Old 19th November 2021, 23:30   #621  |  Link
Dogway
Limiter() is there just for comparison purposes, it simply chops off out of range values. SafeColorLimiter() is the same as Limiter() but with HBD support so I didn't add.
There are still a few small bits that can be improved, like 'tolerance' response, pass arguments in dynamic mode, or finer precision in the min/max values, so I will refine those at a later point.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 20th November 2021, 02:58   #622  |  Link
Originally Posted by VoodooFX View Post
What is that Limiter() there?
Are you asking what the Limiter() plugin is, if so then here[its avs builtin]:- http://avisynth.nl/index.php/Limiter
StainlessS is online now   Reply With Quote
Old 20th November 2021, 03:26   #623  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Now I remember using it for something few years ago...
What ColorYUV(levels="pc->tv) does in comparison?
VoodooFX is offline   Reply With Quote
Old 20th November 2021, 07:54   #624  |  Link
poisondeathray
ColorYUV(levels="pc->tv") does the same as levels(0,1,255,16,235,false) - it scales the clip 0-255 to 16-235. Notice slope of curve is changed, and "banding" is introduced as some values are duplicated (steps in the waveform)
Limiter just cuts off values, all values <16 become 16. >235 become 235. The slope of curve in values 16-235 is unchanged
soft rolloff is a welcome adjustment option, instead of "harsh" transitions
Old 20th November 2021, 18:02   #625  |  Link
Dogway
Ah so nice, I included a tweaked panel of the debug example in the wiki.
Also updated SoftLimiter() with a straight input remap. The curve fitting wasn't accurate plus I assessed it in 8-bit.
Old 20th November 2021, 19:21   #626  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Testing SoftLimiter(show=true) gives me the error "StackVertical: image widths don't match", lines 2235 and 2239.
Old 20th November 2021, 19:27   #627  |  Link
Dogway
Thanks, what I presumed, incompatibilities with mod sizes. Will have a look
EDIT: Fixed. Test now, I also optimized the code a bit.
Old 20th November 2021, 22:11   #628  |  Link
Shinkiro
SMDgraim broken
I can't figure out what he wants from me.
Ryzen 2700x | ASUS ROG Strix GTX 1080 Ti | 16 Gb DDR4
Windows 10 x64 20H2
KD-55XE9005 | Edifier R2800
Shinkiro is offline   Reply With Quote
Old 20th November 2021, 22:22   #629  |  Link
Dogway
Strange, what version of avs+ are you on? propNumElements() works for me outside runtime environments.
Old 20th November 2021, 22:34   #630  |  Link
Shinkiro
Dogway
3.7.1 r4351
SMDegrain v3.3.4d works without errors, other versions have not checked
Windows 10 x64 20H2
Old 20th November 2021, 22:53   #631  |  Link
Dogway
You mean r3351? Can you try newer version? I think props for frame index#0 was added recently.
Try test build 27 from its thread.
Old 20th November 2021, 22:59   #632  |  Link
Shinkiro
With the new version it works, thanks!
Windows 10 x64 20H2
Old 21st November 2021, 10:04   #633  |  Link
tormento
Acid fr0g
tormento's Avatar
I was trying to clean up the BD of Brazil (small clip here) from excessive noise and I am really torn between
SMDegrain (tr=6, thSAD=600, refinemotion=true, contrasharp=false, PreFilter=4, plane=4, chroma=true, LFR=true, DCTFlicker=true)
and
SMDegrain (tr=6, thSAD=600, refinemotion=true, contrasharp=false, PreFilter=5, plane=4, chroma=true)
The first gives more detail behind fog or clouds but it has some dancing noise or textures in the most disturbed areas of the video, mostly visible in clouds or walls.
The second is more stable but loses some details.
The bitrate of both is similar, i.e. 3716 kb/s vs 3623 kb/s (on whole movie).
Some years ago a plugin to calm grain (I can't remember the exact name) was out and I was used to implement it in my scripts.
Can you stabilize in some way more the noise before reapplying with LFR=true, DCTFlicker=true?
Moreover I have some slight color change between the two, such as on the falling pictures on this clip:
Look at the pictures falling on the left.
@turment on Telegram
Old 21st November 2021, 12:08   #634  |  Link
Dogway
I will have a closer look later today or tomorrow with more time since currently I'm porting NIS sharpen but I made some templates for noisy sources, maybe you can try, tweaking the parameters in red.
Mild to strong:
	pre=smdegrain(tr=1,mode="temporalsoften",blksize=32,thSAD=900,LFR=400,prefilter=5,DCTFlicker=true,contrasharp=false,refinemotion=true)
	smdegrain(tr=2,mode="MDegrain",blksize=32,prefilter=pre,thSAD=400,LFR=false,contrasharp=true,refinemotion=true)
Very strong (ie. 300, 21 grams):
	smdegrain(tr=2,mode="temporalsoften",blksize=32,thSAD=900,LFR=300,DCTFlicker=true,contrasharp=false,refinemotion=true)
	smdegrain(tr=1,mode="MDegrain",blksize=32,thSAD=300,LFR=false,contrasharp=true,refinemotion=true)
For calming grain I think the most popular were FluxSmoothT and STPresso. There were Deen, etc but they are older and based on the same concept (thresholded medians). You can try those or some of my implementations like ex_FluxSmoothT() or STTWM(), or ex_FluxSmoothST() if using as prefilter.
Old 21st November 2021, 12:55   #635  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm still getting the error with RC27. Tried without any cropping (i.e. 1080p) and with 240 pixels cropped off the left and right sides.
