#1 | Link |
Frame rate problem
Hello!
I've been encoding a 1280x720 video without resizing, but joining it to another video and added 2 subtitles (one is a logo, the another is the op-ed karaoke). There are some parts where I can exactly tell if the quality got lower or higher. So I choosed x264 2pass Anime_Toons HQ (since my video is an anime) with the following settings: bitrate: 1951, deblocking 1;1, b-frames 16. The other settings still on the default. The encoding went well, but on a certain part, I can see that the picture gotten worse. I tried to test it more, so I cut those scenes to see whether the settings are wrong or not. The result: the video was perfect, even with the joined part and subtitles. Still, if I encode the whole video, the mess come back again. And some odd things occured meanwhile: the frame rate of the encoded video is not the original 23,976 fps, but 202 fps. How? Here are the properties of the four videos: Code:
Original: Overall bit rate : 2 930 Kbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.0 Format settings, CABAC : Yes Format settings, ReFrames : 11 frames Codec ID : V_MPEG4/ISO/AVC Duration : 23mn 54s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Title : [H264] Writing library : x264 core 115 r1995 c1e60b9 Code:
Join-video Overall bit rate : 2 024 Kbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Bit rate mode : Variable Bit rate : 1 951 Kbps Maximum bit rate : 6 108 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 6.39 MiB (100%) Writing library : x264 core 120 r2120 0c7dab9 Code:
Cutted scenes Overall bit rate : 1 906 Kbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Format settings, GOP : M=6, N=20 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 37s Bit rate mode : Variable Bit rate : 1 951 Kbps Maximum bit rate : 13.3 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 22.2 MiB (100%) Writing library : x264 core 119 r2106 07efeb4 Code:
Encoded video Overall bit rate : 2 149 Kbps Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Format settings, GOP : M=1, N=21 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 24mn 21s Bit rate mode : Variable Bit rate : 1 951 Kbps Maximum bit rate : 58.4 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 202 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 340 MiB (91%) Writing library : x264 core 119 r2106 07efeb4 |
#3 | Link |
I'm still away from my computer, but I know my script look like this:
v1=DirectShowSource("D:\source.mkv",audio=false) v2=DirectShowSource("D:\extra.mp4",audio=false) v1 + v2 TextSub("D:\logo.ass") TextSub("D:\Op-Ed 01.ass") ConvertToYV12() |
#4 | Link |
Maybe mediainfo is incorrect in reporting ? The method you used in "cutting" that encoded section for examination may have caused the issue (e.g. not cutting on keyframes)
For the script, Avisynth won't let you append v1+v2 if the frame rates differ between source.mkv and extra.mp4 anyway Info() will report the FPS, and encode log file will provide the other information regarding the encode So assuming those were correct, the issue was probably with cutting the segment - provide more information on how you did this |
#5 | Link |
i run it with AvsPmod and first, it really complaines about the different frame rate, so I converted that extra video from 29 fsp to 23,976 fps. And after changing the video to this new one, the script run with no problem. As I said, if I cut and join several scenes from the whole video (including the extra one), the result is perfect. But when I converted the whole video with the same setting, the quality dropped, especially in certain scenes. Players read it well, but why the quality dropped?
#6 | Link | ||
If you're concerned about the quality drop, use a higher bitrate
frame, rate |
