Old 24th September 2021, 11:48   #401  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Dogway View Post
The range expansion is only for the motion vectors
Oh, wow, thanks. Why didn't you default to 0? Perhaps not everybody wants the video to be "touched" on the dark parts.
Please, give me a hint: some movies, such as Transformers saga, has too much sharpness, giving really low compressibility ratio. FranceBB suggested me to use some vertical only MedianBlur or Blur.
What kind of command would you suggest me from your ex_plugins? And should it be applied before or after denoising?
@turment on Telegram
tormento is online now   Reply With Quote
Old 24th September 2021, 12:06   #402  |  Link
Dogway
I need to see what kind of sharpness. If there isn't any overshoots a simple blur before denoising can do ( ex_boxblur(mode="weighted") with 0.5 or 0.3 value ) passed through an edge mask or even ex_smooth() but -had an idea- needs limiting. If source has overshoots (ringing or halo) you might need to use a FIR filter as once cretindesalpes pointed to me, read here for FIR filtering.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 24th September 2021, 12:16   #403  |  Link
tormento
Acid fr0g
tormento's Avatar
A clip is enough?
And what about str=0 vs str=3 as default?
Old 24th September 2021, 12:19   #404  |  Link
Dogway
Default is Str=3 because most sources benefit from a slight bump in dark areas. Clips that might not benefit as much are generally sports, TV programs which are tuned for a bright surround viewing environment.
Yes, small clip is enough. I will try to bench ex_smooth() against it.
Old 24th September 2021, 17:35   #405  |  Link
tormento
Acid fr0g
tormento's Avatar
Here it is.
Object countours are insanely sharp, just look at sides of houses, cars and robots.
FranceBB knows the issue and solved it with some blur.
Old 24th September 2021, 18:16   #406  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yes I do and yes I did.
I work in post production and this generally happens with some rather sharp shots. What happens is that when I get a shot from like a Drone or even a downscaled shot from a 4K camera to FULL HD 50p and I divide it in fields to get 25i I always always always get aliasing. Even if I get 25p materials and I leave them like that and I just flag them as interlaced (so they're progressive) I still have aliasing.
For this very reason I always always always suggest to blur vertically only a bit to avoid aliasing.
blur(0, 1)
Works.
See this: https://forum.doom9.org/showthread.php?p=1875091
Old 24th September 2021, 18:54   #407  |  Link
tormento
Acid fr0g
tormento's Avatar
@Dogway, is it correct that setting contrasharp=true, it requires RGTools? I was almost sure that you put removegrain into ex_tools.
Old 24th September 2021, 20:42   #408  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by FranceBB View Post
blur(0, 1)
Plain and simple
Let's see what Dogway will pull out of the hat.
Old 24th September 2021, 21:30   #409  |  Link
Dogway
Yes, sorry I didn't have time to check it (battle in RGB to HSV conversion!), but I tweaked Savitzky-Golay smoothing filter a few hours ago to remove haloes. I even added clamp to ex_luts but that will be uploaded in the next few days.
function ex_smooth(clip a, int "radius", int "radiusV", bool "sharp", bool "limit", string "mode", int "UV", bool "fulls") {
    rgb  = isRGB(a)
    isy  = isy(a)
    bi   = BitsPerComponent(a)
    rd = Default(radius,  1)            # from 0 to 3
    rv = Default(radiusV, rd)           # from 0 to 3
    sh = Default(sharp, false)          # Sharp version of S-G mode
    lm = Default(limit,    sh)          # Enable limiting for Sharp smoothing
    md = Default(mode,  "SG")
    UV = Default(UV,    rgb ? 3 : 1)
    fs = Default(fulls, rgb)
    rd = max(rd, 0)
    rv = max(rv, 0)
    rd == 3 || rv == 3 ? Assert (!sh, "S-G Sharp mode only supports radius < 3")                    : nop()
    md == "SNN"        ? Assert (rd == rv && rd < 2 && rv < 2, "SNN mode only supports radius < 2") : nop()
    if (!sh) {
    # Quadratic/Cubic (2nd and 3rd degree polynomials)
    strv = rv == 1 ? "x[0,1] x[0,-1] + 4 * x[0,0] 5.666666666 * + x[0,-2] x[0,2] + - 0.085714286 *"        : \
           rv == 2 ? "x[0,1] x[0,-1] + 2 * x[0,0] 2.333333333 * x[0,-2] x[0,2] + + + x[0,-3] x[0,3] + 0.666666666 * - 0.142857143 *"                                : \
