Old 4th October 2021, 07:13   #461  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
why don't you try the other ones?
I gave the consecutive clip to the community but here I am testing with CompTest.
Where can I find SantiagMod, deconv_h and mt_convolution?
@turment on Telegram
Old 4th October 2021, 08:02   #462  |  Link
Dogway
This is SantiagMod, my go-to antialiaser, I simply replaced GScript with internal syntax:
### SantiagMod
### Antialiasing function by Archimedes,
### mod from original cretindesalpes's santiag.
### Requires:
### LoadPlugin("plugins\EEDI3\eedi3.dll")
### LoadPlugin("plugins\NNEDI2\nnedi2.dll")
### LoadPlugin("plugins\NNEDI3\nnedi3.dll")
### I've changed the posted function santiag a little bit.
### Santiag has now three parameters: type, strh and strv. Type means the antialiasing type.
### Possible values are "EEDI3", "NNEDI2" and "NNEDI3". strh is the strength for the horizontal
### anti aliasing and strv is the strength for the vertical anti aliasing. Default values are:
### type="nnedi3", strh=1 and strv=1.
### Contrary to the first posted function, santiag(strh=0, strv=0) now means no anti aliasing.
### I've also corected the center shift. With NNEDI3 as type, the center shift now works correct
### for all possible input clips (YV12, YUY2 and RGB24).
function SantiagMod(clip input, string "type", int "strh", int "strv") {
  type = Default(type, "NNEDI3")
  strh = Default(strh, 1)
  strv = Default(strv, strh)
  input
  strh > 0 ? AntiAliasing1(type=type, strength=strh) : NOP()
  TurnLeft()
  strv > 0 ? AntiAliasing1(type=type, strength=strv) : NOP()
  TurnRight()
  function AntiAliasing1(clip input, string "type", int "strength") {
    input
      if (type == "EEDI3") {
        EEDI3(dh=True, field=0)
        for (i = 2, strength) {
          EEDI3(dh=False, field=(i + 1) % 2)
      else if (type == "NNEDI2") {
        NNEDI2(dh=True, field=0)
          NNEDI2(dh=False, field=(i + 1) % 2)
      else {
        NNEDI3(dh=True, field=0,qual=2)
          NNEDI3(qual=2,dh=False, field=(i + 1) % 2)
    Spline36Resize(input.Width(), input.Height(), 0, 0.5, input.Width(), input.Height() * 2)
mt_convolution() is from masktools2, I was too lazy to port to Expr() but if it works for you I can craft it.
By the way I have to ask if anyone is able to compile this program for Windows, I need it to optimize the latest medians from 35 and up. For example "median7" has the potential to increase from current 7.8% to 12%.
median7 (48 inputs) can be composed from two 24 sorting networks and finally a batcher's odd-even merge, but before I spend more days on it I want to test if the program can find an optimized sorting network.
On another note I have been reading about Julia, a new programming (scripting?) language. As fast as C, and as "easy" as Python. I might start to learn it.
EDIT: Also I want to comment that I have been testing GradFun3 and a DFT box filter is unbeatable for large radii, so I might just keep it (if I go for back compatibility). Dither_bilateral16() can't also be replaced, I tested with vsTBilateral() at large radii but something is going on, it appears as it denoises the same as Dither_bilateral16() but when passed dithered down it doesn't deband as much, this might have to do with particular settings like flat or wmin. So rather than a revolution I might do an in-place adaptation for HBD.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 4th October 2021, 10:04   #463  |  Link
tormento
Acid fr0g
tormento's Avatar
This is SantiagMod
I have tried with the other filters.
SMDegrain (tr=4, thSAD=400, refinemotion=true, contrasharp=false, PreFilter=4, plane=4, chroma=true)
deconv_h = "0 -5 25 100 25 -5 0 "
mt_convolution (deconv_h, deconv_h, Y=3, U=2, V=2)
encoded 5053 frames, 4.98 fps, 7831.54 kb/s, duration 0:16:54.68
SantiagMod(strh=2,strv=2)
a=last
ex_luts(last,last.removegrain(12,0),mode="clamp",UV=1)
ex_lutxy(last,a,"x y - abs 7 > y x y min ?")
encoded 5053 frames, 4.50 fps, 8190.77 kb/s, duration 0:18:43.92
a=last
ex_boxblur(0.15,mode="weighted")
encoded 5053 frames, 4.36 fps, 7953.44 kb/s, duration 0:19:18.57
As you can see, not many changes at all.
Very hard video to compress.
Old 4th October 2021, 10:43   #464  |  Link
Dogway
Put SMDegrain last, and as I commented those 5000 frames are not representative of the movie pace. Use SelectRangeEvery() to get evenly spaced chunks and get a better estimate of final bitrate. Or simply encode with target bitrate 2 passes.
