#81 | Link |
typo lover
my repositories |
#82 | Link |
Do you still plan on releasing v0.0.4? I'd love to get a similar bump in speed I see with your alpha version benchmark since using this is the only way I found to prevent crashing with memory heavy filters and weird things happen when I use avs2yuv. Also, having everything all in one is pretty great.
#83 | Link | |
Totally Clueless
https://github.com/doobry/avs2pipe |
#84 | Link |
typo lover
oh doobry! welcome back!
my repositories |
#86 | Link |
typo lover
my repositories |
#87 | Link |
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
#89 | Link |
Thanks doobry.
It's indeed very easy to compile; change the path to MinGW in the .bat, run it... and you're done. It compiled so fast that I ran it twice since I was sure it had failed the first time. And I got a 3.12% speedup in my first test so that's a good thing. Edit: The second test when encoding them back to back in similar condition is less good though: h264_10bit_a2p_0-0-3: 0:17:44.77 h264_10bit_a2p_0-0-4: 0:17:42.56 h264_10bit_a2pmod_0-0-3: 0:17:44.16 h264_10bit_a2pmod_0-0-4: 0:17:38.85 Last edited by SamKook; 31st December 2011 at 19:54. |
#90 | Link | |
hi
I'm struggling to migrate from avs2yuv to avs2pipemod. Any suggestion on corresponding avs2pipemod command line for this avs2yuv to imagemagick. Quote:
#92 | Link | |
Yes, I'm weird.
avs2pipemod supports raw output like avs2yuv too. I think here is the equivalent of Yellow_'s command line for avs2pipemod:
#93 | Link |
You seem to be correct. I didn't got it working in my last tests, but it seems I just picked the wrong mode (stacked instead of interleaved) and wrongly assumed the piping tool would convert the high bitdepth into a different format.
#96 | Link |
typo lover
update
avs2pipemod-0.1.1.7z(removed) I rewrote almost code. * avs2pipemod detects avisynth version, and changes the actions. (thus, avs2pipe26mod was removed.) * avisynth.lib is unnecessary any longer. for win64 builds can also be compiled now.
my repositories Last edited by Chikuzen; 28th January 2012 at 15:18. |
#100 | Link | |
typo lover
Is it a very difficult subject ? For present me, yes, it is very difficult... Although I began to study the C language and one year has passed, it may be able to do, if I will try hard for three or more years.
my repositories Last edited by Chikuzen; 30th January 2012 at 12:09. |
avs2pipe |
