Old 14th October 2015, 22:51   #41  |  Link
minaust
I discarded the profile guided optimization in the build process of the ICL Avisynth DLL. It's performance gains were very specific to the scripts I used for profiling. In other cases it actually decreased performance.
In short - yes, you should re-download the file or just replace the ICL avisynth.dll with this one.
Done. Many thanks.
minaust is offline   Reply With Quote
Old 15th October 2015, 11:07   #42  |  Link
Groucho2004
I have updated the switcher tool. It now includes a modified and extended version of the batch file by Jones1913 featuring a menu system, the possibility to specify custom plugin directories and an un-installer. Details in the first post.
Old 20th October 2015, 13:53   #43  |  Link
minaust
Well done - only problem is that it creates a problem when called from within another batch file. PAUSE and "Y/N" prompts a a bad idea in that case. so I fixed it: It now has "wipe32" and "wipe64" as command line options. The 'y/n' prompts are bypassed in command line mode. When run in menu mode it functions as before, except the "pause" at the end was removed. I did this because I'm doing batch encodes, and the encoder script first ser up a 64-bit avisynth environment, then restores the 32-bit environment upon completion. Here goes:
::batch script for fast switching of avisynth versions
::initial idea and work by Groucho2004 -> http://forum.doom9.org/showthread.php?t=172124
::modified by jones1913
::modified and extended by Groucho2004
@echo off
setlocal
fsutil dirty query %systemdrive% > nul
if errorlevel 1 goto :noAdmin
::  The variable "AVS_SRC_DIR" needs to be set according to the location this batch file:
::  When you unpack the repository and just want to create a shortcut to the batch file,
::  remove the colon from the beginning of the next line.
:set AVS_SRC_DIR=%~dp0
::  If you copy the batch file to a different directory (i.e. a directory to which the
::  "PATH" environment variable points), use a fully qualified path to the source
::  directory (don't forget to add the backslash at the end of that path), example below.
:set AVS_SRC_DIR=E:\VideoTools\AvisynthRepository\
::  Below are examples for custom plugin directories for 32 and 64 Bit Avisynth.
::  If you leave them blank and/or don't remove the colon at the beginning of the line,
::  the respective "plugin" directories within the "AvisynthRepository" source directory
::  will be used. Note that there must be *no* backslash at the end of the plugin path.
:set PLUGDIR32=E:\VideoTools\AVSPlugins\AutoLoad32
:set PLUGDIR64=E:\VideoTools\AVSPlugins\AutoLoad64
if /i %PROCESSOR_ARCHITECTURE%==x86 if not defined PROCESSOR_ARCHITEW6432 set winarch=x32
if [%1]==[] goto :menu
if /i %1==AVS257 (set avs=%1) & goto :install
if /i %1==AVS258 (set avs=%1) & goto :install
if /i %1==AVS260 (set avs=%1) & goto :install
if /i %1==AVS260_ICL (set avs=%1) & goto :install
if /i %1==AVS260_MT (set avs=%1) & goto :install
if /i %1==AVSPLUS_x86 (set avs=%1) & (set avspl=true) & goto :install
if /i %1==AVSPLUS_x64 (set avs=%1) & (set avspl=true) & goto :install
if /i %1==WIPE32 (set avs=AVSx86) & goto :uninstallauto
if /i %1==WIPE64 (set avs=AVSx64) & goto :uninstallauto
echo.
echo Unknown parameter.
:menu
cls
echo.
echo Which AviSynth version you want to install?
echo (Or call this batch file next time directly with one of the below listed parameters.)
echo.
echo 1 = AVS257
echo 2 = AVS258
echo 3 = AVS260
echo 4 = AVS260_ICL
echo 5 = AVS260_MT
echo 6 = AVSPLUS_x86
echo 7 = AVSPLUS_x64 *
echo.
echo 8 = WIPE32 (Uninstall AVS x86) **
echo 9 = WIPE64 (Uninstall AVS x64) **
echo.
echo *) AVS+ x64 can be installed in addition to one of the other (32 bit) versions.
echo.
echo **) the WIPE commands bypass the y/n prompt. Be careful!
echo.
set no=
set /p no=[1-9] (leave blank and [Enter] for exit):
if [%no%]==[] goto :cancel
if %no%==1 set avs=AVS257
if %no%==2 set avs=AVS258
if %no%==3 set avs=AVS260
if %no%==4 set avs=AVS260_ICL
if %no%==5 set avs=AVS260_MT
if %no%==6 (set avs=AVSPLUS_x86) & set avspl=true
if %no%==7 (set avs=AVSPLUS_x64) & set avspl=true
if %no%==8 (set avs=AVSx86) & goto :uninstall
if %no%==9 (set avs=AVSx64) & goto :uninstall
echo.
if [%avs%]==[] (echo Invalid input...
