reel.Deel
Originally Posted by Boulder View Post
I forgot it was there. Asd added that. No wonder when I went to replace the deblock plugin it showed a more recent date.
Edit: updated the Deblock wiki page with 299792458m's version built by Asd. I modified the folder structure of the zip so that the binaries are not inside the src folder: https://files.videohelp.com/u/223002...m_noAVX2req.7z
Old 23rd October 2022, 23:02   #1674  |  Link
DTL
Not set is something undefined (may be something like SSE/SSE2 to make not completely poor build). I typically set line ending with /arch:SSE2 for SSE2 builds. It is expected at 2022 year with x64 CPUs most users have at least SSE2.
Old 24th October 2022, 00:06   #1675  |  Link
StvG
The default arch is SSE2. For x64 SSE2 is also the minimum arch.
StvG is offline   Reply With Quote
Old 25th October 2022, 00:44   #1676  |  Link
tormento
Acid fr0g
tormento's Avatar
@Dogway
Is possible to have a porting of maa2 inside your tools?
Old 25th October 2022, 01:48   #1677  |  Link
kedautinh12
@Dogway
real.finder was updated it
https://github.com/realfinder/AVS-St...20up/maa2.avsi
Old 25th October 2022, 06:47   #1678  |  Link
madey83
hi,
what is the benefit of using maa2 filter?
madey83 is offline   Reply With Quote
Old 25th October 2022, 07:03   #1679  |  Link
kedautinh12
Originally Posted by madey83 View Post
hi,
Anti-aliasing scripts
Old 25th October 2022, 09:39   #1680  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks. Does it support Asd-g porting of VS Sangnom2?
I was asking Dogway as he did a real good job optimizing scripts within his extools "library".
I read about the use of nnedi3 as antialiasing tool but don't really know how. It would be even faster as it has a OpenCL port.
avisynth, dogway, filters, hbd, packs
