Old 13th October 2021, 11:11   #541  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
No, LFR is not automatic since it makes the filter slower (haven't benchamrked though). I would use it always with TemporalSoften, and also with MDegrain if you are using thSAD>500 or tr>4 but these are loose estimations. I would run tests to see the before and after (I use ex_makediff to see better) and check if it recovers enough to be worth it.
I have briefly tested in some scenes and the result with fog is awful, i.e. random blocks of pure noise (read: mess ). When my PC will finish the encoding queue, I will test more.
@turment on Telegram
tormento is online now   Reply With Quote
Old 13th October 2021, 11:31   #542  |  Link
Dogway
@TDS: Nice. I tested "ex_BM3D(sigma=5,radius=1,CUDA=false,UV=3,fulls=false)" and it worked here. Do you have the latest version?
@tormento: Great! share the clip (and SMDegrain call) so I can have a look. ExTools and SMDegrain are supposed to be finished except for bugs.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 13th October 2021, 13:21   #543  |  Link
TDS
Formally known as .......
TDS's Avatar
Latest version of what ???
If you're referring to BM3D, I think I have "test 3"...is there newer ??
Long term RipBot264 user.
RB 1.27.1 (std)
RB 1.27.1 (fully loaded, OOD)
PD 7.5 (new)
TDS is online now   Reply With Quote
Old 13th October 2021, 13:42   #544  |  Link
Dogway
test 3 is not latest, it's this.
Old 13th October 2021, 13:55   #545  |  Link
TDS
TDS's Avatar
OK, thanks for that, but I think that might be the one I have...I'll check.
RB 1.27.1 (std)
PD 7.5 (new)
Old 13th October 2021, 15:09   #546  |  Link
kedautinh12
No, this is last
https://github.com/WolframRhodium/Va...uns/1215772307
Old 13th October 2021, 15:16   #547  |  Link
Dogway
Thanks, that's it.
Old 14th October 2021, 01:45   #548  |  Link
TDS
TDS's Avatar
Thanks, that's it.
Were you able to get this ??
It's timestamped @ 09-09-21, older build was 04-09-21.
RB 1.27.1 (std)
PD 7.5 (new)
Old 14th October 2021, 01:49   #549  |  Link
kedautinh12
My link is ver 09-09-21
Old 14th October 2021, 01:57   #550  |  Link
TDS
TDS's Avatar
Hi, yes, but it took me a while to get to the downloadable file...
RB 1.27.1 (std)
PD 7.5 (new)
Old 14th October 2021, 02:03   #551  |  Link
kedautinh12
I downloaded easy with github account
Old 14th October 2021, 02:11   #552  |  Link
TDS
TDS's Avatar
Yes, once I signed in, made all the difference
RB 1.27.1 (std)
PD 7.5 (new)
Old 14th October 2021, 09:39   #553  |  Link
tormento
Acid fr0g
tormento's Avatar
Warning! NSFW!
It's the shower scene in Carrie.
It's a plain script
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE", 2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\carrie.dgi",ct=20,cb=20,cl=0,cr=0)
ConvertBits(16)
SMDegrain (tr=x, thSAD=x00, refinemotion=true, contrasharp=false, PreFilter=4, plane=4, chroma=true) [,lfr=true]
fmtc_bitdepth (bits=8,dmode=8)
Prefetch(6)
where x varies from 4 to 9, accordingly.
Any hint is welcome.
Old 14th October 2021, 09:54   #554  |  Link
Dogway
Thanks, I didn't get block of any sorts, simply recovered low frequency grain.
You have two options, run my double temporalsoften call (double MDegrain also works), or lower the frequency restoration with LFR=8 for example.
EDIT: this is a good compromise between quality and speed
smdegrain(tr=1,mode="temporalsoften",blksize=32,thSAD=900,LFR=2,contrasharp=false,refinemotion=true)
smdegrain(tr=1,mode="MDegrain",blksize=32,thSAD=300,LFR=false,contrasharp=true,refinemotion=true)
Old 14th October 2021, 10:55   #555  |  Link
tormento
Acid fr0g
tormento's Avatar
Does the number modify the frequency domain or the restoration intensity?
Old 14th October 2021, 11:10   #556  |  Link
Dogway
The number indicates the cutoff frequency of the lowpass (it isn't parametrized but I would like to do it in the future). The higher the lower frequency is restored, the lower more high (along low) frequencies are restored. It's a low pass so that means that recovered frequencies span from 0 to cutoff frequency.
Old 14th October 2021, 13:56   #557  |  Link
tormento
Acid fr0g
tormento's Avatar
Do you have any idea of some meaningful numbers/cutoffs to use?
Old 14th October 2021, 21:49   #558  |  Link
Dogway
Depends on source grain, the greater the grain the more low freq noise you will get. Or you can use two passes as above and get away with a lower LFR (higher cutoff).
Also I forgot about your query on ex_makediff(), can't you just do:
a=last
b=SMDegrain(tr=5, thSAD=500)
c=SMDegrain(tr=7, thSAD=700)
d=SMDegrain(tr=9, thSAD=900)
b=ex_makediff(a,b,aug=true)
c=ex_makediff(a,c,aug=true)
d=ex_makediff(a,d,aug=true)
StackHorizontal(b,c,d)
Old 14th October 2021, 22:11   #559  |  Link
Julek
Julek's Avatar
I remember you mentioned about reinstalling VS, so I wanted to let you know that Akarin's Expr now has sortN, which is very useful.
https://github.com/AkarinVS/vapoursy...-order-filters
Julek is offline   Reply With Quote
Old 14th October 2021, 22:41   #560  |  Link
Dogway
Wow that's great, too bad pinterf dismissed the sort operator. I'm still trying to figure out how to compose a 48 inputs ranking filter, I know I can use two parallel 24 inputs, then use a Batcher's odd-even sorter to merge both ranked lists, I still don't know how to set up this odd-even sorting network for 48 inputs, I need to run some tests probably in a few days. Will be the last thing to add to ExTools.
I haven't installed VS because my main urge is to finish the current scripts and its issues. Had to rebase all the scripts for the new ex_blur() gaussian to binomial fit. Then also created a MatchClip() function to remove MatchColorFormat() and its Utils-r41 dependency. Also created a few rounding functions to remove m4(), m4_sh, m(), etc and also Zs_RF_Shared.avsi dependency.
My main problem with VS is python, despite I use it for blender and a few random scripts I prefer the more direct approach of AVS+. Programming is reduced to a minimum and you only care about the algo. Python is a bit harder to read, also because the object oriented approach, a bit too verbose IMO. I will install it when I get TransformsPack to a stable release, want to play with the AI filters.
avisynth, dogway, filters, hbd, packs
