Old 27th September 2021, 08:59   #421  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
I tried though to implement to ex_contrast() without success
Look at this and this too.
@turment on Telegram
Old 27th September 2021, 09:23   #422  |  Link
pinterf
'exp' is a valid Expr function, and is using SIMD, probably worth using it.
In your replacement code above, luckily power with small integer exponents like 1, 2, 3 and 4 are optimized internally into mul (and dup), but for larger exponent values the result is calculated using a^b = exp(b*ln(a)) which needs much more computing.
pinterf is offline   Reply With Quote
Old 27th September 2021, 13:55   #423  |  Link
Dogway
I didn't want to make the snippet more complex than it is so I used "n ^", in real I'm using vars to reuse operations.
I tested with taylor series and gave a great performance improvement over 'exp' but it might not be valid for high steepness, I crafted a graph to see what was happening, I still might be doing something wrong. https://www.desmos.com/calculator/guetsfy9ww
Guess I can join another polynomial but it makes things more complex.
EDIT: just tested and yes, 'exp' is as fast. I had the notion that not when coding ex_bilateral() removing 'exp' gave a huge speed boost.
@tormento: thanks. I think cos, sin and tan are the easiest, I already adapted 'interpolation' mode in ex_blend(), the problem comes when 'x' uses derivatives and other complex functions like atan. If I'm not wrong atan(x) = tan(y) = sin(y) / cos(y)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 27th September 2021, 15:16   #424  |  Link
tormento
Acid fr0g
tormento's Avatar
Nope, the arctan function is the inverse of the tangent function: it returns the angle whose tangent is a given number.
There is a Taylor series & here for it too. Look here also.
Explicit algorithm is present too.
Old 27th September 2021, 17:21   #425  |  Link
Dogway
Thanks tormento, I managed to build a piecewise function for atan(x) since the Taylor series didn't converge between 0.8 and 1.65 so I built a polynomial in that section. https://www.desmos.com/calculator/bb392gsvnu
I tested on avisynth and works fine, now I will try to optimize it and benchmark, and see if I can reduce it on a case by case basis.
Here's the code and bench (400% speed increase):
Expr(last,Format("  x 255 / atan 255 *"),"") # 90
e8  = "X dup dup * X2@ X * X3@ 0.333333 * - X2 X3 * X5@ 0.200001 * + X5 X2 * X7@ 0.142857143 * - X7 X2 * 0.111111111 * +  X7 X3 * 0.0909090909 * -"  # up to 0.8
e16 = " X2 -0.245982 * X 1.00976 * + 0.021622 +"                   # up to 1.65
els = "pi 0.5 * 1 X / - 1 X3 3 * / + 1 X5 5 * / - 1 X7 7 * / - "   # from 1.65 onwards
atan = "X@ 0.8 <= "+e8+" X 1.65 >= "+els+" "+e16+" ? ?"
# atan = "X@ 0.8 <= "+e8+" "+e16+" ?"                              # for atan([0-1])
Expr(last,Format("x range_max / "+atan+" range_max *"),"") # 413
Old 27th September 2021, 18:59   #426  |  Link
tormento
Acid fr0g
tormento's Avatar
You are the most welcome. AFAIK you used a McLaurin (x=0) and not a Taylor series (where x is an arbitrary point), that's why it doesn't fit for |x| larger than 0.
Old 27th September 2021, 22:18   #427  |  Link
Dogway
Yes I know, I'm currently working on cos(x) where x is pi/2 since some functions need cosines as high as pi.
Here's the Taylor series of cos(x) when x=pi/2, converges between 0 and pi.
cosTP = " pi 0.500001 * - X@ 0.00000367321 swap - X dup * X2@ 0.0000018366 * + X2 X * X3@ 0.166666666 * + X2 dup * 0.00000015305 * - X2 X3 * 0.008333333 * -"
Expr(last,Format("x range_max / pi * "+cosTP+" range_max *"),"") # 390
#Expr(last,Format("x range_max / pi * cos range_max *"),"") # 70
Old 27th September 2021, 23:25   #428  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
If pi/2 < x < pi, can't you just subtract x from pi and then take the negative of the result?
Or have I misunderstood... you say you're working on cos(x) when x = pi/2, but that's just zero every time...
Possible helpful reading: http://gruntthepeon.free.fr/ssemath/sse_mathfun.h
wonkey_monkey is offline   Reply With Quote
Old 27th September 2021, 23:36   #429  |  Link
Dogway
It's not cosine of pi/2 but a cosine function approximation around pi/2, so when cos(pi) it gives more accurate results than if I design the Taylor series around x=0.
Here is the desmos graph (check around x=pi )
Old 27th September 2021, 23:42   #430  |  Link
wonkey_monkey
I see, so as per my previous comment: you could design your calculation around 0 < x' < pi/2, reducing x to this range appropriately first. It might be faster for the same accuracy (or more accurate for the same speed).
The purple one needs 5 powers of x, the green one only needs 3. You would basically be taking the first part of the green line (up to pi/2) and rotating it around its endpoint to extend it to pi.
https://www.desmos.com/calculator/bktakxsm7u
Edit: there is a slight discontinuity at pi/2 but you can remove that my nudging the coefficients.
