1st April 2023, 16:44 | #141 | Link |
Will do.
Main issue I have atm. with it, is that when the head covers, most of the image, only parts of the head seem to be processed. This kind of ruins the image if the person has longer hair. (using detector = 1, doesn't help either) https://imgsli.com/MTY2MjEw Suzie with weight=1 Last edited by Selur; 1st April 2023 at 16:55. |
1st April 2023, 16:57 | #142 | Link |
At least the face now looks like it belongs to the same person
1st April 2023, 19:06 | #143 | Link |
Here's an example of weight 0 and weight 1: https://imgsli.com/MTY2Mjc4
2nd April 2023, 10:56 | #144 | Link |
Did some further testing and if upscale is > 1 (weight=1) and the upscaling is later undone it basically can be used as a 'face detail enhancer' which might be interesting.
Also in combination with FeMaSR (with weight<1) it can be used to fix the face distortions FeMaSR does. This does not fix the issue with half enhanced heads, but seems to be a good way to use the filter. SwinIRx4+vsCodeFormer: https://imgsli.com/MTY2NDA3, looks nice frame-by-frame, but isn't really temporally stable => adding 3xQTGMC_type3. Cu Selur Ps.: got a nice example of what weight 0 can do: https://imgsli.com/MTY2NDI2,... Last edited by Selur; 2nd April 2023 at 13:32. |
2nd April 2023, 18:13 | #145 | Link |
Okay, small update in regard to Vapoursynth R62:
TensorRT doesn't support Python 3.11 atm. Latest TensorRT-package (TensorRT-8.6.0.12.Windows10.x86_64.cuda-11.8.zip) from https://developer.nvidia.com/tensorrt does not contain (TensorRT-8.6.0.12.Windows10.x86_64.cuda-11.8.zip\TensorRT-8.6.0.12\python) a cp311 file. So all the filters that use TensorRT won't work. => Hoping NVIDIA will release a Python 3.11 file in the near (who knows) future. Cu Selur Last edited by Selur; 8th April 2023 at 13:50. |
16th April 2023, 17:04 | #146 | Link |
Maybe interesting to some:
https://github.com/HolyWu/vs-grlir uses real-world image super-resolution model of GRL for Image Restoration https://imgsli.com/MTcxMDA1 Cu Selur |
23rd April 2023, 13:11 | #150 | Link |
btw. vs-grlir just got updated and not supports multiple models, cuda_graphs, fp16.
:param model: Model to use. 0 = Blind Image SR 1 = Defocus Deblurring 2 = Motion Deblurring (GoPro) 3 = Motion Deblurring (RealBlur-J) 4 = Motion Deblurring (RealBlur-R) 5 = Demosaicking 6 = Denoising (sigma 15) 7 = Denoising (sigma 25) 8 = Denoising (sigma 50) 9 = JPEG compression artifact removal (quality 10) 10 = JPEG compression artifact removal (quality 20) 11 = JPEG compression artifact removal (quality 30) 12 = JPEG compression artifact removal (quality 40) 13 = Classical Image SR (scale 2) 14 = Classical Image SR (scale 3) 15 = Classical Image SR (scale 4) Models 0, 12-15 are for upscaling, the others are for filtering. Nice! Cu Selur |
13th June 2023, 17:47 | #151 | Link |
Has anyone tried https://github.com/tongyuantongyu/vs-NNVISR/ ?
