19th August 2014, 16:29 | #41 | Link |
Professional Code Monkey
I didn't change anything. That sounds more like a package name.
19th August 2014, 16:32 | #42 | Link | |
EDIT: i tried to launch vspipe from terminal and prompt me this: Code:
vspipe: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/local/lib/libvapoursynth.so) Last edited by dontrythisathome; 19th August 2014 at 16:44. |
19th August 2014, 17:40 | #46 | Link |
I just write down in the editor this simple script:
import vapoursynth as vs core = vs.get_core() print(c.version()) Code:
VapourSynth plugins manager: Failed to load vapoursynth library! Please set up the library search paths in settings. |
19th August 2014, 17:48 | #47 | Link |
Beyond Kawaii
It still can't load the library. Do try to rebuild VapourSynth. There's an error in your script. No variable c. It should be "print(core.version())". It still will not print you anything. The editor doesn't redirect stdout. It expects the script to have ouput video node.
...desu! |
19th August 2014, 17:52 | #48 | Link | |
Still don't load the library and syntax highlighting and autocompletion works only with existing variable though. |
19th August 2014, 18:21 | #50 | Link | |
To correct this error: Code:
vspipe: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/local/lib/libvapoursynth.so) After updated the LD_LIBRARY_PATH, trough the terminal vspipe worked. But when i close the terminal and open a new one, it's like the previous command was cancelled; so, i re-exported the PATH and launched vsedit from terminal, trying to run the simple script, but a new error prompted in vseditor Code:
Failed to get the script output node. Code:
QWidget::insertAction: Attempt to insert null action [ WHEN I OPEN VSEDIT FROM TERMINAL ] VapourSynth Video Processing Library Copyright (c) 2012-2014 Fredrik Mellbin Core r24 API r3 [WHEN I TRIED TO RUN THE SCRIPT] |
19th August 2014, 18:45 | #51 | Link |
Beyond Kawaii
"Failed to get the script output node." - this is an expected error, which I described before. Your script has no output node.
"QWidget::insertAction: Attempt to insert null action" - this is more interesting. Probably a harmless bug in recent files management. I'll look into it.
...desu! |
19th August 2014, 18:50 | #52 | Link | |
25th September 2014, 22:19 | #56 | Link |
Beyond Kawaii
Ugh. I didn't even know drag and drop worked with files. I'm planning to implement a snippets system. There will be snippets for files dropping too. But what kind of drag and drop do you mean?
...desu! |
24th October 2014, 18:35 | #60 | Link |
Beyond Kawaii
Yes, sure. Also, we need a line duplication hotkey.
But not until I finally solve the chroma upsampling issues >_< *bangs his head on the table* Meanwhile everyone feel free to suggest code editing features. It might the the next thing I concentrate on.
...desu! |