Old 28th September 2021, 00:04   #431  |  Link
Dogway
Yes, makes total sense, inverting the function and make it piecewise. I will bench speed and quality in case the discontinuity is visible.
Old 28th September 2021, 00:05   #432  |  Link
tormento
Acid fr0g
tormento's Avatar
Please share the desmos, it was really interesting.
Old 28th September 2021, 00:10   #433  |  Link
wonkey_monkey
Using 0.0013934 (this is just a rough approximation, not a calculated value) as the x^6 coefficient should all but remove the discontinuity. The maximum error is about 0.0000924. Adding an x^8 term can make the max error almost 100x smaller.
I'll try and work on best coefficients tomorrow, if I have time.
Old 28th September 2021, 00:27   #434  |  Link
Dogway
I tested and speed is 2% faster, it was already pretty fast, from 420 to 430fps. Quality wise I think it's better because it doesn't touch range extremes which are always sensible and the discontinuity is not appreciable. But if you can find a better coefficient that would be great.
There's another approximation noted by tormento, the Bhaskara I approx. but it's not as good as the six degree polynomial.
(pi^2 - 4x^2)  / (pi^2 + x^2)
BTW, if I compute the Taylor series for x=pi/4 it might fix the discontinuity -> graph
EDIT: yep, coefficient 0.001329 is almost a match, much better.
tormento: check wonkey_monkey's link above. He includes all the three approximations, the one from my post is the purple.
Old 28th September 2021, 02:39   #435  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
"Real" testing,,
Hi Dogway (and the rest),
I asked a question back here :-
https://forum.doom9.org/showthread.p...24#post1953024
That didn't get answered.
Do any of you ppl that are constantly improving & testing these filters & scripts, actually do any encoding with them ??
Like I mean a full length, 4K movie with your filters, just to see how they REALLY perform !!!
If you're only "benching" them, that's probably NO indication on how they will work in an encoding job.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
PD Builds, etc
Pauly Dunne is offline   Reply With Quote
Old 28th September 2021, 03:51   #436  |  Link
kedautinh12
He was answered you
https://forum.doom9.org/showthread.p...31#post1953031
Old 28th September 2021, 07:22   #437  |  Link
Pauly Dunne
Grumpy Old Man.
Originally Posted by kedautinh12 View Post
I don't consider that as an answer...it's very a confusing comment, and I still can't get the latest builds to work.
And I do remember encoding DVD's at a very slow pace, my fave tool was DVD2SVCD, and I had a very powerful dual Athlon MP2600 system to churn thru it.
PD Builds, etc
Old 28th September 2021, 15:16   #438  |  Link
wonkey_monkey
Best coefficients I've found so far:
Up to x^6:
1 - 0.5x^2 + 0.041574811029363x^4 - 0.001292112506266x^6
Max error: 0.000019976279586 (43x better than truncated Taylor series, 4.6x better than modifying only last term to avoid discontinuity)
Up to x^8:
1 - 0.5x^2 + 0.041666666666667x^4 - 0.001387723061268x^6 + 0.000023661684925x^8
Max error: 0.000000330438621 (72x better than truncated Taylor series, 6x better than modifying only last term to avoid discontinuity)
Old 28th September 2021, 15:38   #439  |  Link
Dogway
Thanks a lot. Will keep the first one for performance reasons.
EDIT: By the way, I managed to also create a Taylor (Maclaurin) series for exp(x), I know 'exp' is accelerated in Expr but it was the main cause of ex_bilateral() drop in performance ('exp' called many times) so I decided to give it a go. Well it works very well for as low as a 5th degree polynomial even in PC levels, it increased from 115fps for ex_bilateral(1) to 167fps, so it's faster than vsTBilateral(). In ex_contrast() it isn't worth it as it's only called once, and the range of action is larger (from -8 to +8 in x)
Old 28th September 2021, 22:15   #440  |  Link
Dogway
Access violation, not sure if my fault or a bug in avs+:
a=FlipHorizontal()
#~ ex_blend(a,"interpolation",1,0.7)
cosTS  = "X dup * X2@ 0.500001 * 1 swap - X2 dup * X4@ 0.041574811029363 * + X4 X2 * 0.001292112506266 * -" # 0.00129 to fix discontinuity at pi/2
cosT  = "X@ pi 0.500001 * <= "+cosTS+" dup pi swap - -1 * ? "
Expr(last,a,"x ymin - ymax ymin - / pi * "+cosT+" 0.250001 * 0.500001 swap - y ymin - ymax ymin - / pi * "+cosT+" 0.250001 * - ymax ymin - *" ,"")
I also tried with "dup pi swap - 1 neg * ? " but the neg operator seems to not be working.
This works though:
cosTS  = "X dup * X2@ 0.500001 * 1 swap - X2 dup * X4@ 0.041574811029363 * + X4 X2 * 0.001292112506266 * - dup"
cosT = "X@ pi 0.500001 * <= "+cosTS+" pi swap - -1 * ? "
Looks like I cannot dup a referenced string(?)
avisynth, dogway, filters, hbd, packs
