2nd August 2020, 13:30 | #1001 | Link | |
The main benefit of 10-bit video lies in the encoding process where it can improve compression efficiency. The visual quality difference of sending 8 or 10-bit to the monitor is very very small. |
4th August 2020, 08:24 | #1002 | Link | |
When you enable 10-bit output in the EVR-CP and see it in statistics, it probably doesn't work. You just specify 10-bit format for the D3D9 backbuffer, but display output can be 8-bit.
D3D9 supports 10-bit output very poorly. You won't even be able to correctly identify the display mode. IDirect3D9::GetAdapterDisplayMode Quote:
MPC-BE 1.7.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
6th August 2020, 21:41 | #1003 | Link |
I just tested out 1.9.7 and for some reason it clears out my keyboard shortcut for exit. I tried to reset it and it clears it out after every start. I have it set to the same as stop so that when I press stop on my remote it closes down. This has worked fine through 1.9.6 but for some reason 1.9.7 clears the slot for exit. Even if I try to use another button's keyboard shortcut it wont exit when its pressed.
7th August 2020, 22:04 | #1004 | Link | |
Perhaps it should be an option to allow (or not allow) the same shortcut to have multiple commands. |
12th August 2020, 09:21 | #1005 | Link |
Has anything changed in the implementation of seeking?
I always have left/right key associated with jump forward/backwards by a keyframe, but today I've noticed the jump is more like at least half a second. That didn't work that way in past (no idea when last). |
12th August 2020, 10:47 | #1007 | Link |
Just to confirm,
is View > Renderer Settings > Presentation > Output Range > 0 -255 or 16-235 expected to have any effect with EVR-CP/DXVA2, RGB32 output ? I am not seeing any difference by changing between the 2 values on my system with intel igpu (same result with Mpc-be). My understanding of range handling by mpc-hc/be is that with a yuv video file, range will be expanded at yuv-rgb conversion at the renderer Input unless the video stream has Color range: Full (tag visible in mediainfo).
bShaders: realtime Effects/filters for video players |
12th August 2020, 11:41 | #1009 | Link |
I have deleted the settings file and redid everything from scratch, and now it behaves even weirder: the keyframe jump now does about five seconds while "jump small" is exactly one (that used to be a tin bit longer before too).
12th August 2020, 15:16 | #1010 | Link |
Left/Right is medium jump.
Shift+Left/Right is jump to previous/next keyframe. You can customize this in the options. Small/medium/large jumps try to jump to a keyframe (if fast seek enabled) that is nearest to the target time. In case of small jump (default 1 sec) that often has a too large inaccuracy, so then it will do an exact jump to a non-keyframe. @butterw2 Range handing is done automatic for decoding. The renderer setting is unrelated to decoding. Please don't touch any range related settings. You are only going to create problems for yourself. |
12th August 2020, 16:39 | #1011 | Link |
Yes, I always remap the keys so that left/right is a keyframe, shift+arrow is small, medium is nothing and alt+arrow is large.
I haven't changed any settings in months and only updated the program itself, and now I noticed the jump segments changed considerably, so I can only assume something in the code is responsible for that. What I was talking about was not jumping TO a keyframe but BY a single keyframe. I mean it's right there in the settings. It just doesn't work anymore. I tried three videos with different codecs and they all behave the same way. |
12th August 2020, 17:27 | #1012 | Link |
Jumping code hasn't changed in a long time. It might be a bug where key mappings are reset.
Try this dev build which has a fix for that: https://github.com/clsid2/mpc-hc/rel...9.7.22.x64.zip |
12th August 2020, 17:44 | #1013 | Link |
That seems to be the same.
I believe I was used to be able to jump between several frames per second (but not like full 24 or whatever stuff is shot at). Jumping a single keyframe "currently" still does something a litle under one second, definitely a LOT more than it used to be in some unknown point in past. |
12th August 2020, 22:39 | #1015 | Link |
Since it wasn't directly mentioned before, keyframe jumping will directly depend on the video you are testing with. Player version has nothing to do with it (if there arent any bugs). A single video could have multiple per second, or one every couple seconds. Less keyframes is typically better for compression.
Its very much possible that videos you used some time ago just had more keyframes.
13th August 2020, 07:12 | #1016 | Link |
I did mention this. DVD Video typically has GOPs of half a second. And Blu-ray compliant AVC has a smaller GOP size (up to 1 or 2 sec) as well. Only efficient recodes for harddisk storage prefer longer GOPs.
15th August 2020, 23:37 | #1017 | Link |
About playing HLS steams. When an URL pointing to a master playlist containing multiple streams with same resolution and framerate but different bitrate is opened, the stream with the highest bitrate is not necessarily played.
#EXTM3U #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1047320,RESOLUTION=768x432,FRAME-RATE=50.000,CODECS="avc1.4d401f,mp4a.40.2",VIDEO-RANGE=SDR index-f1-v1-a1.m3u8?token=abc.123 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1776902,RESOLUTION=1024x576,FRAME-RATE=50.000,CODECS="avc1.4d4020,mp4a.40.2",VIDEO-RANGE=SDR index-f2-v1-a1.m3u8?token=abc.123 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=3360822,RESOLUTION=1280x720,FRAME-RATE=50.000,CODECS="avc1.4d4020,mp4a.40.2",VIDEO-RANGE=SDR index-f3-v1-a1.m3u8?token=abc.123 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=4772596,RESOLUTION=1280x720,FRAME-RATE=50.000,CODECS="avc1.4d4020,mp4a.40.2",VIDEO-RANGE=SDR index-f4-v1-a1.m3u8?token=abc.123 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=684164,RESOLUTION=512x288,FRAME-RATE=50.000,CODECS="avc1.4d401e,mp4a.40.2",VIDEO-RANGE=SDR index-f5-v1-a1.m3u8?token=abc.123 #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=122448,RESOLUTION=768x432,CODECS="avc1.4d401f",URI="iframes-f1-v1-a1.m3u8?token=abc.123",VIDEO-RANGE=SDR #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=215693,RESOLUTION=1024x576,CODECS="avc1.4d4020",URI="iframes-f2-v1-a1.m3u8?token=abc.123",VIDEO-RANGE=SDR #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=393745,RESOLUTION=1280x720,CODECS="avc1.4d4020",URI="iframes-f3-v1-a1.m3u8?token=abc.123",VIDEO-RANGE=SDR #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=517641,RESOLUTION=1280x720,CODECS="avc1.4d4020",URI="iframes-f4-v1-a1.m3u8?token=abc.123",VIDEO-RANGE=SDR #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=73710,RESOLUTION=512x288,CODECS="avc1.4d401e",URI="iframes-f5-v1-a1.m3u8?token=abc.123",VIDEO-RANGE=SDR Edit: URL is like https://something.fi/88/online/video...?token=abc.123 |
16th August 2020, 12:42 | #1019 | Link | |
This is frustrating, I can't give you anything specific you could check out in the code. |
16th August 2020, 12:57 | #1020 | Link |
Also, a feature request: could you add an option to save image in the full resolution? I have some videos that are larger than my 1920x1200 monitor and if I take a screenshot, MPC saves it in the displayed size, not the original.