Old 4th October 2021, 10:46   #465  |  Link
kedautinh12
New ver santiag
https://github.com/realfinder/AVS-St...p/Santiag.avsi
Old 4th October 2021, 11:12   #466  |  Link
Dogway
Originally Posted by kedautinh12 View Post
Oh my god, who said to keep it simple.
Old 5th October 2021, 21:30   #467  |  Link
tormento
Acid fr0g
tormento's Avatar
I am having a problem with the following script
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE", 2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\1_48 Fantozzi\fantozzi.dgi",ct=24,cb=24,cl=0,cr=0)
ConvertBits(16)
Spresso(10,30).STpresso(10,30,4,22,8,49,1,mc=true) #last updates
fmtc_bitdepth (bits=8,dmode=8)
Prefetch(6)
with error
mt_lutxy : Error at position 3: cannot convert to number: 1.000000
(D:/Programmi/Media/AviSynth+/plugins64/STPresso-2020_0507.avsi, line 40)
Could you please convert STPresso too to use your ex_tools?
Old 6th October 2021, 00:01   #468  |  Link
Dogway
I made STTWM() 2 months ago. Did you try it?
Old 6th October 2021, 00:13   #469  |  Link
kedautinh12
You don't upload that to github. I think it's only test build
Old 6th October 2021, 00:35   #470  |  Link
Dogway
It was only an example script I crafted for tormento. I don't know to what degree it works or people find it useful so I can't vouch for that.
EDIT: By the way, compiled SorterHunter just to know it doesn't work with inputs larger than 32, oh well...
Old 6th October 2021, 09:38   #471  |  Link
tormento
Acid fr0g
tormento's Avatar
I made STTWM
Sorry, it jumped out of my mind. Have I to replace into
or use per se?
Old 6th October 2021, 09:42   #472  |  Link
Dogway
No, it's not a port it's an alternative, it uses the same concept, thresholded temporal, thresholded spatial then mix with another threshold. It's way faster. When I tested I liked the results but I normally don't use STPresso anyway. These are impulse noise denoisers (salt'n'pepper, etc) which I don't use much.
I just tested STPresso and worked for me with latest masktools and AVS+
Old 6th October 2021, 09:55   #473  |  Link
tormento
Acid fr0g
tormento's Avatar
I am just looking for an alternative for very grainy and oddly noised video, where SMDegrain simply surrender, even with 9/900.
Any suggested parameter? The defaults are ok?
Old 6th October 2021, 10:18   #474  |  Link
Dogway
Ah for heavy grain I implemented temporalsoften into SMDegrain, it works great so far as I ported it from TSMC() mod and some bits from LTSMC() from Didée. Yes, there's some low frequency (motion) blur like, I'm working on it.
I tested STPresso with default values, maybe it might be something on your end. What line/call is giving you issues?
Old 6th October 2021, 14:05   #475  |  Link
tormento
Acid fr0g
tormento's Avatar
Please explain me how to use it, as I can't see in the documentation.
I saw a new release of MaskTools is out, allowing TAB, CR and LF characters as symbol separators in expression strings.
Will give it a try.
Old 7th October 2021, 00:02   #476  |  Link
Dogway
I explained it to you in this post 2 weeks back.
Old 7th October 2021, 09:29   #477  |  Link
tormento
Acid fr0g
tormento's Avatar
Oops.
I saw you mentioned ex_retinex too.
I am trying to recover some color cast, probably from film degradation, as you can see in the Retinex thread.
So, is it possible to integrate my separate line for color restoration inside SMDegrain? As you can see there, I am having some problems with too much red restoration.
Old 7th October 2021, 10:06   #478  |  Link
Dogway
My version of retinex is not for color balance but for contrast enhancement.
I think there are better tools to remove the color cast like Gammac or RGBadapt. See here.
Also check here from videoFred
Old 7th October 2021, 10:45   #479  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your links, I will read them.
The issue with that film is that every component aged in a different manner and it's really hard to balance the hues of each one.
Old 8th October 2021, 04:39   #480  |  Link
TDS
Formally known as .......
TDS's Avatar
What is the actual function on the "pre-filters" in SMDegrain ? eg:- Dfttest, KNLMeansCL, & BM3D.
Are they to compliment the main SMDegrain function ?, 'cause SMDegrain works pretty well, by itself !
And can the "strengths" be easily changed ?
Long term RipBot264 user.
RB 1.27.1 (std)
RB 1.27.1 (fully loaded, OOD)
PD 7.5 (new)
TDS is offline   Reply With Quote
avisynth, dogway, filters, hbd, packs