	goto :menu)
:install
if "%PLUGDIR32%" == "" (
  set REGPLUGDIR32=%AVS_SRC_DIR%%avs%\plugins
) else (
  set REGPLUGDIR32=%PLUGDIR32%
if "%PLUGDIR64%" == "" (
  set REGPLUGDIR64=%AVS_SRC_DIR%%avs%\plugins
) else (
  set REGPLUGDIR64=%PLUGDIR64%
echo Installing %avs%...
echo.
if defined winarch (
	echo setup for 32bit windows system...
	echo.
	if /i %avs%==AVSPLUS_x64 ( echo Attempt to install x64 AVS on x32 Windows.
		goto :cancel )
	echo copying %avs% files to "%WINDIR%\System32"...
	copy /y "%AVS_SRC_DIR%%avs%\avisynth.dll" "%WINDIR%\System32"
	copy /y "%AVS_SRC_DIR%%avs%\devil.dll" "%WINDIR%\System32"
	if errorlevel 1 ( echo Failed to copy files to "%WINDIR%\System32"
		goto :error )
	echo.
	echo reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%"
	reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" /f
	if errorlevel 1 ( echo Error on importing registry keys!
		goto :error )
	call :regWin
) else (
	echo setup for 64bit windows system...
	echo.
			goto :error )
		echo.
		echo reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR64%"
		reg add "HKLM\SOFTWARE\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR64%" /f
			goto :error )
		call :regWin
	) else (
		echo copying %avs% files to "%WINDIR%\SysWow64"...
		echo copy /y "%AVS_SRC_DIR%%avs%\avisynth.dll" "%WINDIR%\SysWow64"
		copy /y "%AVS_SRC_DIR%%avs%\devil.dll" "%WINDIR%\SysWow64"
		if errorlevel 1 ( echo Failed to copy files to "%WINDIR%\SysWow64"
			goto :error )
		echo.
		echo reg add "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%"
		reg add "HKLM\SOFTWARE\Wow6432Node\Avisynth" /v "PluginDir2_5" /d "%REGPLUGDIR32%" /f
			goto :error )
		call :regWow64
goto :end
:regWin
echo.
echo adding more registry entries...
reg add "HKLM\SOFTWARE\Classes\AVIFile\Extensions\AVS" /ve /d "{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /ve /d "AviSynth" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /ve /d "AviSynth.dll" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /v "ThreadingModel" /d "Apartment" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\Media Type\Extensions\.avs" /v "Source Filter" /d "{D3588AB0-0781-11CE-B03A-0020AF0BA770}" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\.avs" /ve /d "avsfile" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\.avsi" /ve /d "avs_auto_file" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\avsfile" /ve /d "AviSynth Script" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\avsfile\DefaultIcon" /ve /d "%WINDIR%\System32\AviSynth.dll,0" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\avs_auto_file" /ve /d "AviSynth Autoload Script" /f >nul 2>&1
if defined avspl (reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve  /d "%WINDIR%\System32\AviSynth.dll,1" /f
	) else reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\System32\AviSynth.dll,0" /f
goto :eof
:regWow64
echo.
echo adding more registry entries (wow64 mode)...
reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /ve /d "AviSynth" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /ve /d "AviSynth.dll" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32" /v "ThreadingModel" /d "Apartment" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Wow6432Node\Classes\Media Type\Extensions\.avs" /v "Source Filter" /d "{D3588AB0-0781-11CE-B03A-0020AF0BA770}" /f >nul 2>&1
reg add "HKLM\SOFTWARE\Classes\avsfile\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,0" /f >nul 2>&1
if defined avspl (reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,1" /f
	) else reg add "HKLM\SOFTWARE\Classes\avs_auto_file\DefaultIcon" /ve /d "%WINDIR%\SysWow64\AviSynth.dll,0" /f
goto :eof
:uninstall
echo.
echo Remove %avs% .dll and registry entries from this system?
set /p rm=[y/n]:
if /i not [%rm%]==[y] goto :cancel
:uninstallauto
echo.
	if /i %avs%==AVSx64 ( echo Attempt to remove x64 AVS from x32 Windows.
		goto :cancel )
	echo removing %avs% files from "%WINDIR%\System32"...
	del "%WINDIR%\System32\avisynth.dll"
	del "%WINDIR%\System32\devil.dll"
	call :unregWin all
) else (
		if exist "%WINDIR%\SysWow64\avisynth.dll" (call :unregWin) else (
			call :unregWin all )
	) else (
		echo removing %avs% files from "%WINDIR%\SysWow64"...
		del "%WINDIR%\SysWow64\avisynth.dll"
		del "%WINDIR%\SysWow64\devil.dll"
		if exist "%WINDIR%\System32\avisynth.dll" (call :unregWow64) else (
			call :unregWow64 all )
goto :end
:unregWin
echo.
echo removing registry entries...
reg delete "HKLM\SOFTWARE\Avisynth" /f
reg delete "HKLM\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f
reg delete "HKLM\SOFTWARE\Classes\Media Type\Extensions\.avs" /f
if [%1]==[all] call :unregAll
goto :eof
:unregWow64
echo.
echo removing registry entries (wow64 mode)...