14th June 2023, 17:52 | #152 | Link |
Tried to test it by extracing everything into "F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR" ending with:
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cublas64_12.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cublasLt64_12.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudart64_12.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_adv_infer64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_adv_train64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_cnn_infer64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_cnn_train64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_ops_infer64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_ops_train64_8.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvblas64_12.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_builder_resource.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_dispatch.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_lean.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_plugin.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_vc_plugin.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvonnxparser.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvrtc-builtins64_121.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvrtc64_120_0.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\vs-nnvisr.dll F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\fe_n2_2x2_l4_yuv1-1.onnx F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\fe_n4_4x4_l1.onnx F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\ff_n2_2x2_l4_yuv1-1.onnx F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\ff_n4_4x4_l1.onnx Code:
# Imports import vapoursynth as vs # getting Vapoursynth core core = vs.core # Loading Plugins core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/vslsmashsource.dll") core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR/vs-nnvisr.dll") # source: 'G:\TestClips&Co\files\test.avi' # current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading G:\TestClips&Co\files\test.avi using LWLibavSource clip = core.lsmas.LWLibavSource(source="G:/TestClips&Co/files/test.avi", format="YUV420P8", stream_index=0, cache=0, prefer_hw=0) # Setting detected color matrix (470bg). clip = core.std.SetFrameProps(clip, _Matrix=5) # Setting color transfer info (470bg), when it is not set clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5) # Setting color primaries info (), when it is not set clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=0) # progressive clip = core.nnvisr.Super(clip, scale_factor=2, use_fp16=True, model="fe_n2_2x2_l4_yuv1-1.onnx", model_path="F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR") # set output frame rate to 25fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Output clip.set_output() Code:
Failed to evaluate the script: Python exception: Failed to load F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR/vs-nnvisr.dll. GetLastError() returned 1114. Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 3115, in vapoursynth._vpy_evaluate File "src\cython\vapoursynth.pyx", line 3116, in vapoursynth._vpy_evaluate File "C:\Users\Selur\Desktop\test_1.vpy", line 8, in core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR/vs-nnvisr.dll") File "src\cython\vapoursynth.pyx", line 2847, in vapoursynth.Function.__call__ vapoursynth.Error: Failed to load F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR/vs-nnvisr.dll. GetLastError() returned 1114. -> does anyone have an idea what I'm missing/overlooking? Cu Selur |
18th June 2023, 08:23 | #153 | Link |
Got it working.
dll folder needs to explicitly loaded: Code:
# Imports import vapoursynth as vs # getting Vapoursynth core core = vs.core import site import os import ctypes # Adding torch dependencies to PATH path = site.getsitepackages()[0]+'/../vsfilters/ResizeFilter/NNVISR' ctypes.windll.kernel32.SetDllDirectoryW(path) path = path.replace('\\', '/') os.environ["PATH"] = path + os.pathsep + os.environ["PATH"] Cu Selur Ps.: the explicit loading is fixed in 'v1.0.0-pre3' Last edited by Selur; 18th June 2023 at 08:45. |
19th June 2023, 14:44 | #155 | Link | |
Yes, vs-NNVISR support models which use mutliple frames for their calculation, main problem is finding such models (or training them yourself).
Side note: VSGAN also supports EGVSR models, which are 'temporal aware'. Current available models only run with specific values. "'scale_factor': 2, 'input_count': 2,..., 'interpolation': True" means the model always does scale by 2, takes two frames as input and interpolates the frames by 2. Also, the YUV420 1/1/1 means that it only works if color fromat is YUV420(P8), _Transfer, _Primaries and _Matrix are bt709. see: https://github.com/tongyuantongyu/vs...docs/models.md So to me, it's nice to see something different is being developed, but atm. I won't use it since it seems too much of a hassle. Cu Selur Ps.: Seems like the 'Enhance Everything' folks are revamping https://upscale.wiki/wiki/Model_Database into https://openmodeldb.info/ |
19th June 2023, 16:14 | #156 | Link | |
vsbasicvsrpp does temporal I think, with the length parameter: https://github.com/HolyWu/vs-basicvs..._init__.py#L50
(i have a tendency to drunk post) |
5th October 2023, 16:18 | #158 | Link |
Trying to set up a new portable Vapoursynth R64 with BasicVSR++&Co I'm stuck.
