Old 26th August 2021, 08:33   #221  |  Link
kedautinh12
Originally Posted by Pauly Dunne View Post
Wow, I don't understand why that could be an issue.....
I've only got 32Gb, 3600Mhz DDR4.
Can you post your log with AVSMeter or avisynth info tool??
Old 26th August 2021, 08:34   #222  |  Link
Dogway
This is my plugins list, and I have no problems with any of your examples.
ConvertStacked.dll
DirectShowSource.dll
ExTools.avsi
FFMS2.avsi
ffms2.dll
ffms2.lib
ffmsindex.exe
ImageSeq.dll
KNLMeansCL.dll
LSFmod.v2.9x.avsi
masktools2.dll
MtModes.r851.avsi
mvtools2.dll
RgTools.dll
SharpenersPack.avsi
Shibatch.dll
SMDegrain v3.2.5d.avsi
TimeStretch.dll
Utils-r41.avsi
Zs_RF_Shared.avsi
I think your problem is something is not updated, namely Zs_RF_Shared? Update to V1.154.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 26th August 2021, 10:04   #223  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Not too sure how to do that...I'll have a look tomorrow.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
PD Builds, etc
Pauly Dunne is offline   Reply With Quote
Old 26th August 2021, 10:10   #224  |  Link
Pauly Dunne
Grumpy Old Man.
ConvertStacked.dll
ExTools.avsi
FFMS2.avsi
ffms2.dll
ffms2.lib
ffmsindex.exe
ImageSeq.dll
KNLMeansCL.dll
LSFmod.v2.9x.avsi
masktools2.dll
MtModes.r851.avsi
mvtools2.dll
RgTools.dll
SharpenersPack.avsi
Shibatch.dll
TimeStretch.dll
Utils-r41.avsi
Zs_RF_Shared.avsi
Excellent...yes I think I am running v1.153.
Will keep you posted, and thankyou so much for your help
PD Builds, etc
Old 26th August 2021, 10:12   #225  |  Link
kedautinh12
-avsinfo in AVSMeter or you can read here for more details
https://forum.doom9.org/showthread.php?t=174797
Old 26th August 2021, 10:42   #226  |  Link
Pauly Dunne
Grumpy Old Man.
I generally run it within RipBot, so I'm not sure if there are any logs generated, or where they go.
I guess I could run it stand alone (could I ?)
PD Builds, etc
Old 26th August 2021, 16:00   #227  |  Link
on command line just type path and name eg d:\avsmeter.exe
and produces eg
EDIT: I have "C:\BIN" in my environment variables PATH, so I don't have to put the path the execuatable of avsmeter.
I store my cmd exe's in C:\BIN
Old 27th August 2021, 02:02   #228  |  Link
Pauly Dunne
Grumpy Old Man.
Hi StainlessS,
But the only info I can get this to display is in the default installation folder, NOT where I have all the "custom" info for RipBot
Got it work, had to copy my custom stuff into the default folder....didn't show any problems, that I could see.
PD Builds, etc
Old 27th August 2021, 02:06   #229  |  Link
Pauly Dunne
Grumpy Old Man.
ConvertStacked.dll
ExTools.avsi
FFMS2.avsi
ffms2.dll
ffms2.lib
ffmsindex.exe
ImageSeq.dll
KNLMeansCL.dll
LSFmod.v2.9x.avsi
masktools2.dll
MtModes.r851.avsi
mvtools2.dll
RgTools.dll
SharpenersPack.avsi
Shibatch.dll
TimeStretch.dll
Utils-r41.avsi
Zs_RF_Shared.avsi
Hey Dogway,
Well, unfortunately, I was already using v1.154 of Zs RF, so that hasn't fixed the problem.
Now I shouldn't need to run all those plugins you've listed above, but maybe I should add them, and see what happens.
edit :- OK, I've had a win x 1,000....I went thru all your list, and the only one that I hadn't tried was "SharpenersPack.avsi", so I popped that in, and away it went with SMDegrain 3.2.5d.
So now I need to is clean up the mess I've made of all my files & folders, and I should be good to go, and "kedautinh12" gave me a good idea to use avsi's, instead of avs's.
And I'd like to now figure out how to incorporate BM3D....but isn't that only for nVidia GPU's ??
PD Builds, etc
Old 27th August 2021, 02:21   #230  |  Link
Pauly Dunne
Grumpy Old Man.
This is the best I could do....
PD Builds, etc
Old 27th August 2021, 02:47   #231  |  Link
kedautinh12
Hi StainlessS,
But the only info I can get this to dispaly is in the default installation folder, NOT where I have all the "custom" info for RipBot
Transport your filters to default installation folder and check with AVSMeter again
Old 27th August 2021, 03:01   #232  |  Link
Pauly Dunne
Grumpy Old Man.
Wow, OK, I'll try that, but there's so many of them...
But what is this going to prove ??
It's strange that the scripts I sent Dogway worked for him...
PD Builds, etc
Old 27th August 2021, 03:06   #233  |  Link
kedautinh12
To checked what errors in your scripts/filter. And you don't need call them anymore in ripbot (don't need LoadPlugin/Import anymore)
Old 27th August 2021, 03:10   #234  |  Link
Pauly Dunne
Grumpy Old Man.
So you're saying I don't need these anymore ???
#Custom
LoadPlugin("%AVISYNTHPLUGINS%\mvtools\mvtools2.dll")
LoadPlugin("%AVISYNTHPLUGINS%\RgTools\RgTools.dll")
Import("%AVISYNTHPLUGINS%\scripts\extras\LSFmod29ex.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\ExTools52.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\SMDegrain325d.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\Zs_RF_Shared.avs")
video=SMDegrain(video,tr=6,thSAD=600,contrasharp=30,prefilter=2,str=1.2,refinemotion=true)
I can't see that working, that's the way RipBot is built
PD Builds, etc
Old 27th August 2021, 03:15   #235  |  Link
Pauly Dunne
Grumpy Old Man.
So far all it's displaying is the filters & scripts info....no other, no errors
PD Builds, etc
Old 27th August 2021, 03:28   #236  |  Link
kedautinh12
Don't have functions duplicate??
Old 27th August 2021, 03:34   #237  |  Link
kedautinh12
#Custom
Yeah, i use megui with autoload install folder and don't need use call them with LoadPlugin/Import anymore cause they autoload by avisynth in autoload folder when i put them in it.
Btw, change .avs to .avsi, avs+ only autoload .avsi
Old 27th August 2021, 03:35   #238  |  Link
Pauly Dunne
Grumpy Old Man.
None that I noticed...
PD Builds, etc
Old 27th August 2021, 03:39   #239  |  Link
Pauly Dunne
Grumpy Old Man.
So if "everything" was in one folder, with the .avs's changed to .avsi, and I got the path correct, that would work ???
Could you give me an example of how you've addressed it ??
But what is the advantage of that ??
PD Builds, etc
Old 27th August 2021, 04:42   #240  |  Link
kedautinh12
Example: your script
video=ffms("...")
After you put all plugins/scripts in one autoload folder, you only use this script and it will work
ffms("...")
SMDegrain(tr=6,thSAD=600,contrasharp=30,prefilter=2,str=1.2,refinemotion=true)
That is what i do with megui
avisynth, dogway, filters, hbd, packs