Old 21st November 2021, 14:29   #636  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Ex_makediff also seems to be broken, "I don't know what 'fmt' means." is the error, lines 1895 and 1910 in transformspack.avsi.
Tested by loading the 1080p source and with these as the only lines after that:
ConvertBits(16)
ex_makediff(last, SPresso(bias=20, biasc=40, rgmodec=4, limit=0.3, limitc=0.6), aug=true)
There's something strange happening with the SPresso limit, if I use limit=0.29, the output seems to change drastically.
Old 21st November 2021, 21:53   #637  |  Link
Dogway
Thanks, yes stupid typo for 'aug=true'. Should be format=PixelType(RGB) in TransformsPack
As for SoftLimiter() debug panel I tested with decimal resizing (using RatioResize) for a few minutes and I had no issues. What's the exact resolution of the clip so I can check?
I did some tests for SPresso and didn't get such behaviour, the parameter response was smooth so it might be clip dependent. I would need a small sample.
Old 22nd November 2021, 06:44   #638  |  Link
Boulder
Pig on the wing
Boulder's Avatar
It's 1920x1080, reproducable if I just load the source with DGSource and then use SoftLimiter(show=true).
Try with this one. The same one can also be used for the SoftLimiter test.
https://drive.google.com/file/d/1oPb...ew?usp=sharing
You can use this script to see how it looks, if you change the value of limit between 0.29 and 0.3, the difference is quite big compared to 0.3 and 0.31. It doesn't seem to matter if the source is 8 or 16 bits.
DGSource("spresso_testclip.dgi")
limit = 0.3
convertbits(16)
ex_makediff(last, mcdegrainsharp(last, c2=SPresso(bias=20, biasc=40, rgmodec=4, limit=limit, limitc=limit*2), frames=1), aug=50, uv=128)
Function MCDegrainSharp(clip c, clip "c2", int "frames", float "bblur", float "csharp", bool "bsrch",bool "Precise",Int "Limit",Int "LimitC") {
  # From:- http://forum.doom9.org/showthread.php?p=1737045#post1737045
  # Based on MCDegrain By Didee, http://forum.doom9.org/showthread.php?t=161594
  # Also based on DiDee observations in this thread: http://forum.doom9.org/showthread.php?t=161580
  # "Denoise with MDegrainX, do slight sharpening where motionmatch is good, do slight blurring where motionmatch is bad"
  # In areas where MAnalyse cannot find good matches, the blur() will be dominant.
  # In areas where good matches are found, the sharpen()'ed pixels will overweight the blur()'ed pixels
  # when the pixel averaging is performed.
  # Mod by StainlessS to add Precise, 3 Sept 2015.
  # Mod by StainlessS, Default bblur mod for HD. bs (blocksize) mod for HD. Added Limit, LimitC. 17 Feb 2020.
    frames = Default(frames, 2)
#    bblur  = Default(bblur, (c.width>1920) ? 0.75 : (c.width>1280) ? 0.7 : (c.width>960 ) ? 0.65 : 0.6)
    csharp = Default(csharp, 0.6)
    bsrch  = Default(bsrch, true)
    Precise= Default(Precise,False)  # Use MRecalculate
    Limit  = Default(Limit,255)
    LimitC = Default(LimitC,Limit)
    bs     = (c.width>1920) ? 32 : (c.width>1280) ? 24 : (c.width>960 ) ? 16 : 8
    super = bsrch ? c2.MSuper(pel=2, sharp=1) : c.MSuper(pel=2, sharp=1)
    super_rend  = c.sharpen(csharp).MSuper(pel=2, sharp=1,levels=1)   # Only 1 Level required for sharpened Super (not MAnalyse-ing)
    backward_vec1 = MAnalyse(super, isb = true, delta = 1, blksize=bs, overlap=bs/2)
    forward_vec1  = MAnalyse(super, isb = false, delta = 1, blksize=bs, overlap=bs/2)
    backward_vec1 = (Precise) ? MRecalculate(super, backward_vec1, blksize=bs/2, overlap=bs/4,thSAD=100) : backward_vec1
    forward_vec1  = (Precise) ? MRecalculate(super, forward_vec1 , blksize=bs/2, overlap=bs/4,thSAD=100) : forward_vec1
    (frames<=0) ? c :\
    (frames==1) ? c2.MDegrain1(super_rend, backward_vec1,forward_vec1,thSAD=400,Limit=Limit,LimitC=LimitC) :\
    (frames==2) ? c2.MDegrain2(super_rend, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400,Limit=Limit,LimitC=LimitC) \
                : c2.MDegrain3(super_rend, backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3,thSAD=400,Limit=Limit,LimitC=LimitC)
    return(last)
Old 22nd November 2021, 20:16   #639  |  Link
Dogway
Ok uploaded an update. The debug panel in SoftLimiter() is hopefully fixed. Also fixed the typo for ex_makediff(aug=true).
SharpenersPack is also updated with a new sharpener NVSharpen(), this is Nvidia's NIS sharpener, but I didn't like it too much. And reworked/optimized SSSharpenEX() for good I hope.
Now I will have a look at the SPresso thing and Tormento's clip.
I have a somewhat big change pending in the case masks should use fullscale bitdepth, just waiting for confirmation. In my opinion it shouldn't despite masks being PC range (except when source is also PC range).
Old 23rd November 2021, 13:32   #640  |  Link
tormento
Acid fr0g
tormento's Avatar
Did you work out some other unsharpener? I have tried many solutions but I don't see lot of improvements on bitrate output side. Always too high.
P.S: Do you plan to introduce the new development MVTools options soon or will you wait for a stable release?
avisynth, dogway, filters, hbd, packs