What I did so far to create a portable Vapoursynth with pytorch&co:
python -m pip install -U openmim mim install "mmcv>=2.0.0" python -m pip install -U vsbasicvsrpp python -m vsbasicvsrpp Code:
python -m pip install -U openmim Code:
Collecting aliyun-python-sdk-core>=2.13.12 (from oss2~=2.17.0->openxlab->opendatalab->openmim) Using cached aliyun-python-sdk-core-2.14.0.tar.gz (443 kB) Preparing metadata (setup.py) ... error error: subprocess-exited-with-error × python setup.py egg_info did not run successfully. │ exit code: 1 ╰─> [7 lines of output] Traceback (most recent call last): File "<string>", line 2, in <module> File "<pip-setuptools-caller>", line 34, in <module> File "C:\Users\Selur\AppData\Local\Temp\pip-install-t2r9eu4j\aliyun-python-sdk-core_b912f61c599e490b859580d9c77cbbd2\setup.py", line 41, in <module> VERSION = __import__(PACKAGE).__version__ ^^^^^^^^^^^^^^^^^^^ ModuleNotFoundError: No module named 'aliyunsdkcore' [end of output] I also tried installing aliyun-python-sdk-core with: Code:
python -m pip install aliyunsdkcore Code:
python -m pip install aliyun-python-sdk-core-v3 => does anyone have an idea how to fix this? Cu Selur |
5th October 2023, 16:40 | #159 | Link |
Seems to be related to the openmim version, when using:
python -m pip install -U openmim==0.3.7 openmim does install without an issue, but then Code:
set PATH=f:\Hybrid\64bit\Vapoursynth\Scripts;%PATH% mim install "mmcv>=2.0.0" Code:
Looking in links: https://download.openmmlab.com/mmcv/dist/cu121/torch2.1.0/index.html Collecting mmcv>=2.0.0 Using cached mmcv-2.0.1.tar.gz (469 kB) Preparing metadata (setup.py) ... error error: subprocess-exited-with-error × python setup.py egg_info did not run successfully. │ exit code: 1 ╰─> [20 lines of output] C:\Users\Selur\AppData\Local\Temp\pip-install-xs23k5n_\mmcv_a93dd8751cad4bf1bafcae67f7e00b43\setup.py:5: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html from pkg_resources import DistributionNotFound, get_distribution, parse_version Traceback (most recent call last): File "<string>", line 2, in <module> File "<pip-setuptools-caller>", line 34, in <module> File "C:\Users\Selur\AppData\Local\Temp\pip-install-xs23k5n_\mmcv_a93dd8751cad4bf1bafcae67f7e00b43\setup.py", line 466, in <module> ext_modules=get_extensions(), ^^^^^^^^^^^^^^^^ File "C:\Users\Selur\AppData\Local\Temp\pip-install-xs23k5n_\mmcv_a93dd8751cad4bf1bafcae67f7e00b43\setup.py", line 423, in get_extensions ext_ops = extension( ^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\torch\utils\cpp_extension.py", line 1076, in CUDAExtension library_dirs += library_paths(cuda=True) ^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\torch\utils\cpp_extension.py", line 1210, in library_paths paths.append(_join_cuda_home(lib_dir)) ^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\torch\utils\cpp_extension.py", line 2416, in _join_cuda_home raise OSError('CUDA_HOME environment variable is not set. ' OSError: CUDA_HOME environment variable is not set. Please set it to your CUDA install root. [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: metadata-generation-failed × Encountered error while generating package metadata. ╰─> See above for output. note: This is an issue with the package mentioned above, not pip. hint: See above for details. Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "f:\Hybrid\64bit\Vapoursynth\Scripts\mim.exe\__main__.py", line 7, in <module> File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "F:\Hybrid\64bit\Vapoursynth\Lib\site-packages\mim\commands\install.py", line 73, in cli exit(exit_code) ^^^^ NameError: name 'exit' is not defined (same when using openmim==0.3.8, openmim==0.3.9 fails at the install of openmim) Cu Selur Last edited by Selur; 5th October 2023 at 16:45. |
5th October 2023, 17:00 | #160 | Link | |
=> so there's hope, but will have to wait |
