14th February 2017, 17:48 | #64 | Link |
Update on New Script : Dehalo command is not recognised anymore. Tested with Basic + Final ... Earlier (Script) fps was 0.23 now it has dropped to 0.14 ... Plus there are Memory Leaks with same dependencies :
Core freed but 87 filter instances still exist Core freed but 87 filter instances still exist Core freed but 1525568512 bytes still allocated in framebuffers Core freed but 1525568512 bytes still allocated in framebuffers |
14th February 2017, 17:55 | #65 | Link | |
I'm Siri
14th February 2017, 18:03 | #67 | Link | |
I'm Siri
15th February 2017, 13:47 | #69 | Link |
I'm Siri
you can use the latest version now if you want to
and.. 1. stop complaining about memory leaks in this thread, if there're memory leaks in certain plugin(s), Vine is not what's causing all that, as I already told you here, https://forum.doom9.org/showpost.php...3&postcount=37 complain in the thread for the exact plugin that has memory leaks if you know which plugin is the one to blame, or complain in the main vaporsynth thread if you don't, Myrsloik or jackoneill will probably help you out if they're in a good mood.. 2. yeah, the new version is slower but the quality is better, you can stick to the previous version if you're not okay with the performance. |
15th February 2017, 13:49 | #70 | Link | |
11th January 2018, 23:32 | #71 | Link |
Cary Knoop
Levels adjustment?
Running Vine using a SMPTE RP 219 test chart with the following commands:
ref = Vine.Basic(c, h=31.18, sharp=0.48) ref = Vine.Basic(ref, h=13.86, sharp=0.16) c = Vine.Final([c, ref], [Vine.Super(c), Vine.Super(ref)], [6, 2, 4], sigma=2.2, alpha=0.18) |
15th January 2018, 04:16 | #72 | Link | |
I noticed no significant change in levels. Slightly different source. YUV422P8 bars with pluge pre / post vine Last edited by poisondeathray; 15th January 2018 at 05:34. |
15th January 2018, 05:35 | #73 | Link |
Cary Knoop
Squeezed as if the video levels are interpreted as full range and "squeezed" to video.
source = 'VideoLevelsRec709CineformSMPTE1080P.mov' c = core.lsmas.LWLibavSource(source) c = core.fmtc.bitdepth (c, bits=32) ref = Vine.Basic(c, h=31.18, sharp=0.48) ref = Vine.Basic(ref, h=13.86, sharp=0.16) c = Vine.Final([c, ref], [Vine.Super(c), Vine.Super(ref)], [6, 2, 4], sigma=2.2, alpha=0.18) return core.fmtc.bitdepth (c, bits=8) c.set_output() |
15th January 2018, 05:46 | #74 | Link |
No, it's legal range video levels except for the pluge; you can see the waveform in IRE in my post, I added it
Check each step with histogram ; for example comment out everything, except for lsmash source filter, check levels; the vine lines, check levels, comment out fmtc lines, check levels etc... Vine didn't do anything significant to levels in my test (beyond the expected slight changes in edges) Last edited by poisondeathray; 15th January 2018 at 05:52. |
16th January 2018, 04:59 | #75 | Link |
Cary Knoop
Tested this again, and well, I can't reproduce the situation.
I think we have to call it a user error (that's me). I am sorry. By the way, Vine works great! I was wondering how much change it would take to restrict the adjustments to horizontal adjustments only (i.e. reducing vertical stripes while keeping horizontal stripes alone)? |
28th May 2023, 13:13 | #78 | Link |
Does anyone know if there is an update for Vine to work with the latest version of Vapoursynth? I have been unable to find one.