reg delete "HKLM\SOFTWARE\Wow6432Node\Avisynth" /f
reg delete "HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}" /f
reg delete "HKLM\SOFTWARE\Wow6432Node\Classes\Media Type\Extensions\.avs" /f
goto :eof
:unregAll
echo.
echo removing more avs registry entries...
reg delete "HKLM\SOFTWARE\Classes\AVIFile\Extensions\AVS" /f
reg delete "HKLM\SOFTWARE\Classes\.avs" /f
reg delete "HKLM\SOFTWARE\Classes\.avsi" /f
reg delete "HKLM\SOFTWARE\Classes\avsfile" /f
reg delete "HKLM\SOFTWARE\Classes\avs_auto_file" /f
goto :eof
:noAdmin
echo This script must run with elevated privileges, so:
echo.
echo   a) right click on it, chose "run as administrator"
echo   b) or start it from within a root cmd window
:error
echo.
echo something went wrong...
:cancel
echo.
echo cancelled...
:end
endlocal
echo.
As you can see, basically I added two lines, a new label, removed the pause, and modded the menu to reflect the new functionality.
Old 28th April 2016, 13:22   #44  |  Link
Groucho2004
Update:
- Replaced the r1576 AVS+ DLLs with the latest versions from pinterf
- Batch file tweaks/cosmetics
Old 29th April 2016, 14:08   #45  |  Link
minaust
Update:
Excellent! Got it.
Old 28th September 2016, 18:29   #46  |  Link
Groucho2004
2016/09/28
- Updated AVS+ DLLs to the latest versions (r2172)
Groucho's Avisynth Stuff
Old 29th September 2016, 22:43   #47  |  Link
minaust
2016/09/28
Thank you, and thank you for keeping this little gem going.
Old 3rd October 2016, 01:51   #48  |  Link
hydra3333
Yes, thank you.
Old 9th February 2017, 14:01   #49  |  Link
Groucho2004
2017-02-09
- Updated AVS+ DLLs to the latest versions (r2420)
Old 10th February 2017, 02:17   #50  |  Link
minaust
2017-02-09
Thank you sir.
Old 21st February 2017, 18:59   #51  |  Link
tcope
Digital Artifact
tcope's Avatar
Deleted because was incorrect and cluttered the thread.
tcope is offline   Reply With Quote
Old 9th March 2017, 11:42   #52  |  Link
tebasuna51
tebasuna51's Avatar
Last 6 post moved to new thread Linux AviSynth Switcher
Old 12th March 2017, 11:41   #53  |  Link
tebasuna51
tebasuna51's Avatar
@Groucho2004
About the setavs.bat in your package, there are:
::  The variable "AVS_SRC_DIR" needs to be set according to the location of this batch file:
::  Option 1
::  Option 2
:set AVS_SRC_DIR=E:\Apps\VideoTools\AvisynthRepository
But set AVS_SRC_DIR=%~dp0 produce a string finished with a slash like:
INSTALL_FOLDER\
After that all references like %AVS_SRC_DIR%\%avs% produce strings with a double slash.
I suggest use %AVS_SRC_DIR%%avs% (without the slash) and
::  Option 2 (example with finish slash)
:set AVS_SRC_DIR=E:\Apps\VideoTools\AvisynthRepository\
Old 12th March 2017, 12:34   #54  |  Link
Groucho2004
@Groucho2004
::  Option 1
::  Option 2
INSTALL_FOLDER\
Nice catch. Another fix would be this (which I think I'd prefer):
if "%AVS_SRC_DIR:~-1%"=="\" SET AVS_SRC_DIR=%AVS_SRC_DIR:~0,-1%
Old 12th March 2017, 14:01   #55  |  Link
tebasuna51
tebasuna51's Avatar
Of course.
Nice tool, I'm testing now to have Avs+ 32 and 64 bits installed.
Old 12th March 2017, 20:12   #56  |  Link
Groucho2004
2017-03-12
  • Updated AVS+ to the latest version (r2440)
  • Fixed potential issue with trailing backslashes in the batch file
Old 12th March 2017, 22:19   #57  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Great stuff! Thanks for the updates and others helping in on things.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 13th March 2017, 04:30   #58  |  Link
tcope
Digital Artifact
tcope's Avatar
@ tebasuna51
with coexistence .. am guessing you are running windows ..
I have not 64 bit windows to test on.
Install 32 bit AVS then install 64 bit avs,
then run tests with 32 bit..
Is windows maintaining arch isolation ?
Old 13th March 2017, 08:51   #59  |  Link
ChaosKing
I get a syntaxerror after the :menu (win10 x64).
The 2 new added lines are the problem:
if "%PLUGDIR32:~-1%"=="\" SET PLUGDIR32=%PLUGDIR32:~0,-1%
if "%PLUGDIR64:~-1%"=="\" SET PLUGDIR64=%PLUGDIR64:~0,-1%
EDIT:
works with the update now
Old 13th March 2017, 10:17   #60  |  Link
Groucho2004
Yeah, I did not test it properly. Will be fixed shortly.