           rv == 3 ? "x[0,3] x[0,-3] + 4.666666666 * x[0,2] x[0,-2] + 13 * x[0,1] x[0,-1] + 18 * x[0,0] 19.666666666 * + + + x[0,-4] x[0,4] + 7 * - 0.012987013 *"  : ""
    strh = rd == 1 ? "x[-1,0] x[1,0] + 4 * x[0,0] 5.666666666 * + x[2,0] x[-2,0] + - 0.085714286 *"        : \
           rd == 2 ? "x[-1,0] x[1,0] + 2 * x[0,0] 2.333333333 * x[2,0] x[-2,0] + + + x[3,0] x[-3,0] + 0.666666666 * - 0.142857143 *"                                : \
           rd == 3 ? "x[3,0] x[-3,0] + 4.666666666 * x[2,0] x[-2,0] + 13 * x[1,0] x[-1,0] + 18 * x[0,0] 19.666666666 * + + + x[-4,0] x[4,0] + 7 * - 0.012987013 *"  : ""
    } else {
    # Quartic/Quintic (4th and 5th degree polynomials) (sharper)
    strv = rv == 1 ? "x[0,1] x[0,-1] + 15 * x[0,0] 26.2 * x[0,3] x[0,-3] + + + x[0,-2] x[0,2] + 6 * - 0.021645022 *"                                                : \
           rv == 2 ? "x[0,2] x[0,-2] + 2 * x[0,1] x[0,-1] + 9 * x[0,0] 11.933333333 * x[0,4] x[0,-4] + + + + x[0,-3] x[0,3] + 3.666666666 * - 0.034965035 *"        : ""
    strh = rd == 1 ? "x[1,0] x[-1,0] + 15 * x[0,0] 26.2 * x[3,0] x[-3,0] + + + x[-2,0] x[2,0] + 6 * - 0.021645022 *"                                                : \
           rd == 2 ? "x[2,0] x[-2,0] + 2 * x[1,0] x[-1,0] + 9 * x[0,0] 11.933333333 * x[4,0] x[-4,0] + + + + x[-3,0] x[3,0] + 3.666666666 * - 0.034965035 *"        : ""
    strv = md == "SNN" ? "x[0,0] X@  x[-1,1] A@ - abs X x[1,-1]  H@ - abs + M@
                          X          x[0,1]  B@ - abs X x[0,-1]  G@ - abs + N@ min
                          X          x[1,1]  C@ - abs X x[-1,-1] F@ - abs + O@ min
                          X          x[-1,0] D@ - abs X x[1,0]   E@ - abs +    min W^
                          W M == A H + W N == B G + W O == C F + D E + ? ? ? 0.500001 *" : strv
    rv == 0 ?      a        : \
    isy     ? Expr(a,    strv                                                       ) : \
    UV == 1 ? Expr(a,    strv, ""                                                   ) : \
              Expr(a,    strv, ex_UVexpr(strv, UV, bi, rgb, fs), scale_inputs="none")
    rd == 0 || md == "SNN" ? last                                                     : \
    isy     ? Expr(last, strh                                                       ) : \
    UV == 1 ? Expr(last, strh, ""                                                   ) : \
              Expr(last, strh, ex_UVexpr(strh, UV, bi, rgb, fs), scale_inputs="none")
	lm && sh ? ex_clamp(last,a.ex_expand(min(1,rd),"horizontal").ex_expand(min(1,rv),"vertical"),a.ex_inpand(min(1,rd),"horizontal").ex_inpand(min(1,rv),"vertical"),0,0) : last
	# ex_luts(last,a,mode="clamp",UV=uv) performance update in the next few days
Call like "ex_smooth(1 or 2, sharp=true, limit=true)"
If it's only vertical I guess "ex_smooth(0, 1, sharp=true)" can do.
EDIT: SantiagMod also works very good. But I see there's some ringing in the source.
EDIT2: Some alternatives:
Finedehaloer
SantiagMod(strh=2,strv=2)
a=last
ex_luts(last,last.removegrain(12,0),mode="clamp",UV=1)
ex_lutxy(last,a,"x y - abs 7 > y x y min ?")
# ex_boxblur(0.15,mode="weighted") # optional
FIR:
deconv_h = "0 -5 25 100 25 -5 0 "
mt_convolution (deconv_h, deconv_h, Y=3, U=2, V=2)
ExTools do have counterpart filters of RGTools, but is not SO hellish fast (90% there still), so SharpenersPack is in MIX mod. I should probably place it inside the MIX mods folder.
Old 25th September 2021, 00:59   #410  |  Link
anton_foy
Sorry but what is ex_smooth? The purpose? HSV conversion sounds very interesting! Just wondering because of the way I try to make my filters.
anton_foy is offline   Reply With Quote
Old 25th September 2021, 01:46   #411  |  Link
Dogway
A smoothing filter, between antialiasing and blur. I just added a limiter because it was creating some 2nd order halos.
Yes, HSV conversion is proving to be more complex than I thought. There are better cylindrical models and easier to implement but I want to add HSV to TransformPack for completion and also comparison for the Skin_qualifier()
Old 25th September 2021, 02:21   #412  |  Link
anton_foy
Interesting indeed although I must check into "skin_qualifier", guess that the name says it all? Please shout out if you get to finish the hsv-conversion you mentioned a while ago. I would love to try to base a denoising filter off of that colorspace.