I have had an attempt to do this myself, but with no luck. Def NLmeans brings an error message. Here is my version of Vine so far: Last edited by WaxCyl; 28th May 2023 at 13:54. Reason: add extra sentence |
28th May 2023, 13:17 | #79 | Link |
import vapoursynth as vs import math fmtc_args = dict(fulls=True, fulld=True) msuper_args = dict(hpad=0, vpad=0, sharp=2, levels=0, chroma=False) manalyze_args = dict(search=3, truemotion=False, trymany=True, levels=0, badrange=-24, divide=0, dct=0, chroma=False) mrecalculate_args = dict(truemotion=False, search=3, smooth=1, divide=0, dct=0, chroma=False) mdegrain_args = dict(plane=0, thscd1=16711680.0, thscd2=255.0) canny_args = dict(mode=1, op=0) nnedi_args = dict(field=1, dh=True, nns=4, qual=2, etype=1, nsize=0) class get_core: def __init__(self): self.MSuper = self.core.mvsf.Super self.MAnalyze = self.core.mvsf.Analyze self.MRecalculate = self.core.mvsf.Recalculate self.MDegrain = self.core.mvsf.Degrain self.KNLMeansCL = self.core.haf.KNLMeansCL self.Canny = self.core.tcanny.TCanny self.NNEDI = self.core.nnedi3.nnedi3 self.RGB2OPP = self.core.bm3d.RGB2OPP self.OPP2RGB = self.core.bm3d.OPP2RGB self.Resample = self.core.fmtc.resample self.Maximum = self.core.std.Maximum self.Minimum = self.core.std.Minimum self.Expr = self.core.std.Expr self.Merge = self.core.std.Merge self.MakeDiff = self.core.std.MakeDiff self.MergeDiff = self.core.std.MergeDiff self.Crop = self.core.std.CropRel self.AddBorders = self.core.std.AddBorders self.Transpose = self.core.std.Transpose self.Inflate = self.core.std.Inflate self.MaskedMerge = self.core.std.MaskedMerge self.ShufflePlanes = self.core.std.ShufflePlanes self.SetFieldBased = self.core.std.SetFieldBased def CutOff(self, low, hi, p): def inline(src): upsmp = self.Resample(src, src.width*2, src.height*2, kernel="gauss", a1=100, **fmtc_args) clip = self.Resample(upsmp, src.width, src.height, kernel="gauss", a1=p, **fmtc_args) return clip hif = self.MakeDiff(hi, inline(hi)) clip = self.MergeDiff(inline(low), hif) return clip def Pad(self, src, left, right, top, bottom): w = src.width h = src.height clip = self.Resample(src, w+left+right, h+top+bottom, -left, -top, w+left+right, h+top+bottom, kernel="point", **fmtc_args) return clip def NLMeans(self, src, d, a, s, h, rclip): pad = self.AddBorders(src, a+s, a+s, a+s, a+s) rclip = self.AddBorders(rclip, a+s, a+s, a+s, a+s) if rclip is not None else None nlm = self.KNLMeansCL(pad, d=0, a=a, s=s, h=h, rclip=rclip) clip = self.Crop(nlm, a+s, a+s, a+s, a+s) return clip def XYClosest(self, src1, src2, ref): clip = self.Expr([src1, src2, ref], "x z - abs y z - abs > y x ?") return clip class internal: def dilation(core, src, radius): for i in range(radius): src = core.Maximum(src) return src def erosion(core, src, radius): for i in range(radius): src = core.Minimum(src) return src def closing(core, src, radius): clip = internal.dilation(core, src, radius) clip = internal.erosion(core, clip, radius) return clip def opening(core, src, radius): clip = internal.erosion(core, src, radius) clip = internal.dilation(core, clip, radius) return clip def gradient(core, src, radius): erosion = internal.erosion(core, src, radius) dilation = internal.dilation(core, src, radius) clip = core.Expr([dilation, erosion], "x y -") return clip def tophat(core, src, radius): opening = internal.opening(core, src, radius) clip = core.Expr([src, opening], "x y -") return clip def blackhat(core, src, radius): closing = internal.closing(core, src, radius) clip = core.Expr([src, closing], "y x -") return clip def super(core, src, pel): src = core.Pad(src, 128, 128, 128, 128) clip = core.std.transpose(core.nnedi3.nnedi3(core.std.transpose(core.nnedi3.nnedi3(src, **nnedi_args)), **nnedi_args)) if pel == 4: clip = core.std.transpose(core.nnedi3.nnedi3(core.std.transpose(core.nnedi3.nnedi3(clip, **nnedi_args)), **nnedi_args)) return clip def basic(core, src, a, h, sharp, cutoff): c1 = 0.3926327792690057290863679493724 c2 = 18.880334973195822973214959957208 c3 = 0.5862453661304626725671053478676 weight = c1 * sharp * math.log(1.0 + 1.0 / (c1 * sharp)) h_refine = c2 * math.pow(h / c2, c3) upsampled = core.std.Transpose(core.nnedi3.nnedi3(core.std.Transpose(core.nnedi3.nnedi3(src, **nnedi_args)), **nnedi_args)) upsampled = core.NLmeans(upsampled, a, 0, h, None) resampled = core.Resample(upsampled, src.width, src.height, sx=-0.5, sy=-0.5, kernel="cubic", a1=-sharp, a2=0) clean = core.NLmeans(src, a, 0, h, None) clean = core.Merge(resampled, clean, weight) clean = core.CutOff(src, clean, cutoff) dif = core.MakeDiff(src, clean) dif = core.NLmeans(dif, a, 1, h_refine, clean) clip = core.MergeDiff(clean, dif) return clip def final(core, src, super, radius, pel, sad, sigma, alpha, beta, masking, show): constant = 0.0009948813682897925944723492342 me_sad = constant * math.pow(sad, 2.0) * math.log(1.0 + 1.0 / (constant * sad)) if masking: mask = core.Canny(src[1], sigma=sigma, **canny_args) mask = core.Expr(mask, "x {alpha} + {beta} pow {gamma} - 0.0 max 1.0 min".format(alpha=alpha, beta=beta, gamma=math.pow(alpha, beta))) expanded = internal.dilation(core, mask, radius[1]) closed = internal.closing(core, mask, radius[1]) mask = core.Expr([expanded, closed, mask], "x y - z +") for i in range(radius[2]): mask = core.Inflate(mask) if show: return mask for i in range(2): src[i] = core.Pad(src[i], 128, 128, 128, 128) src[1] = core.MakeDiff(src[1], src[0]) super[1] = core.MakeDiff(super[1], super[0]) if super[0] is not None and super[1] is not None else None blankdif = core.Expr(src[0], "0.0") supersearch = core.MSuper(src[0], pelclip=super[0], rfilter=4, pel=pel, **msuper_args) superdif = core.MSuper(src[1], pelclip=super[1], rfilter=2, pel=pel, **msuper_args) vmulti = core.MAnalyze(supersearch, radius=radius[0], overlap=64, blksize=128, **manalyze_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=32, blksize=64, thsad=me_sad, **mrecalculate_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=16, blksize=32, thsad=me_sad, **mrecalculate_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=8, blksize=16, thsad=me_sad, **mrecalculate_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=4, blksize=8, thsad=me_sad, **mrecalculate_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=2, blksize=4, thsad=me_sad, **mrecalculate_args) vmulti = core.MRecalculate(supersearch, vmulti, overlap=1, blksize=2, thsad=me_sad, **mrecalculate_args) averaged_dif = core.MDegrain(src[1], superdif, vmulti, thsad=sad, **mdegrain_args) averaged_dif = core.XYClosest(averaged_dif, src[1], blankdif) averaged_dif = core.Crop(averaged_dif, 128, 128, 128, 128) src[0] = core.Crop(src[0], 128, 128, 128, 128) clean = core.MergeDiff(src[0], averaged_dif) clip = core.MaskedMerge(src[0], clean, mask) if masking else clean return clip def Super(src, pel=4): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Super: src has to be a video clip!") elif src.format.sample_type != vs.FLOAT or src.format.bits_per_sample < 32: raise TypeError("Vine.Super: the sample type of src has to be single precision!") if not isinstance(pel, int): raise TypeError("Vine.Super: pel has to be an integer!") elif pel != 2 and pel != 4: raise RuntimeError("Vine.Super: pel has to be 2 or 4!") core = core src = core.SetFieldBased(src, 0) colorspace = src.format.color_family if colorspace == vs.RGB: src = core.RGB2OPP(src, 1) if colorspace != vs.GRAY: src = core.ShufflePlanes(src, 0, vs.GRAY) clip = internal.super(core, src, pel) del core return clip def Basic(src, a=32, h=6.4, sharp=1.0, cutoff=4): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Basic: src has to be a video clip!") elif src.format.sample_type != vs.FLOAT or src.format.bits_per_sample < 32: raise TypeError("Vine.Basic: the sample type of src has to be single precision!") if not isinstance(a, int): raise TypeError("Vine.Basic: a has to be an integer!") elif a < 1: raise RuntimeError("Vine.Basic: a has to be greater than 0!") if not isinstance(h, float) and not isinstance(h, int): raise TypeError("Vine.Basic: h has to be a real number!") elif h <= 0: raise RuntimeError("Vine.Basic: h has to be greater than 0!") if not isinstance(sharp, float) and not isinstance(sharp, int): raise TypeError("Vine.Basic: sharp has to be a real number!") elif sharp <= 0.0: raise RuntimeError("Vine.Basic: sharp has to be greater than 0!") if not isinstance(cutoff, int): raise TypeError("Vine.Basic: cutoff has to be an integer!") elif cutoff < 1 or cutoff > 100: raise RuntimeError("Vine.Basic: cutoff must fall in (0, 100]!") core =vs. core src = core.std.SetFieldBased(src, 0) colorspace = src.format.color_family if colorspace == vs.RGB: src = core.RGB2OPP(src, 1) if colorspace != vs.GRAY: src = core.std. ShufflePlanes(src, 0, vs.GRAY) clip = internal.basic(core, src, a, h, sharp, cutoff) del core return clip |
28th May 2023, 13:23 | #80 | Link |
def Final(src, super=[None, None], radius=[6, 1, None], pel=4, sad=400.0, sigma=0.6, alpha=0.36, beta=32.0, masking=True, show=False): if not isinstance(src, list): raise TypeError("Vine.Final: src has to be an array!") elif len(src) != 2: raise RuntimeError("Vine.Final: src has to contain 2 elements exactly!") elif not isinstance(src[0], vs.VideoNode) or not isinstance(src[1], vs.VideoNode): raise TypeError("Vine.Final: elements in src must be video clips!") elif src[0].format.sample_type != vs.FLOAT or src[0].format.bits_per_sample < 32: raise TypeError("Vine.Final: the sample type of src[0] has to be single precision!") elif src[1].format.id != vs.GRAYS: raise RuntimeError("Vine.Final: corrupted basic estimation!") if not isinstance(super, list): raise TypeError("Vine.Final: super has to be an array!") elif len(super) != 2: raise RuntimeError("Vine.Final: super has to contain 2 elements exactly!") for i in range(2): if not isinstance(super[i], vs.VideoNode) and super[i] is not None: raise TypeError("Vine.Final: elements in super must be video clips or