Old 15th October 2021, 09:21   #561  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
I haven't installed VS
Don't give in to the dark side.
@turment on Telegram
Old 15th October 2021, 19:12   #562  |  Link
Dogway
No I won't. I look forward to Julia, much faster and probably easier to read (I hate the "X if true else false" of python).
Just updated SimilarityMetrics, vsSSIM had a few issues. Also finished BSSIM.
Also updated ResizersPack, main utility is nmod(), it converts any value to a set mod size, also has an option for minimum value (ie. nmod(n, 4, 16) ). You can also use bankers' rounding. New function PadBorders() pads the clip with borders in set 'mode', as in 'Dilate', 'Mirror' or a color '$000000'. And also updated MatteCrop() to work faster, the function still needs some work.
This weekend I will have a look at MatchClip() and update all the EX/MIX mods according.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 15th October 2021, 20:49   #563  |  Link
Julek
Julek's Avatar
I have a question about your ex_ContraSharpening, why do you use the result of "ssDD range_half -" or "ssD range_half -" to add to the denoised, and the original chooses between ssDD and ssD to then add to the denoised?
ex_CS: https://github.com/Dogway/Avisynth-S...Pack.avsi#L566
CS: https://github.com/realfinder/AVS-St...avsi#L603-L606
vs-CS: https://github.com/HomeOfVapourSynth...py#L5691-L5693
Julek is offline   Reply With Quote
Old 15th October 2021, 21:06   #564  |  Link
Dogway
The original version uses mt_adddiff() which does "ssDD range_half -" or "ssD range_half -" in itself, so their output needs to be range_half centered.
I do everything in a single step so no need to add (or keep) the centered values. This is faster.
Old 15th October 2021, 21:12   #565  |  Link
Julek
Julek's Avatar
But wouldn't mt_adddiff be like denoised + ssD (the whole ssD or ssDD)?
#EDIT: I guess I really didn't know how mt_adddiff works, I'll do some tests later.
Old 15th October 2021, 21:24   #566  |  Link
Dogway
You want to add the pure difference. Centering the difference is to circumvent the unsigned nature of AviSynth+ int bitdepths.
mt_addiff() is actually "y range_half - x +".
Old 16th October 2021, 11:53   #567  |  Link
tormento
Acid fr0g
tormento's Avatar
No I won't.
Can I make a request?
Something similar to RGBAdapt but more consistent and MT friendly, plus it still needs stacked to do HBD.
I have tried AutoAdjust too but it's just too slow to be useful on HD or 4K.
You made so many useful scripts that the only two things I can see missing is a motion stabilizer (a really working one, even for micromovements of film on the spool) and levels/gamma/RGB optimizer.
Those two can help a lot with old movies, directly ported to BD and even 4K with no restoration at all.
Old 16th October 2021, 19:01   #568  |  Link
Dogway
Did you try RGBAdapt or Gammac? The core principle is easy, the hard part is to work on scene bounds and temporally soften the effect to avoid chroma flicker. This has been done in plugins, I don't know of an easy way to do it at script level.
I usually apply a hue correction but at clip level so I avoid all those issues. Normally at two points, white level and grey level. Import the curve from Photoshop apply to RGB, convert to YUV and mergechroma with that.
Old 16th October 2021, 23:11   #569  |  Link
tormento
Acid fr0g
tormento's Avatar
Yes and yes. RGBAdapt is a script and I hope it could be improved, as it presents many limitations.
Sorry, as I told, I am a noob with color spaces and conversion. Any available tutorial to the detailed steps?
Old 17th October 2021, 14:17   #570  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've been getting Access Violation errors with SPresso. Extools.avsi line 3670, smdegrain.avsi line 622 and spresso.avsi line 38 are mentioned in the dialog box.
This is the script I can use to reproduce it, it usually starts occurring if I have to refresh the script often in VDub2 while tuning the settings. Closing the application and reopening it seems to help.
DGSource("columbo_s03e01.dgi")
TFM(slow=2).TDecimate(nt=1)
SPresso(bias=20, rgmodec=4, limit=0.65)
SelectEvery(400, 1)
Old 17th October 2021, 14:51   #571  |  Link
Dogway
Interesting, looks like an avisynth bug. It's in the "smart" algo of ex_median(). Investigating. Read here.
EDIT: @tormento, look here for a simple color correction method, You can do 2 points, 3, 4, etc. Do over things you know should be neutral (opening, credits...). Then export as a .cube file.
Old 18th October 2021, 16:14   #572  |  Link
Dogway
@Boulder: Did it work before, in previous versions of test AviSynth+ ? Since what version does it happen? Looks like an obscure memory bug.
Old 18th October 2021, 18:34   #573  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've only started testing SPresso recently, so all tests have been done with test14. I actually forgot that there's more recent ones too, I guess I could try testing with the latest one once my current encode finishes.
Old 18th October 2021, 19:02   #574  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Looks like test20 works without issues, I tried refreshing and jumping around the video a lot but it didn't trigger anything. I'm good with that
Old 18th October 2021, 19:40   #575  |  Link
Dogway
Ok, I was in test 20 and got the issue initially (although not today), so the bug traces back to at least test 14.
EDIT: Updated most EX/MIX mods, mainly maintenance rebasing to latest ExTools and ResizersPack.
Old 19th October 2021, 05:03   #576  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I got it now with test20 as well, if it's a memory bug, no wonder it is quite random.
Old 19th October 2021, 11:35   #577  |  Link
Dogway
I will update it with a workaround until it is fixed (if it gets fixed at all) since it is so critical (used in minblur) so for the time being you can edit the "smart" algo with an explicit var:
Where it says "E^ D^ H^" replace it with "E^ D^ H^ A^ A" and the bug shouldn't appear more.
Old 19th October 2021, 23:14   #578  |  Link
tormento
Acid fr0g
tormento's Avatar
@tormento
I was playing with lfr and contrasharpening.
The details recovered with lfr are terrific when compared to contrasharpening. How are them different and has contrasharpening any reason to exist anymore?
Old 20th October 2021, 00:04   #579  |  Link
Dogway
The lowpass recovery has an issue, it recovers everything under the cutoff (not exactly but more or less), so it's as if you didn't denoise low frequencies at all, this can be problematic for very grainy sources. That's why that's another reason to run two consecutive calls, the later cleaning up the remnant low frequency noise.
Another thing is that for LFR I'm comparing the behaviour of filtering twice (the original and the lowpassed). Maybe this is not necessary at all and can do as I did with MDegrain, simply compare the lowpassed original versus the lowpassed denoised. This would greatly improve performance.
Also there might be better filters for lowpassing, bessel, butterworth, etc. There's room for improvement.
ex_contrasharpening() doesn't recover anything, it's just acutance. I like to think in terms of LFR for low freq, and contra for high freq, so they are not mutually exclusive.
Old 20th October 2021, 00:39   #580  |  Link
tormento
Acid fr0g
tormento's Avatar
Any example to understand the behaviour is welcome. Please keep us informed!
So, wouldn't be possible to set a integer parameter for contra and call it something like hfr?
avisynth, dogway, filters, hbd, packs