Old 25th September 2021, 11:17   #413  |  Link
tormento
Acid fr0g
tormento's Avatar
So you suggest me to wait for the definitive version?
Old 25th September 2021, 19:49   #414  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Moved from the Avisynth+ discussion:
"x 0 > y x / atan A@ x 0 < y 0 >= & A pi + x 0 < y 0 < & A pi - x 0 == y 0 > pi 0.5 * y 0 < pi -0.5 * 0 0 ? ? ? ? ? ?"
I think there's some things wrong with this. If you map it to pixel coordinates (with suitable multiplication and offset) you get this:
Note the vertical line.
Separately, the deepest conditional seems to be:
pi -0.5 * 0 0 ?
Which will always equate to zero.
While attempting to find an alternative, I've got as far as
y x / atan
dup pi - x 0 < swap2 ?
dup 2 pi * + x 0 < y 0 > & swap2 ?
though it seems to still work even when x should be 0 (I used sx instead as a pixel coordinate), which makes no sense to me.
I use "swap2 ?" for conditionals because to me it makes far, far more sense to have the condition last.
wonkey_monkey is offline   Reply With Quote
Old 25th September 2021, 22:59   #415  |  Link
Dogway
Thanks for looking into it. I found the error was at the first conditional, changing it to ">=" fixes the line issue (despite originally being ">" in the wiki).
The first 0 stands for "undefined" when all the ternaries fail, and the last 0 when "x < 0" (first conditional) which seems wrong because following we have "minus than 0" comparisons, so might need to reorder the ternaries.
I implemented the compact version and also works.
ex_lutspa(mode="absolute", expr="x 255 - X@ 0 > y 255 - Y@ X / atan A@ Y 0 > pi 0.5 * X Y / atan B@ - Y 0 < 0 B - pi 0.5 * - X 0 < A pi + X 0 == Y 0 == & 0 0 ? ? ? ? ? pi 180 / * 2048 * 128 +", UV=128)
And another one without conditionals (only for the sign(x) operator):
ex_lutspa(mode="absolute", expr="x 255 - X@ 0 == 0 x dup abs / ? SX^  y 255 - Y@ 0 == 0 y dup abs / ? SY^  SX dup * Y X / atan *   1 X 0 < -1 1 ? - 0.5 *    SY dup dup * - 1 + * pi * +   pi 180 / * 4096 *", UV=128)
Improved (maybe) and much faster:
ex_lutspa(mode="absolute", expr="x 255 - X^   y 255 - Y^    X dup abs / SX^   Y dup abs / SY^   SX dup * Y X / atan *   1 SX - 0.5 *    SY dup dup * - 1 + * pi * + 180 pi / * 128 + ", UV=128)
Please forgive my awkward normalization, I don't know what I'm doing lol
@tormento: yes, wait for the improved "HSV". I already implemented IPT model in other projects, it's miles better than HSV as it is UCS (uniform color space) in the HUE domain. But I need HSV to correlate skin HUE on HSV (33.5) to IPT.
Old 26th September 2021, 08:56   #416  |  Link
tormento
Acid fr0g
tormento's Avatar
In your opinion, would I lose more details and general quality using some light vertical blur or increasing from tr=3, thsad=300 to tr=4, thsad=400?
Old 26th September 2021, 11:01   #417  |  Link
Dogway
I didn't spot any staircasing so vertical blur seems very destructive to me.
Old 26th September 2021, 14:45   #418  |  Link
tormento
Acid fr0g
tormento's Avatar
Staircasing?
Old 26th September 2021, 14:59   #419  |  Link
Dogway
A type of aliasing.
EDIT: By the way:
Can't you use Taylor series? Usually with 5/6 terms you have very good approximation.
Wow, had no idea of it. At some point I searched for optimizing exponent operator and found nothing. This is a game changer. I tried though to implement to ex_contrast() without success, these days I'm a bit slow (fatigue...)
cont   = 5.0
pivot  = 0.5
knee   = 1. / (1. + exp(cont *  pivot))
shldr  = 1. / (1. + exp(cont * (pivot - 1.)))
shmkn  = shldr - knee
rshmkn = 1. / shmkn
# 'exp' Taylor series
exp    = "X@ X 2 ^ 0.500001 * + X 3 ^ 0.166666666 * + X 4 ^ 0.041666666 * + 1 +"
Expr(last, Format("1 1 {cont} {pivot} x ymin - ymax ymin - / - * "+exp+" + / {knee} - {rshmkn} * ymax ymin - * ymin +"), "")
Old 26th September 2021, 16:19   #420  |  Link
tormento
Acid fr0g
tormento's Avatar
I am really happy to be of help to one of the few who have helped us all!
avisynth, dogway, filters, hbd, packs
