#19381 | Link | |
Formally known as .......
https://forum.doom9.org/showthread.p...02#post1958502
We all need to get a life, before it's over. 5950X, Asus ROG Strix X570-F, RTX 3050 OC. 3950X, Asus ROG Strix X570-F, RX 480 & GTX 760. 5900X, MSI B550M-A Pro, GTX 980Ti Hybrid. and many more... |
#19382 | Link | |
So if I encode in a single chunk I don't see any problem with the output video is that because the frames are being encoded in sequence? |
#19383 | Link |
That's right. You may also try remuxing your video file in mkvtoolnix to see if this fixes seek issues.
#19384 | Link | |
I really prefer using Ripbot for 1080p encodes, but if I have to use Handbrake for the rare HEVC encode, so be it. |
#19385 | Link | |
A couple things I've noticed when trying to do the distributed encoding. One, if I enter the IP address of the host server, it will blank out the options for that server as if the IP is not allowed. If I change the IP by one digit in any direction, those options return. Are we no longer allowed to use the host computer as one of the distributed encoding processors? Next, when I try to do distributed encoding, the other computers I'm trying to use say "Access violation at address 0051AE24 in module 'EncodingServer.exe'. Read of address 00000098" Last edited by gabbett1; 23rd December 2021 at 22:19. |
#19386 | Link | |
There must be some addressing conflict somewhere you need to rectify.
#19387 | Link | |
Have you tried Staxrip ??
#19391 | Link |
Some app running in background is blocking Encoding Server. (Geforce Experience and so on)
#19392 | Link | |
Maybe change ALL your IP address's, and see if that does anything. Or you can try what is suggested in the post's just before this one..Safe Mode, some app running in the background causing havoc. And if Atak isn't going to chime in, that's about all I can suggest. Happy New Year.
#19394 | Link |
Check Wait Chain option
https://superuser.com/questions/4976...n-task-manager
#19395 | Link |
@Atak
Audio delay goes up to 10000ms Sometimes that's not enough. Mkv merge can go higher but has no preview Can you remove the delay limit on the next upgrade please?
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
#19396 | Link |
Any tried this, I did a conversion from Dolby Vision (Profile 7, Dolby Vision Dual layer) to Profile 8 (Dolby Vision Single Layer). Could be nice if this feature could be added into RipBot264.
https://forum.doom9.org/showthread.php?t=183479 I havent tried to use it on a encoding with cropping, but it should be possible to crop the RPU data before injecting it into the encoded MKV. So no need to do Dolby Vision encoding in x265 as its just extracted - Cropped - Injected into the final mkv file. |
#19397 | Link | |
If this could be added to RipBot so the Dolby Vision stream is added along with the HDR10, that would be wonderful. GZZ: How big was your Dolby Vision stream? I read it added several GB to the file size. |
#19398 | Link | |
Will upload them later today |
#19399 | Link | |
#19400 | Link | |
https://github.com/quietvoid/dovi_tool/issues/39 I quote regarding turning on the crop option: "It has no knowledge of the letterbox bars size, they are simply set to zero, to tell the Dolby Vision decoder that there are no letterbox bars encoded in the video." So far I've created a Dolby Vision version of Transformers the Movie and Dune Part1. Transformers looked better, but Dune was dimmer. BTW, I'm one of those strange ones that likes the "Vivid" settings on a TV, and on the Z9D, Vivid is amazing. My problem is probably due to settings the Z9D is setting to display Dolby Vision. I'll dig into that more as I like to keep the Dolby Vision stream in my encodes. Either way, the new DV tools are awesome in how easy they are to use. Could still use a bit more work so you can specify a location to pick up and store the RPU.bin file |