None!") elif super[i] is not None: if super[i].format.id != vs.GRAYS: raise RuntimeError("Vine.Final: corrupted super clips!") if not isinstance(radius, list): raise TypeError("Vine.Final: radius parameter has to be an array!") elif len(radius) != 3: raise RuntimeError("Vine.Final: radius parameter has to contain 3 elements exactly!") for i in range(2): if not isinstance(radius[i], int): raise TypeError("Vine.Final: radius[" + str(i) + "] has to be an integer!") if radius[0] <= 0: raise RuntimeError("Vine.Final: radius[0] has to be greater than 0!") if radius[1] < 0: raise RuntimeError("Vine.Final: radius[1] has to be no less than 0!") if not isinstance(radius[2], int) and radius[2] is not None: raise TypeError("Vine.Final: radius[2] has to be an integer or None!") elif radius[2] is not None: if radius[2] < 0: raise RuntimeError("Vine.Final: radius[2] has to be no less than 0!") if not isinstance(pel, int): raise TypeError("Vine.Final: pel has to be an integer!") elif pel != 1 and pel != 2 and pel != 4: raise RuntimeError("Vine.Final: pel has to be 1, 2 or 4!") if not isinstance(sad, float) and not isinstance(sad, int): raise TypeError("Vine.Final: sad has to be a real number!") elif sad <= 0: raise RuntimeError("Vine.Final: sad has to be greater than 0!") if not isinstance(alpha, float) and not isinstance(alpha, int): raise TypeError("Vine.Final: alpha has to be a real number!") elif alpha < 0.0 or alpha > 1.0: raise RuntimeError("Vine.Final: alpha must fall in [0.0, 1.0]!") if not isinstance(beta, float) and not isinstance(beta, int): raise TypeError("Vine.Final: beta has to be a real number!") elif beta <= 1.0: raise RuntimeError("Vine.Final: beta has to be greater than 1.0!") if not isinstance(masking, bool): raise TypeError("Vine.Final: masking has to be boolean!") if not isinstance(show, bool): raise TypeError("Vine.Final: show has to be boolean!") if not masking and show: raise RuntimeError("Vine.Final: masking has been disabled, set masking True to show the halo mask!") radius[2] = math.ceil(radius[1] / 2) if radius[2] is None else radius[2] core = core for i in range(2): src[i] = core.SetFieldBased(src[i], 0) super[i] = core.SetFieldBased(super[i], 0) if super[i] is not None else None colorspace = src[0].format.color_family if colorspace == vs.RGB: src[0] = core.RGB2OPP(src[0], 1) if colorspace != vs.GRAY: src_color = src[0] src[0] = core.ShufflePlanes(src[0], 0, vs.GRAY) clip = internal.final(core, src, super, radius, pel, sad, sigma, alpha, beta, masking, show) if colorspace != vs.GRAY: clip = core.ShufflePlanes([clip, src_color], [0, 1, 2], vs.YUV) if colorspace == vs.RGB: clip = core.OPP2RGB(clip, 1) del core return clip def Dilation(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Dilation: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.Dilation: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.Dilation: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.dilation(core, src, radius) del core return clip def Erosion(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Erosion: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.Erosion: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.Erosion: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.erosion(core, src, radius) del core return clip def Closing(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Closing: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.Closing: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.Closing: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.closing(core, src, radius) del core return clip def Opening(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Opening: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.Opening: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.Opening: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.opening(core, src, radius) del core return clip def Gradient(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.Gradient: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.Gradient: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.Gradient: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.gradient(core, src, radius) del core return clip def TopHat(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.TopHat: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.TopHat: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.TopHat: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.tophat(core, src, radius) del core return clip def BlackHat(src, radius=1): if not isinstance(src, vs.VideoNode): raise TypeError("Vine.BlackHat: src has to be a video clip!") if not isinstance(radius, int): raise TypeError("Vine.BlackHat: radius has to be an integer!") elif radius < 1: raise RuntimeError("Vine.BlackHat: radius has to be greater than 0!") core = core src = core.SetFieldBased(src, 0) clip = internal.blackhat(core, src, radius) del core return clip Last edited by WaxCyl; 28th May 2023 at 13:56. Reason: added note |
